EXPIRED: Active loudspeaker Kit
Recently Browsing 0 members
Similar Content
By Ericsoh
Item Condition: CD Player in excellent condition, some Blemish on Remote Contro Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Southern River State: WA Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: No Longer Required Further information:
Up for sale is a highly regarded Audio Research CD6/ DAC in black colour.
This is a top class CD player (with excellent standalone DAC) with 5 star rating in 'WHAT HI FI". There are currently very few CD6 for sale in second hand market in Australia.
The condition of the CD player itself is very good (like new - no skretch or mark - as far as i can see). Work flawlessly and sounds superb.
There is some blemish on the remote control but it works well without issue. And this has been relfected in the sales price. With the top condition to the CD player itself, i believe this might be one of the lowest price you can find in second hand market in Australia.
For your information, a replacement remote control (not metal anymore, but in plastic) is avaiable and can be ordered from Audio Research if one is fuss about the remote control. i have checked with the dealer, it cost $100 to get one to Australia (to WA)
It comes with original manual however i don't have the box. But i will have it very well and securely packed for shipping (insured). Further discount can be made to Perth buyer for local pick up (as no freight required)
PLEASE READ
If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you don't include photographs of the actual item being sold, your ad will not be approved You understand that a reasonable donation for selling fees is expected upon successful sale of your item
By elmura
Item Condition: New. Sealed in box. Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Oran Park State: NSW Payment Method: All payment methods. Paypal add 2.6%. Reason for selling: Excess
Strong™ Universal Fine Adjust Projector Mounts for big Projectors up to 23kg.
SM-PROJ-XL-BLK RRP $480 Price includes delivery. Or you can pickup and save $30
I ordered two of these so someone else can benefit from the best projector bracket on the market. I've fitted this to the Epson flagship in my home cinema and it is completely invisible. Highly recommended for premium home theatre.
The main benefits are the fine adjustment rotary knobs that lets you precisely locate your image without keystone or overscanning so you maximise your projected picture quality. Anyone who's installed a projector with a regular bracket will attest that it's painful and time consuming to get it perfect as the one screw usually locks all 3 axis at once. And, usually when you tighten the screw, it goes out of precise position. And often they're a bit wobbly which causes image shake with big bass hits.
With this bracket, you can finely adjust the distance from the screen (within a small range); horizontal position; vertical position; and yaw (rotation) - all individually. That's four separate adjustments available.
Additionally, it's made to handle big, heavy projectors and keep them rigidly positioned so you don't get subwoofer induced picture vibration. I fitted one with the big Epson 9300W and love it. Enough talk, below is the sales blurb.
______________________________________________________________________________________________________________________________________________________________________________________________________________________________________
Manufacturer's website link
Equipped with longer mounting arms and security screw holes, these projector mounts are specifically designed to handle oversized models up to 50 lbs., including JVC projectors, while offering maximum installation flexibility. They feature tool-less adjustments - so getting the ideal alignment is a breeze - and have a simple three-piece design that minimizes time spent at the top of the ladder. Also included is a plastic cover to keep the install looking neat and tidy.
Tool-Less Adjustments
Getting a projector image to perfectly align with a screen is easier said than done. Thankfully this mount simplifies the process with easy-to-use vertical tilt, horizontal roll and yaw adjustments. Just pop off the cover and use the tool-less dials to make micro adjustments until the ideal alignment is achieved - no tightening or loosening of the screws required.
Easy To Install
A smart three-piece design makes it easy to get this projector securely installed. The top plate attaches to the ceiling and screws into the mount assembly body, while the bottom plate (with attached projector) simply slides and locks into place. It makes installing the product fast and easy.
Security Screws
This mount features multiple security screws for projector attachment, as well as screws on each side of the mounting base - which all help to lock things in place. Move the mount around until you get the perfect center of gravity for the projector, then tighten down the screws and you’re good to go!
Mounting Flexibility
For the most versatility in your next installation, this projector mount features longer arms that extend for up to 17.7” diameter mounting. Plus it has a series of slots on the arms and the bottom plate that provide almost limitless placement options, so it’s easy to get the projector perfectly positioned. Need to install directly in concrete or ceiling drywall? Not a problem – just use the included hardware.
Extension Capability
If you want to drop the projector off the ceiling with an extension pole, we've included a separate ceiling plate to allow for easy connection to the pipe. Also included is a plastic cover to keep the install looking neat and tidy.
By franky995
Item Condition: Used Shipping Options: Shipping is available at agreed cost. Suburb or Town: Heatherton State: VIC Payment Method: Reason for selling: Further information:
Bought new from A2A. Just sold my Sony’s so no longer need the upgrade cable. Happy to supply invoice dated 20/10/20.
Excellent condition, hardly used.
PLEASE READ
By linnmaster
Item Condition: Very good condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: VIC Payment Method: Pickup - Cash, Bank deposit, wire transfer. Reason for selling: Selling collection of a friends's Further information:
Serial numbers 4917 & 4923
Ohm measure 4917 - 7.3 ohm
Ohm measure 4923 - 7.4 ohm
I have been told all diaphragms are all original. In excellent working condition as shown.
Attached as follows.
By ricky65
Item Condition: Used Shipping Options: Pickup available but audition is not available. Suburb or Town: Sydney State: NSW Payment Method: Cash / PayPal Reason for selling: Not used Further information: excellent condition tuner RDS model. This model was in excess of $1200 when released. Comes with remote.
PLEASE READ
