Baldrick35
Centre Speaker - set to large or small?
Hi all,
I have a Marantz SR5009 receiver running a set of Arron speaker - ATS-5s at the front, SS-120 rears and CC-120 centre. The receiver asks you to set the speakers to either 'large' or 'small', which I gather is pretty much what they all do these days. I've got the fronts as large, the rears as small.
Question is - what's the best option for the CC-120 centre? Doesn't exactly seem small to me, but neither would I expect it to be large? There's a set of specs here if that helps - https://www.avconcept.com.au/av-concepts-products-toowoomba/for-the-home/speakers/other-speakers/aaron-cc120/
And I guess I'm curious about whether there's a general rule to follow for this setting? How do you decide what's large and what's small?
Thanks for your tips!
Cam
Always set Mains, Centre and Rears to "SMALL"
This should ensure that bass management in your AVR will send signals 80HZ and below to your subwoofer.
EVERYTHING will sound clearly better to you this way.
If you don't have a sub???...........GET ONE!!!!!!!!!!!
(and rerun Audyssey Room EQ!!!!)
Edited by JohnL
OR TWO!!!!!!!!!
Hmmmm, it seems you've immediately spotted part of my dilema - no sub :) I've resisted the sub as I always feel it's a bit unneccesary when the fronts and cente do a decent amount of bass, particularly in a smallish room. But maybe I need to revisit this idea.
That said, I see you're suggesting small for the Mains (fronts?) - I thought it was normal to set these to large if you've got decent sized floor standing speakers?
Thanks for your thouhts!
If you have no sub then set mains to large and center to large or if you want center bass to go to mains set center to small.
My high end Mains have 9 inch bass drivers
STILL sound better as "small"
Don't make the mistake of equating regular stereo practices to HT....................different fish
Trust me............adding a minimum 10" sub (or 2) will totally transform your entire HT experience.
Edited by JohnL
Righto, seems I need to do some investigating then! Thanks for your help John!
set all to large.
the least amount of bass management the better !
if wanting to stick with aarons, look out for their subs they made which were pretty decent for the money. do tend to come up 2nd hand now and then too.
check this out only $110 !
I know 709 only quotes pick up only. but might be convinced to ship :D  and still be a massive bargain !
I agree with the previous posts, get a sub ASAP. As the CC-120 only has 5" woofers I'd suggest setting the Centre and Surrounds as Small with an 80hz crossover. The larger ATS5's should be ok run as Large till a sub turns up
think you will find 709 replaced the 120 sub with 2x 240 subs. as you do not indicate room size i will guess is a medium size ie 5mx4m? the aaron 120 sub should be used in a pair.. you also dont indicate the avr used as to if it can actually set up 2 subs (not just an internal y splitter with 2 sub outs)
i had the ats5 fronts and yes if you have no sub now you can try them as "large" with the centre as "small". yes bass is non directional and setting at 80hz is right but placement is also important. i tried the ats5 without a sub (i also had the bigger 240 centre) and in my room it was rubbish. if you watch movies get 2 subs.. 10" will do but 12" is the sweet spot.
Guest VladimirFreddie
FWIW My main speakers measure down to 20hz (-2db)in room and I still have them set to small and crossed over @ 80hz for movies.  I have two subs.
There is more slam, headroom, sounds more live & no doubt has less distortion when using the subs.
Edited by VladimirFreddie
Then you will need to set your speakers to large.
For other situations, what to do depends heavily on the details - and there is no universal answer like many suggest....   and it can get quite complicated.
As mentioned it depends on your room size and sub settup as too whether you set the ats5s to large or small Baldrick . If no sub set to large as the ats5's dual woofers manage 28hz- 28khz which is considerably better than thx's 80hz ;
your cc manages 65hz-23khz so small is ok as mentioned . When you get a sub or 2 you can take some of the stress of your L/R's midrange and bass drivers and let the sub handle that as well as low pass redirected frequencies from your cc and surround speakers :)
http://www.aaronhifi.com.au/Post-2008-Product-Listing.pdf
    • By CMAN
      Item: GoldenEar SuperSat Satellite Centre Speakers 3C
      Price: $300
      Item Condition: Used, in great working and cosmetic condition
      Reason for selling: To upgrade
      Payment Method: Pickup - Cash
      Extra Info: Purchased brand new from a high end stereo retailer
      Current RRP: $595 on https://www.theaudiotailor.com.au/products/golden-ear-super-sat-3c-satellite-centre-speaker
    • By Polish_Bear
      Item: Focal Chorus CC700V Centre Speaker
      Price: $400
      Item Condition: Very good
      Reason for selling: No longer required
      Payment Method: Pickup preferred as don't have original packaging. - Cash, Paypal, COD Only
      Extra Info: I'm the first owner from new. This centre was my first venture into surround sound and it has served me well. I've since changed from Focal to the Polk Audio LSIM series for my front channels so no longer require this centre.
      As per photos, only issue is the veneer peeling in one place after I left it in a sunny spot in the spare room after disconnecting it.
      Sound wise, plays as new.
    • By Rolland
      Item: Krix Graphix Mk2 centre speaker
      Price: $400 includes shipping Australia wide
      Item Condition: as new
      Reason for selling: upgraded
      Payment Method: Pickup - Cash, PayPal.
      Very good centre channel, it's in as new condition sitting in box, selling due to upgrade. Still has 4 1/2 years on the Krix warranty with the original receipt.
      Price is including shipping Australia wide.
    • By Audio Connection
      Item: DALI OPTICON VOKAL centre speaker in black ex display condition
      Price: $725.00
      Item Condition: Ex display condition
      Reason for selling: Clearance
      Payment Method: Pickup - COD, Credit card on pick up, Direct deposit
      Extra Info: Can freight at extra cost
      Also the component that handles the bulk of the direct front action, choosing an effective centre loudspeaker is essential to the whole home cinema experience. This is why we designed the VOKAL to be a fool-proof hit in any home, both in terms of performance and physicality.
      Firstly, armed with our sublime 6½ inch low-loss Wood Fibre Woofer, Hybrid Tweeter module and front-pointing bass port, you can be assured that the action on the screen in front of you is seamlessly soundtracked, with deftly handled detail drawing you deeper in. Perfect with any of the compact speakers in the series, but at the same time powerful enough to match just about any set of speakers.
      Secondly, with an eye on practicality, the OPTICON VOKAL has also been designed to fit most makes of Hi-Fi furniture due to the front facing bass ports, meaning it can be neatly stowed away – a plus point for aesthetically minded home owners and home cinema custom installers alike. But it will work just as well out in the open.
