$40 Record Cleaning Machine at Aust.Post
5 minutes ago, Wimbo said:
Funny thing is, when I bought it, it never said anything about filling it up with water. Just apply fluid to the pads. I just use my old Dual for rotation, spray White cleaner first and use a directional brush when turning . After that I spray ironing water on and use another directional brush to spread that while turning. Works really well and no mess.
If you don't mind asking... how do you dry vinyl after spraying ironing water and applying another brushing?
  • Replies 77
Popular Posts
In my humble opinion the Post Office is actually selling this style of basic record cleaner for what they should sell for given how inexpensive these types of cleaners would be to manufacture. At
I read an article by Rigby about the best ways to clean. He claims records have a "special coating" on the vinyl and if you repeatedly use any iso alcohol it strips it and the record noticeably deteri
I cleaned a few records tonight and modified my procedure. Instead of the back and forth method suggested in the instructions I give it four rotations in one direction. It seems to be a upright versio
I am getting the feeling they copied Spin Clean but didn't manage to copy the instructions properly.
I just watched this youtube video about it.  It is exactly like the Spinclean, so I can't imagine why you wouldn't put water in it.
The spinclean instructions tell you to pour the fluid on the brushes.  Here's what they say.
Fill the SPIN-CLEAN® RECORD WASHER MKII with distilled water to the indicator line on the inner side-walls of the basin. You can use tap water if distilled water is not available.
Pour Washer Fluid MKII directly over the top of the inserted brushes in the wash basin - using the following amounts:
For MKII Record Washer Fluid: use three (3) capfuls from the 4 oz. bottle and one (1) capful from the 8 oz., 16 oz., and 32 oz. bottles.
For MK3 Record Washer Fluid, use one (1) capful from the 4 oz., 8 oz., 16 oz., and 32 oz. bottles.
The Spin-Clean Record Washer Fluid encapsulates the dirt extracted from the record grooves and forces it to the bottom of the basin, preventing it from being re-deposited onto the record. The bright yellow color of the SPIN-CLEAN® Record Washer MKII allows you to easily see the dirt collecting at the bottom when you are done cleaning your albums or singles.
Well, after rotating it in my Spinclean, I let the excess drip back into the machine, then I place the damp album between layers of a folded towel to absorb the free water, then I take it out, place it on top of the towel, and wipe it down with the cloths that are provided with the kit.  It comes up dry and shiny, ready to play.
This is a point missed by the Studebaker, because it is black.      I really do see the accumulation of dirt in the bottom of the trough.
The brushes I use are directional and they tends to dry as well.They also pick up the residue. What the ironing water does is dilutes and dissipates the white board cleaner. The record can be marginally wet at the end but this evaporates fairly quickly.
I did exactly what that guy did. I'm a dumbass. I think Crisis asked earlier if you put distilled water in it. And I think he did. For sure, you have to. My other way of cleaning works well though. The best way was with the Nitty Gritty 1.5FI that I had a couple of decades ago.
5 hours ago, Wimbo said:
I find it a pain in the ass to use. The roller want to come out and you have to put a lot of effort into turning it. This is just putting the fluid on the pads by the way.
It isn't the easiest thing to use.
5 hours ago, aussievintage said:
Don't you fill the trough with water as well?   That's how my spin clean works.  I imagine that, without any water, it WOULD be hard to turn.
I didn't. Not sure if I was supposed to.
4 hours ago, Spider27 said:
Do not recommend it. I got it yesterday to test and it cleans surface okay but does not clean inside groove at all. After cleaning, it still has as much surface noise as before.
It seemed to remove some of the things that were causing clicks and pops on my albums. I'm not sure how well it is supposed to work.
It has two cloths but I let mine dry as well after. That's why I would like a rack of some kind.
I don't apply the fluid the way he did. I lift one pad and lower it as I am squeezing the fluid onto it. Generally do that twice. The record comes out pretty damp after cleaning this way.
Nah I didn't. I did what they said to do. I am reasonably happy with it considering how much it costs. It cleans. I'm not sure how well in comparison to the legit versions though.
Well, given it is physically the same idea as a Spinclean, the difference is just the fluid.  You could buy a SpinClean refill next time and use it with water to see if it works better.
