petetherock
Denon 2017-2018 AV models
I am looking forward to the new AVC X8500H....
Some info on the new flagship 8500:
https://translate.google.co.uk/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.avcesar.com%2Factu%2Fid-23363%2Fdenon-avc-x8500h-132-hdmi-21-upscaling-ultra-hd-4k-compatible-8k-et-10k.html&edit-text=
No HDMI 2.1 when it is launched, so it remains to be seen if we will be fleeced again for the update...
Moderator
oh wow thats some amazing news from denon Pete. bang on 10 years looks like they will indeed deliver on follow up on their flagship A series launched 10 years ago !
I am now looking forward to news on the A series pre amp in the mighty AVPs replacement :) surely it must not be far away.
what is really interesting too is multi eq pro :) yeah great news thats being kept !!!
what they do say is hdmi 2.1 as an update. my bet like the marantz series ... it will just be provided :) great its there as an option.
I was really keen on the SR 8012, but the fact that it only has HDMI 2.0b and won't be upgradable was a big minus.
The 8500 uses the same 4490 DAC as the 7200 whereas the 8012 uses the same 4458 from the earlier 7011 & 7010..
So the 8500 is akin to a 7200 on steroids plus two more channels, whilst the 8012 is a 7010 on steroids with two extra channels and a toroidal transformer.
Note that the 8012 has the same capacitance as the 7200, which drives nine channels only.
So I do not know how much of a powerhouse that 8012 will be..
No radio though... the units are starting to arrive in Asia-Pac ... should I pick one up ... hmm..
Pete out of curiosity what are the price for these in Singapore?
SRP is S$6k... you might be able to knock a few hundred off... but I don't have the indicative price yet..
Start watching around 10:00 for the AVC 8500 information.
27kg!
Thick panels !
Copper plates around the power section.
Griffin Lite 32 bit DSP chips!
32 bit up-conversion:
http://www.analog.com/en/products/landing-pages/001/adsp-sc58x-adsp-2158x-series.html
Around the 25:00 it can consume 2800W to power all 13 channels ... :ohmy:
Edited by petetherock
I found a site in Japanese which confirms that the 8500 has the same capacitance as the 7200, but has to drive more channels:
https://translate.google.com.sg/translate?sl=ja&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fweekly.ascii.jp%2Felem%2F000%2F000%2F409%2F409760%2Findex-2.html&edit-text=
Quote
The interior is a symmetrical design centered on a large EI transformer. This is a tradition after "POA - 3000" developed at the end of the 1970 's. The EI transformer has a core size of 111 mm, a stacking pressure of 90 mm, and a weight of 8.2 kg. The power supply part is also powerful, and it is possible to output 1557 W / 8 Ω by actual measurement when 13 ch simultaneous output is said. The block condenser is custom like the AVR - 7200 W, and it has a large capacity of 22000 uF.
https://www.phileweb.com/news/d-av/201801/17/43086_2.html
This website has plenty of info and pics..
Quote
The block condenser of the power supply section is equipped with two dedicated tuned 22,000 μF custom capacitors. It is said that it was able to realize sound with high power and stable power supply by the power unit composed of these, combined with low center of gravity and vividness.
Customized 22,000 μF capacitor dedicated to tuning
A total of 8 32-bit 2-channel DAC 'AK4490' mounted
D / A conversion is carried out by mounting a total of 8 32-bit 2 ch DAC chips of AKM Asahi Kasei Electronics (AKM) 'Ak 4490' Constitution. This D / A conversion circuit is mounted on a dedicated board, and independent from the video circuit and network circuit, eliminates mutual interference.
An independent D / A conversion circuit board
Moreover, by using dedicated board, the layout of D / A conversion circuit, signal line, power supply line is also optimized. Together with the selection of sound quality countermeasure parts and the redesign of the post lifter, it is said that DAC chip performance will be maximized.
Refreshed design. Adopted 3 piece cover since AVC-A1HD Redesigned the
design as a new flagship. Keeping in mind the traditional tone, we pushed out the front part more and made it a solid design.
Adopted 3-piece cover consisting of top panel, left and right side panels
For the cabinet, we adopted a three-piece top cover that uses aluminum side covers since AVC-A1HD. The ventilation (ventilation hole) applied to the cover is also optimized considering the resonance.
For the chassis, a 1.2 mm thick steel plate was used for the bottom chassis, a 1.2 mm thick bottom plate and a 1.2 mm thick transformer plate were added to make a total 3.6 mm thick triple layered chassis. This ensures high chassis rigidity and vibration resistance.
Triple layered chassis with total thickness of 3.6 mm is adopted
Besides that, as an AV amplifier, it is also sticking to the rigidity and design of the cabinet, such as "8mm thick aluminum trap door", "Mr. Miyahara is thicker than anywhere", inside the spin finish panel, original screws.
