Bill125812
Reviews on my cheap Van Damme RCA & XLR interconnects
I thought I would start a thread on My Van Damme cables
I have made up quite a few now for members of SNA, and as I only charge what it takes me to make them up and free postage,  ( so at $50 for a 1m cable,  I’m not retiring from making these )  I would love some feedback from anyone who has had a set for a little while
Bill
Edited by Bill125812
Looking forward to receiving mine! Are these officially known as ‘Bill’s Cables’ btw?!
Yes.
This cable is perfect and you save a lot of money.
Ι'm  listening my new toy for about tow weeks now and i mean Van Damme interconnects,
I put your cables in an Valve intamb 2a3 3.5 Wat per channel, AVI cd player and Mission 782 a small monitor
From 2000.
I believe is more detailed and rich than my Nordost black and DNM reason which I hear this time.
Next week I test it in the system of my son: Nu-vista300 pre-power amp, Sonographe CDplayer and Cabasse speakers.
Bill is a top bloke to deal with. Got a pair of RCA not long ago, still going through the burning stage. My first impressions are that these are cheap in price but not in the sound it offers which is on the rich and warm.
Good stuff.
Are you using the VD mic cable Bill?
I had a roll of it ages ago to make up some mic leads and used the leftover for IC's.
I thought it was great.
Not using the Standard mic cable.      All the IC’s are also soldered with silver solder and double heat shrink over the solder   Then techflex.    Lots of insulation
I've used the Vandamme XKE instrument cable as diy interconnects before. Which model cable are you using Bill?
Xke professional
Hi Bill, are your RCA's shielded?
Edited by kelossus
Van Damme Pro Grade Classic XKE Instrument Cable is a relatively low capacitance unbalanced audio cable for use with unbalanced output devices. Its tight construction and dual screens of conductive thermoplastic and close lapped copper spiral ensure noise free handling and excellent noise rejection
Does that mean it is good for Phono cables? I am after a pair from my tonearm to phonostage.
Yes mate.   I was using a commercial cable which did cause a little hum.   Tried everything to fix the issue.   Made up one of my cables and the hum was gone.
Ive replaced all my expensive cables with my own. Some rca. Some xlr.
I'm using it for Phono pre to passive pre and from there to my Monobloks. I find it very neutral and clean.
I'm using for phono had them for a couple of weeks now find them neutral clean and low noise, fantastic value.
bill made a long interconnect for me.
compared to canare L2T2s and mogami 2893 it is more neutral and never got in the way of the music.
for the price give it a go.
Thanks for the cables Bill. I have used them for a few days and they are an absolute bargain for the price. As good as cables priced at a few hundred dollars. Great through the entire range. No harshness, while still remaining neutral.
Thanks again.
I received Bill’s cables last week.  They’re very well constructed, soft and flexible, which is exactly what I was after. Bill made me 4 sets, which covers my whole system. They replace 3 sets of NVA Sound Cord and 1 set of a Belden/Nuetrik (which runs from Phono to Pre). I've only listened to DAC and CDP so far, so comparison applies to the NVA cables. Right off the bat, they're amazing! The soundstage has increased not in width, but depth; therefore instruments are better positioned, separated, and easier to follow. There's more detail, or the perception of more detail, due to this separation/definition. Complex passages are also easier to listen to. Transients are definitely more pronounced and defined, while at the same time being easier on the ears. Overall the cables seem more neutral, and less harsh or coloured. This is after brief listening, to a few albums only! I’ll post my thoughts again in a week or two.
Hi Bill,
Any chance you could make me another pair of your RCA cables?  1M would do.
CD player is going well- just have to find a more permanent arrangement for it!
No rush.
Tim
Edited by Tim D
29 minutes ago, Tim D said:
Hi Bill,
No rush.
Tim
Hi Tim
sure mate.
Just pm me please
Any reason you didn't use the XKE Pro Patch cable which has a twisted pair plus braided shielding or the XKE Star Quad?  Both are superior Van Damme cables, and don't cost much more.
@gmdb neither of those cable you mentioned are coaxial which I imagine constitutes a large part of its goodness.
Edited by PicoWattson
Well the proof is in the pudding as they say, the XKE Pro Patch cable Geoff is suggesting works very well!
Edit: I haven't used the Star Quad but know some that rate it highly also. But Van Damme make quality stuff and no doubt the instrument cable is good also, but for low level like a phono cable I'd prefer both signal and return both shielded. I actually use a coax on line level but a solid core silver clad copper center conductor.
Edited by Noum
Hi Geoff
As Picco Wattson mentioned, I prefer the coax cable.   I have tried both your suggestions, and to me the coax seems to produce a better sound teamed with the AMPHENOL RCA’s.     I suppose it’s all a question of personnel preference.