  • 3 months later...
So I need some more fluid for this and I don't think Aus Post are in the business of supporting this admittedly miserly purchase on my behalf. Any suggestions? Is distilled water an option?
14 hours ago, crisis said:
Just saw this on a TT manufacturer site. Does anyone use isopropyl alcohol on the records?...
There are many formulas for vinyl record-cleaning solutions on the internet.  Most are a combination of distilled water, isopropyl alcohol, and a wetting/agent or small amount of detergent.  The proportions in the formulas will vary.
Important:  NEVER use alcohol in cleaning solutions when cleaning 78rpm disks - the alcohol will dissolve the shellac!
On 06/07/2018 at 7:09 PM, Andrews_melb said:
@crisis i use this with my disco anti stat
https://www.melodymate.com.au/shop/product/15356/Melody-Mate-Premium-Vinyl-Record-Cleaner-Solution-1-Litre-BONUS-Microfiber-Cloth/
seems to work great, i just bought a 2ltr bottle of distilled water from bunnings as well
+1 for the Melody Mate. Have been using it in various ways over the last couple of years and I rate it highly. I also have a Disco Anti stat, which came with its own liquid. I turfed that after reading a few negative comments about it leaving residue in the grooves of the records after cleaning. The Melody Mate dries without residue.
The instructions say to vacuum. I was looking for something to use in the rotary cleaner I have?
I didnt notice that part @crisis but have used the cleaner for a few years now with good results. Poor records dont suddenly become mint again but it sure helps any clean up surface noise and other annoying things that can get on records after a while.
i just pour it in to the disco anti stat which is rotary as well - no vac.
then let it dry for a while then in new sleeves
Edited by Andrews_melb
Yeah, there seems to be Melody Mate for different machines now, from the simple hand cleaning bunnings paint square thingy (which I used to use) through the cheap rotary type (Disco Antistat, Spin Clean etc) through to the more expensive vacuum type machines.
Not sure what the inherent differences are in each product if any, but just choose one for your type of cleaner.
13 minutes ago, crisis said:
Anyone had any success with this in a similar machine?
I have a disco antistat unit as my main wet wash cleaner. I used the cleaning fluid it came with at first, but have used my own homemade fluid ever since.
I think everyone forgets The Disc Doctor Cleaning Fluid and special brushes. Dwayne is an industrial chemist and originally formulated this for cleaning shellac 78s. It's specifically formulated so as not to leach the binders from the vinyl. It was (and still is) recommended by Michael Fremer. There's a lot of copy-cat product on the market nowadays but this stuff is the best, been around for 20 years and his system is quick and simple. One brush for the cleaning fluid and the second for the distilled water wash. I've got a Pristine Vinyl VIVAC RC2 but I still use the Disc Doc fluid and brushes for the cleaning and rinsing. I have purchased from the USA but decibelhifi.com.au sell it all at the same price.
@crisis
before there were readily available the "Spinclean" and this latest incarnation, my first foray into serious record cleaning and what opened my ears to the benefits of cleaning my records was purchase of the "Disco Antistat" kit including a bottle of the fluid to which you refer.
It provided a significant increase in SQ, however, I quickly noticed that post cleaning I had a white waxy deposit on the stylus for several plays post cleaning.  This was more than 10 years ago, I still have the  remainder of the fluid.  I then developed a manual cleaning regime using the "Disc Doctor" brushes and fluids and the Disco as a rinse bath post scrubbing filled with distilled water and then air dried on the Disco drying rack.  This system, while rather labour intensive was most effective in improving SQ.  I have since been able to afford a vacuum RCM but continue to use the excellent and very durable Disc Doctor brushes for scrubbing, but have changed to Melody mate cleaning solution which to my hearing provides audibly superior results to many other fluids tried including KM, Art du Son and Disc Doctor.
I very quickly learned that good cleaning provided sonic benefits far exceeding its cost and adding to the benefits of cartridge upgrades, turntable upgrades and better phono stages.  I have for many years now always cleaned even new records prior to play and replace all paper sleeves with new antistatic sleeves.
Rudolf Bruils Soundfountain website is an excellent resource for record cleaning information and the London Jazz Collector site also has cleaning fluid recipes.