The speaker terminal also changed to the latest terminal adopted from AVR-X6400H. In the past, the grounding part, which was made up of two metal parts, was made up of one metal part. In addition to increasing the stability and durability of the connection, it also contributes to improving sound quality as a result.
It was also appealing that this machine was consistently produced at its own factory in Shirakawa City, Fukushima Prefecture, under strict quality control.
Marantz SR 8012
Denon AVC X8500H
Remarks
DSP chipset
ADSP 21487 (4)
ADSP 21537 (2)
aka Griffin Lite
Power
11 channels
13 channels
Capacitance
? 44 000uf
44 000uF
Processing capability
11
13
Pre-outs
11
15
Transformer
Toroidal
Square
Chassis
Copper
Triple layer
Denon – hand built in small batches
Weight
17.4 kg
23.6kg
Sound enhancements
HDAM modules
DDSC AL32 processing
HDMI
2.0b
2.1 (via an upgrade)
DAC
AKM 4458VN
AKM 4490EQ (one per channel)
Power consumption
780W
900W
Audyssey APP support
Paid extra
Paid extra
RC 5 trigger
Activates other Marantz products
nil
Remote
Backlight button
Motion sensor backlight
Moderator
pete...all this tells me just one thing
many people have said the A line is dead....
well I think the above shows the A line is back :D
are we back to the days of the denon A lines leading the D&M lines ? well in receiver stakes it seems to be
I cant wait to see if there will be a return of the mighty A line pre pro ! ...  TRUE FLAGSHIP !
It's a bit hard.. because of the price and how fast things move..
The older models had a lot of cooling fins - hence the weight.. these days, the fans take heat off, literally.. and here, a few kilos might come from those reinforced plate, and the capacitance is a lot lower than before...
This is when Denon made true High End AV Reciever,s ...AVCA1 XVA .....I still have one of the old beast,s...48KG and HUGE power supply,s..:)   Makes the current gen stuff look very "Anaemic"
Just purchased a Denon 8500. Will post my impression once I get it and have it setup
The Americans just received a FW update, And it might be the Auro update everyone is waiting for..
Many years ago this forum pointed me in the direction of KEC in Singapore in order to get a great price on a Denon 4810 shipped to Australia. Just wondering if there are any outlets in Singapore that will ship these receivers to Australia? any good recommendations?
Kind Regards
Scott
I can't recall any company that deals online or takes email orders anymore. You probably need to turn up in Singapore..
They will certainly ship overseas from the post offices or Fedex offices after you pay in person :)
Some feedback on my purchase of this receiver.
When I initially set it up, I hated what Audessey had done to the sound in my room. Bass was uneven and messy, male voices sounded unnatural, highs were unpleasant. I was very much in buyer’s remorse and missing my Yamaha.
This was the first time I had used Audessey (or had a Denon), so I was not familiar with all the features and parameters.
I did some reading, purchased the Audessey app, and brought out my Umik and REQ.
After a couple hrs of calibration and adjustment and implementing a house curve through the app, the sound is A LOT better. The bass is fantastic. I was surprised how well it evened the bass response (as confirmed by independent measurements I made with the Umik/REW). So much so that be Behringer FBD I previously used to manually adjust the bass is redundant.
I did note that the dynamics and some of the highs were a bit oppressed. But I think with some more reading/experimentation with the Audessey App features and the house curve, I can address this.
Some other observations of note:
  • The setup process is really good. Very intuitive with the menu structure.
  • When manually changing the gain/SPL settings for each speaker, I like how the order of the speakers allows you to compare levels with different sets of speakers (i.e. rear to top and side to top). This allowed me to pick up an issue with my rear surround and rear height speaker placement – they are too close together, giving the impression sound is coming from the same location
  • The remote buttons automatically lights up with the remote is moved. This is really handy when the rooms lights are off
  • The on screen display shows what audio signal is being provided into the receiver and the associated channels that would be natively driven, as well as what processing the receiver is doing and what channels are actually being driven.
  • WTF is up with the mic and mic stand (cardboard cut-out…really???). For a flag ship receiver with a RRP of $6K, what a let down
After a disappointing start, I am overall quite happy with my purchase.
I have still yet to connect my front wide channels to complete the 9.2.4 setup. Look forward to doing this when I get back home in a couple of weeks, and finishing fine tuning/calibrating the audio.
Did anyone see a FW update for their 8500 today?
