daedalus Posted August 9, 2010 Share Posted August 9, 2010 Hi, I have a Pioneer VSX-517. I would like to connect a power amp to it and use the Pioneer as a processor as I have sources connected to it via optical SPDIF. I have read that I would need a "pre-out". My pioneer has audio left out and audio right out (see page 2 of http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/424500909VSX-517-K(-S).pdf) Do I connect that to the Audio left in and Audio left in of the power amp? This seems to be the case for say Cambridge Audio according to their instructions http://www.cambridgeaudio.com/assets/documents/AP208461Azur740ACQuickStartGuide.pdf Thanks! Link to comment Share on other sites More sharing options...
Grumpy Posted August 9, 2010 Share Posted August 9, 2010 Unfortunately by the looks of your Pioneer you don't have pre-outs to connect extra power amps. Might be time to upgrade if you want better sound from 2 channels or more power from a power amp. Link to comment Share on other sites More sharing options...
daedalus Posted August 9, 2010 Author Share Posted August 9, 2010 Unfortunately by the looks of your Pioneer you don't have pre-outs to connect extra power amps. Might be time to upgrade if you want better sound from 2 channels or more power from a power amp. hmm then what does the "audio out" ports do then? Link to comment Share on other sites More sharing options...
Grumpy Posted August 9, 2010 Share Posted August 9, 2010 (edited) I can't see any audio outs in the pic on page 2 except for the Sub woofer Edited August 9, 2010 by Grumpy Link to comment Share on other sites More sharing options...
daedalus Posted August 9, 2010 Author Share Posted August 9, 2010 I can't see any audio outs in the pic on page 2 except for the Sub woofer on page 2 with the pic of the rear of the receiver, goto the top left of the receiver. To the right of the Optical In port under the "DVR/VCR" section there are 2 RCA ports labelled "OUT". Similarly, on the bottom left to the right of the lowest COAX input there are also 2 RCA ports labelled "OUT". are those "pre outs"? Link to comment Share on other sites More sharing options...
Benje Posted August 9, 2010 Share Posted August 9, 2010 they may be 'post outs'. They may be suitable to feed an amplifier. I wouldn't know. Benje Link to comment Share on other sites More sharing options...
cmcook Posted August 9, 2010 Share Posted August 9, 2010 I would think they are not volume controlled. Link to comment Share on other sites More sharing options...
Jake Posted August 9, 2010 Share Posted August 9, 2010 The lower ones are tape outs, and would definitely be fixed volume, I'm not sure about the other ones. Link to comment Share on other sites More sharing options...
little blue penguin Posted August 9, 2010 Share Posted August 9, 2010 Both sets are fixed level outputs intended for devices that can record external sources. These are unsuitable to connect to an external amp. There are no pre-outs on this amp. Link to comment Share on other sites More sharing options...
daedalus Posted August 9, 2010 Author Share Posted August 9, 2010 Both sets are fixed level outputs intended for devices that can record external sources. These are unsuitable to connect to an external amp. There are no pre-outs on this amp. thanks. as a follow up i have posted a thread on how to modify this receiver to have pre-outs/ pre outs. i have started a thread in the DIY section as that suits this project more http://www.stereo.net.au/forums/showthread.php/27043-Modifying-my-receiver-to-have-pre-out-pre-out?p=398473#post398473 anyone have any ideas? it would be best to post in my new thread though to help future people who would be searching these threads Link to comment Share on other sites More sharing options...