Decibel Hi Fi have an excellent starter kit from the Disc Doctor which will provide more benefit than a new cartridge of similar cost.
Edited by ophool
  • Like 3
Just one small (but important) point to consider for anyone new to using the Disc Doctor brushes. The brushes aren't used for 'scrubbing' the record surface as this implies putting downward force and that the brush bristles are running along the grooves dislodging dirt. The Disc Doc brushes are super fine 'hairs' that simply 'agitate' the fluid in the groove; it's the fluid dislodging the grunge, not the brush. So it's the lightest of touches as the brush rests and moves against the LP surface, going back and forth around a third of the record surface at a time.
Also, for anyone new to cleaning LPs, there are two types of stuff you're actually removing. The first is on used LPs. All those years of spilt party beer, dirt, dust, grease from fingers, and living mould (mould loves living in dark, humid record grooves feeding on cellulose from paper sleeve dust).
And the second is for NEW LPs. In the manufacturing process the record stamper machines have a thin coating of mould-release agent applied so the just-pressed LP drops cleanly out of the mould not leaving tiny bits of vinyl stuck to the metal.  So your new sealed LP has a sticky manufacturing residue coating all the grooves that is going to attract and hold any dust that falls on it.
It makes good sense to clean the new LP before playing it for the first time. As the stylus tip moves over the surface of the groove it's point-loading is massive and the heat generated actually melts the vinyl for a moment. Any grunge in the groove is actually going to be baked into the surface as the vinyl cools and reforms.
Another issue with used LPs from the 70s/80s was because of the cost of vinyl increasing as the price of oil rose, some manufacturers would recycle unsold LPs. Unfortunately the paper label wouldn't be removed and the LPs pressed using this second-hand vinyl would have microscopic bits of paper sticking up out of the groove surface. This explained a lot of the clicks and pops of new records at the time. Tragically a lot of modern pressed vinyl is churned out from overworked pressing-plants with no quality control. Unscrupulous people churning out cheap LPs made badly and from CD digital files. Websites like the stevehoffman and vinylengine forums and user reviews at acousticsounds.com are invaluable to read to research what purchasers have found with new releases.
LPs are a physical medium that has been around for decades and will be around after we're long gone. A properly cleaned LP that is played with an unworn stylus at the correct weight loading will last forever, well for a long, long time. Even used LPs that have some minor wear in the grooves from playing with older era styluses can sound fresh when played with modern stylus profile shapes that trace deeper in the groove, touching vinyl that was never touched by the more conical shaped tips of yesteryear.
There's a natural resistance at the thought of having to clean records when all we want to do is play them but once you've done a few and got your system rhythm worked out it's easy to do 3 - 5 at a time and not find it a tiresome task. Without doubt, the effort you put in will preserve that expensive vinyl for you, your kids and even their kids. What a great legacy to pass on.
On 23/07/2018 at 11:21 AM, stevoz said:
I read an article by Rigby about the best ways to clean. He claims records have a "special coating" on the vinyl and if you repeatedly use any iso alcohol it strips it and the record noticeably deteriorates. Someone challenged his claim about a special coating and he backpedaled a bit. He also said he used concentrations of alcohol nobody would normally use and cleaned a few times over. I'm calling bullshit. I have a mate who has been selling chemicals for ages and he said that iso doesn't damage plastic. I am going to try a mixture of demineralised water and iso in the cleaner and see how it goes. It may be a bit miserly of me but I hate the feeling of getting stiffed by companies who are pretty much selling this same thing in a pretty bottle. FWIW I've used a Discwasher for 30 years or so and my old records are pretty good. At the time there were plenty of naysayers claiming that solution would damage records. I don't think its as an effective cleaner but it certainly hasn't damaged the records themselves.
On with the show!
  • Like 5
  • 8 months later...
Regarding The Studebaker cleaning system I happen to have two of them; one was a gift and the other I bought from Australia Post on sale $29.99 (if memory serves). The first thing I would like to add to the discussion is that the units vary considerably regarding how they operate. With the first unit, I found it was quite difficult to turn the record and the rubber ring in the centre of the rollers would distort and move due to the pressure required to turn the LP, this problem did not occur with the second unit and the rubber rings in the rollers remained secure.