    • By DiaNode
      Item: Denon PMA1600NE integrated amplifier (current model)
      Price: $1850
      Item Condition: As new, no marks, working perfectly, still in box
      Reason for selling: Not using
      2 x 70W @ 8ohm output, 20 Hz - 20 kHz, T.H.D. 0.07%
      Ultra High Current (UHC)-MOS Single Push-Pull Circuit Power Amplifier with Schottky barrier diodes
      Embedded D/A converter, DAC Master Clock Design
      2 Digital Optical and 1 Digital Coaxial inputs; Rear USB-B input
      High performance MM & MC Phono Equalizer Amp
      Base/treble/balance controls
      Remote control
      Weight: 17.6 kg
      Size: 434 W x 414 D x 135 H (mm)
      Winner HiFi Choice integrated amp group test September 2017
      Would prefer Melbourne sale but if no sale within a few weeks may consider mailing, cost arrangement to be determined.
    • By Sceeta
      Item: Denon DL-103 MC Cartridge
      Price: $750  $450
      Item Condition: Near new
      Reason for selling: Upgrading
      Extra Info: Selling on behalf of a mate. A near new Golden Age Audio custom wood bodied Denon DL103 cartridge. These things get a lot of great reviews although I haven't heard one myself I believe they are exceptional once they are upgraded. Here's a chance to get one at a really great price. Please PM if interested and I can put you in touch with the seller. Apologies for the crap photo. Comes with box and specification sheet. Postage at buyers cost.
    • By dmitry
      Item: Denon DCD 720AE CD Player
      Price: $350
      Item Condition: As New, no marks, scratches, etc. No remote - I used a Logitech universal one
      High quality Super Audio Disc player from Denon, DCD-720AE, integrates high-precision 32-bit/192-kHz DAC with AL32 Processing for superior performance.
      The DCD-720AE is a CD player with AL32 Processing that plays not only music CDs but also files from an iPod in beautiful high-quality sound. To fully harness the superior performance of AL32 Processing, a Denon technology that produces analog waveforms from digital signals, it is combined with a high-precision 32-bit/192-kHz D/A converter and a variety of other designs dedicated to producing high-quality sound. The front panel includes a USB port where an iPhone, iPod or other portable audio device can be connected to enjoy music from those devices in the renowned Denon sound quality.
      Features:
      AL32 Processing, to dramatically enhance the music listening experience High Precision 32bit/192kHz D/A converter Vibration-resistant design with Direct Mechanical Ground Construction Original DENON Mechanism centrally located Carefully designed construction to preserve audio signal purity Minimum signal path design Strictly selected parts for high sound quality Pure Direct to preserve pure audio details USB port for playback from an iPod or USB device Folder Mode function, for playing only files stored in specific folders Aluminium front panel, fitting the elegant design of other components in the range
      Channels: 2 channel stereo Dynamic range: 100 dB Signal-to-noise ratio: 110 dB Total harmonic distortion: 0.0025% (1 kHz) Dimensions (W x H x D): 434 x 107 x 279 mm Weight: 4.2 kg
      https://www.au.denon.com/au/product/hificomponents/sacdcdplayers/dcd720ae
    • By dmitry
      Item: Denon DNP-730AE network audio player (DSD [2.8, 5.6], PCM [FLAC 192/24], DLNA, Spotify Connect)
      Price: $470
      Item Condition: As New, no scratched, marks, etc. Perfect working order. 1.6 yo
      Burr Brown/Texas Instruments PCM1795 Inputs: 1 x USB-A, 1 x Ethernet, Wi-Fi Outputs: 1 x analogue stereo (RCA), 1 x optical digital Other: 1 x IR out Frequency response: 2-96,000Hz (PCM @ 192kHz); 2-20,000Hz (PCM @ 44.1kHz); 2-50,000Hz -3dB (DSD) S/N: 115dB (PCM/DSD, Audible range) Dynamic range: 100dB (PCM, Audible range); 105dB (DSD, Audible range) Harmonic distortion: 0.002% (PCM, 1 kHz, Audible range); 0.001% (DSD, 1 kHz, Audible range) Dimensions (whd): 434 x 73 x 297mm Weight: 2.9kg   http://www.avhub.com.au/product-reviews/sound-image/denon-dnp-730ae-network-audio-player-review-415212
      https://www.au.denon.com/au/product/hificomponents/networkaudioplayers/dnp730ae
    • By Alex32
      Item: Assorted In-Ear Headphones
      Price: Starting @ $30 up to $65
      Item Condition: Brand New, never been opened
      Reason for selling: Don't need
      Payment Method: Pickup - Cash, Paypal, COD Only - +3% For Paypal buyers - Happy to post at buyers expense.
      I've got 3 pairs of the Klipsch Reference S4 @ $65ea
      Then I have a pair of Denon AH-C @ $40
      Then I got a pair of Monster MobileTalk Headphones @ $30
