Stephen Conners
Infocus Projector Repair Experience
Recently I acquired two Infocus projectors, one being the IN78 and the other In76. Both are approximately 11 years old, so parts are very scarce.
The IN78 had lost its red tones which means the colour wheel has faded and obviously requires replacing.
The IN76 had a big, black dot in the centre of the screen which usually means the DMD chip failed or the light magnifying lens is burnt or the light tunnel has collapsed.
Pulling apart the IN76 I discovered the light tunnel had indeed collapsed so i removed and cleaned the tunnel pieces and glued back together with QuickFix UltraRepair. It's flexible, high-temp glue suitable for glass and quick drying too. Put it in the fridge to give it more working time!
Well I switched it on in a still open state however the black dot remained.  Next step, remove all other parts just to get the Optical Engine out. Opening the Optical Engine revealed the culprit - an acrylic internal magnifying light lens which was burnt. I'll provide pictures below.  Well, I cannot obtain a new lens anywhere unless I find another In72/74/76/78.  So, now I've now come to the conclusion that the IN76 is for parts only now.  Hence, the colour wheel will be used in the IN78 which is better due to the DMD DarkChip3 technology.  What's more, I've now got spare bulbs and parts!  Hopefully this helps anyone else with their fault finding or repair.
That lens is seriously burnt! Good luck with the repairs to the IN78.
UPDATE:  The IN78 had previously been worked on by an amateur.  I discovered the colour wheel had been replaced with a cheap import which was so small it didn't even cover the hole and light tunnel.  Replacing it with the IN76 colour wheel worked a treat!  All working exceptionally well on my mid grey projection screen.  Now calibrating for two scenario's;  1 Ambient setting.  2 Pitch Dark room. Fortunately the IN78 has 3 Presets.
I will include some pictures when I'm done.
Hi Stephen I hope you can help me. I have an InFocus In72 overhead. It was working perfectly until we relocated the projector. When we plugged it in we heard a crackling sound and the power went off. We cannot get it working again. We have called practically every repair shop in Melbourne and no one can help us. Would you have any idea where we can get this looked at? Thank you for your time
Liz Walters
Liz Walters
If you're in Bayswater Vic, give JLS Electronics a call. However, I'd expect parts availability is going to be an issue nowadays.
    • By Silver Audiophile
      Item: Infocus IN81 HD DLP Projector.
      Price: $850 ONO
      Item Condition: Excellent.
      Reason for selling:NLR
      Extra Info: Excellent condition HD DLP Infocus IN81 Home Cinema Projector. Minimum use (500 hours on original bulb still), original owner. Comes with two remotes. Ready to ceiling mount or mount on flat surface. Very high contrast, eats all modern LCDs for breakfast in terms of colour and contrast. Local buyer welcome to audition projector in action before purchase.