In addition, I found it best to allow the cleaning fluid to soak into the brushes before putting them into the grooves/guides in the 'washer basin', as the microfibers seem to repel the fluid at first. I apply a few drops of the Cleaning fluid and then using the top of the bottle, I gently rub the Cleaning pads working the fluid into them, continuing until the pads are thoroughly wet. I then place the pads together, microfibre sides together and matching orientation and then slide them into the grooves/guides in the basin.
I tend to clean a number of records at a time because it takes a bit to set things up and I want to make a good job of it. Also it takes a little time for washed records to dry. I also have a number of fluff free microfibre (advertised as microfibre but I don't know) towels of various sizes and clothes of the spectacle cleaning variety.
My record cleaning procedure involves removing any visible detritus from each LP prior to cleaning and then using one unit to wash the records with cleaning solution on the pads and then the other to rinse off the cleaning solution using demineralised water, filling the unit up to the spindle of the rollers. I have labelled the two units so I always know which one is for cleaning and which for rinsing.
After rinsing I lay the LPs out on the towels, then using another smaller microfibre towel, I remove any excess moisture, turning and repeating the process and then after a few minutes I place them in new sleeves (inner and outer) and I put them into my record collection.
I can't say there is much science to my process and I am always looking for some improvements that I might make, but my method seems logical to me.
Finally I believe the Studebaker system is value for money, the Spinclean system costs 3 times as much and more. However I haven't used a Spinclean unit and so I cannot compare results between the two.
from Mr Base Man
  • Thanks 1
As to buying cleaning fluid,   I have decided the Spinclean fluid does a good job and actually is not expensive.  At a capful or two at a time, it lasts a long time for $29.  Biggest advantage is I can buy it locally.
pro-ject-spin-clean-washer-fluid-1_4c5f42d5-dd19-46f2-a53b-de9c0c8a0716_large.jpg?v=1503495991
  • 2 months later...
Thanks for the heads up.
I just walked up to the P.O. here in Kingston and grabbed the only one on the shelf. The staff didn't even know they sold them!
Jason.
3 hours ago, steve-rsa said:
These are on sale again - $20 at Auspost.
I just saw them in the catalogue so jumped online, saw free postage and ordered one.
On 25/07/2018 at 10:35 PM, crisis said:
... FWIW I've used a Discwasher for 30 years or so and my old records are pretty good. At the time there were plenty of naysayers claiming that solution would damage records. I don't think its as an effective cleaner but it certainly hasn't damaged the records themselves...
FYI here is the patent for the Discwasher cleaning fluid.  The formula is in the patent info.  https://patentimages.storage.googleapis.com/a2/ed/e2/f7e9c54b553ae7/US3951841.pdf
And a summary, from http://db.audioasylum.com/cgi/m.mpl?forum=vinyl&n=338394&highlight=discwasher+d4&session=
The cleaner basically contained an antifungal agent, a surfactant, one or two solvents to keep the surfactant soluble in water and assist in cleaning, and distilled water.
The Patent discussion indicates the following possibilities:
  1. The antifungal agent was sodium azide and probably ran between 0.0001% and 0.004% by weight.
  2. The surfactant was either Triton X-114 or Triton N-57 and probably used somewhere between 0.0003% and 0.025%. These surfactants start to become insoluble in water when the temperature reaches 70 - 75°F which is what makes them effective at cleaning oils/greases but can cause formula stability problems (separation into two layers) without the assistance of a cosolvent or other surfactant.
  3. The two possible solvents are propylene glycol and isopropyl alcohol (IPA). Propylene glycol is probably run between 0.001% and 0.2%. The patent suggests IPA is run anywhere from 0.01% up to 5%.
Since this cleaner can be thought of as being similar to a glass cleaner, the total solids level usually does not exceed 0.1% by weight (glass cleaners are prone to leaving visible streaking above this level). Thus, my best guess at the original D3 Discwasher solution is:
  • Sodium Azide = 0.004%
  • Surfactant (most likely Triton X-114) = 0.025%
  • Propylene Glycol = 0.01% to 0.075% (probably closer to the high end)
  • IPA = Won't hurt to run the full 5%
  • Distilled Water = quantity sufficient to add up to 100%
  • 1 month later...
On 17/11/2017 at 3:46 PM, Grumpy said:
Just got mine, thanks for the tip off @audiofeline
Well !  being the lazy old fart that I am, I just opened my Studebaker cleaner (as you can see by the above date, it's been awhile since I bought it ) and found that it is missing the cleaning fluid - Ripped off, but I'll use some demineralised water and some isopropyl fluid. - perhaps.
If anyone’s interested, I have been using Melody Mate fluid in my Disco Antistat (sortof same thing) and it works really well.
I get the big pourer of concentrate, and dilute by about 1/2 with distilled water.  My system involves a clean using this, and then I vacuum off the liquid with a Kuzma record vac machine.
Once I sort a shed, I’ll likely try the ultrasound setup peeps use on the foru s here....
  • 3 weeks later...
1 hour ago, Grumpy said:
So, what is the verdict re,  pouring distilled water in the tank of the STUDEBAKER - do we or don't we ?
Confused Grumpy.
When I was using it I just wetted the pads. I didn't fill the tank but now I have the Knosti I do fill the tank. If you are using your own blend I would suggest filling it but with the Knosti you get filters so you can re use the fluid and store it back in the bottle. Otherwise you will probably waste a bit.
Given that the cause of most dandruff is fungal............................just whack some Head and Shoulders in there!
    • By evil c
      Item Condition: Very good Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Glen Waverley State: Victoria Payment Method: Paypal, EFT, Cash on pick up. Reason for selling: NLR Further information:
      Knosti Record cleaning machine, fantastic unit and very good for restoring vinyl .
      Bought a few years ago from Audio Trends.
      Supplied with full 1Lt bottle of record cleaning liquid
      Not only is it remarkably good at cleaning your LPs but it's quick and easy to use and there's none of the noise and palaver associated with more elaborate alternatives. It's by far the cheapest wet cleaner on the market and to be frank, it's as effective as any other." Hi Fi Choice
      "The results were visually impressive. All visible finger marks and dirt had been removed leaving a satisfyingly glossy surface. Before and after playings proved that this system does a good job. Surface noise was drastically reduced and clarity improved to a surprising extent." Hi Fi News
      "We can't recommend this gadget too highly." AV Review
      Revive Your Vinyl Collection. Record Washing Machine. Helps Minimise Static. Removes Dirt & Dries Residue Free. Does Not Require Power. Easy To Use. Very Economical. Replacement 1 Litre Refills available. Made In Germany.
    • By grorr76
      Item: interested in any vacuum record cleaner
      Price Range: 4-500 tops
      Item Condition: New or Used
      Extra Info: any brand no preference automatic or manual
    • By Yardbird
      Item: Knosti Disco-Antistat
      Price: $30
      Item Condition: Used
      Purchased from another SNAer a few months ago and I never used it. Decided to go with an ultrasonic set up instead due to the volume of records that I have to clean.
      Does not have the drying rack as it never came with the system when I purchased it (missing rack show in pic three).
      Happy to post at buyers expense.
    • Guest
      By Guest
      I'm floating an idea here for like minding vinyl lovers. Not sure if its workable or not but here goes …….
      I had a set of records cleaned by the Audio Desk Systeme Vinyl Cleaner and the results were amazing. Better than any of my various routines before including vacuum machines.
      http://www.stereophile.com/content/audio-desk-systeme-vinyl-cleaner
      Now one of these machines would set you back 4K. I personally don’t have that kind of money. But, I am just wondering, would there be people out there that would possibly consider going 1/2 1/3 or 1/4? Again not sure how to work out the details of how this would work, but hey I'm putting the idea out there.
      Maybe someone else had done a share arrangement on other equipment and could share there experiences? Any thoughts, pitfalls advice appreciated!
      Cheers, Mark
    • By kylevuong19
      Item: Okki Nokki Record Cleaning machine MK2 (Black)
      Price: $500
      Item Condition: Mint
      Reason for selling: Not in use, need some fund
      Bought this a year ago and only used twice since then. I normally bought new vinyl so it's hardly use.
      Prefer local pickup but happy to ship if needed.
