ArneS
Cheap Isolation fix - Vast Improvement
Just as an experiment I cut some small squares of the more porous Whites blocks, these come in 100mm x 100mm x 12.5mm, the air spaces are larger than in the other 50mm x 50mm squares, can get 4 small squares from each uncut square.
https://www.bunnings.com.au/whites-on-site-100-x-12-5mm-rubber-anti-vibration-mat-4-pack_p3961547
They seem to work slightly better for me, and it seems logical to me at least with the larger air pockets/spaces.
I think @Spukee in that other thread used the large mats of this more porous type when he isolated his speakers.
On 07/02/2020 at 8:53 PM, gwurb said:
What foam would support the weight of 15kg+ without collapsing?
What would be an example of springs being used under speakers?
Q.1 Ethafoam (open cell foamed polyethylene)
Q.2
Thong supports up to 80Kg each foot. So 15Kg is no problem. Take a walk along xxxxx beach (insert your favourite bit of Oz coast) and pick up thong, cut into 35 x 35mm square. Voila, no money has left your pocket and, just as thong isolates you from sharp gravel, bindies and Scholl wearing socialist pariah, it can do the same under your favourite bit of music making audio.
My ML-1's are 12 kilo each at least, maybe slightly more, and as can be seen they are sitting on boards held above the stands top plate with 4 each 3cm x 3cm squares of that porous anti vibration stuff from bunnings. The full size squares are 10cm x 10cm and are sold to be placed under washing machines.
Edited by muon*
Oh no, I got the 50mm pack! Didn’t realise it was different density to the 100mm blocks. 🙄
But then I was only looking to increase the height of the speakers.😉
Really pleased with SQ outcome, but now wondering whether it would be even better with the less dense 100mm block.🤔
Would have worked out cheaper too, after cutting into 50mm!🤣
Edited by vivianbl
Yeah, big savings :lol:
It's subtle, but I think still there in my situation.
When I've had rubber thongs (footwear), by the time they wear out they have permanent compression indentations where it has held the weight from my feet.  In the short-term, there would be no difference.  Longer term use I would expect compression.
An alternative that is porous and cheap.  Go to your local pharmacy and buy Heroes for the removal of corns and callouses.
http://www.heros-int.com/sponge-en.html
John
On 15/02/2020 at 6:31 PM, lemarquis said:
I now have the pads under the feet of all components sitting on the butcher's blocks and under the small bamboo board on top of the speaker stands as you and @Soundscape have done. One thing I did notice was that the pads are not all cut to exactly the same height so a spirit measure is essential to align them correctly. Maybe they will settle down with a bit of time (break in? :D )
Will have a listen over the weekend and report back.
Hi, I would suggest trying a different approach. The top of the stand and the bamboo board look too small to provide adequate stability for the speaker. IMO you would be better off making some boards that are the same dimensions as the speaker boxes, and fix them firmly to the top of the stands, with screws or countersunk bolts and nuts (or blutack). Then place the isolation pads at each corner, directly under the speakers. This will give much better stability, make it much easier to level the speakers and the isolation factor will be improved as well. The boards will also help to dampen the top plates of the speaker stands, a crude but useful constrained layer construction. Even better if you add a thin layer of rubber or similar sandwiched between the board and the top of the stand, which will improve the damping factor.
Edited by Soundscape
Hi and thanks for the tip. The photo may look deceptive as the speakers are rock solid on the stands (they weigh 15kg ) but your suggestion makes sense so will give that  approach a try :thumb:
Bunnings also have the anti vibration product in a thin layer roll 4mm thick, or pads 3mm thick.
https://www.bunnings.com.au/whites-90-x-60-x-3mm-rubber-leveling-pad-60-pack_p3961981
https://www.bunnings.com.au/whites-100mm-x-1m-anti-vibration-pad_p3961983
OK. The results are in after a weekend of testing the little black magic squares..
I put them under the amp, cdp dac and speakers. All had bamboo butcher's block in place already.  I placed these under the feet of the gear sitting on the blocks. It was going to be a challenge to say which thing led to any improvement as I did it all at once but here goes..
First thing I noticed was that the dac didn't like it. Lost a bit of focus. This may be because the dac is quite small and light or a different implementation may be required. So I removed them.
Next on to some CD sessions. (As background the Halcro was NOS and came without feet so I had it on some big sturdy round plastic bottle tops. This was, in retrospect, a prime candidate for some improvement. )
Wow! Where is that WEIGHT coming from? The orchestra is massive. Is it boom or bloom? Is it going to mess with the lower midrange? Answer was No. After extensive listening to several familiar classical works (piano concertos) I lost nothing but gained enormous weight and authority. Now for some Year of the Cat. Great album with plenty of nice analog instruments and very very familiar territory to these ears. Again, WOW! The bass notes (bass guitar or drums) are so tight you feel them. Yes not just hear but actually feel (I'm not talking massive drum solos just nice tuneful playing). Detail? You hear people say they heard things they never heard before? Well I've played this album hundreds and hundreds of times and yes, I heard new things. Like under a guitar solo there's another little thing going on. Notes I'd heard before but now I know what they're saying (micro dynamics, lower noise floor?). Instruments like acoustic guitar had more body and resonance.  Background orchestral pieces had more cohesion and clarity in the mix. Just great. I recently tweaked the Halcro with an audio mat that took it to another level (well worth it even at $300). Now with the $4 black magic I got an almost equivalent improvement.
Back to the Dac for some DSD sessions. Again just awesome weight, scale, clarity and authority. Hard to say but I think the amplifier has a lot to do with this.  Maybe the speakers too.  But the cdp has definitely moved up another level with the blocks under it.
As the man used to say... "Do yourself a favour.." :thumb:
So this is where I'm up to currently, glued the blocks of tungsten together using locktite 406, sandwiched between 16mm mdf using gorilla glue and have roughly filled the gaps using automotive bog. The blocks sit on 3x 50mm bunnings isolation pads, and I've used bluetack between the speaker and the blocks, I feel the bass is punchier, and clearer, the unit they sit on has less vibration to it too. Still a fair amount of work left in them but very happy so far, as far as the weight goes they're up around the 15kg mark.
Hi, the whites squares (brand name) from Bunnings do work very well. I kind of discovered them independently , but great to see this thread that many others are enjoying. I never thought of putting under electronics but will give it a go.
For light components, the earthquake protection gel squares from Daiso work a treat.  If you trim the plastic sheet bit don’t remove it, then they won’t stick to the component.  With these under the bamboo board below my TT, it is less prone to skipping from footfalls  than anything else I have tried so far.  I also like the sound.
    • By NoCoder
      Hi All,
      Revisiting the vinyl scene after many years away and have started out with a Pioneer LP30 turntable and I already had a Yamaha HTR-6130 receiver. Down the track  I would like to upgrade eveything, but my budget will not allow that for a fair while.
      I would like to add better speakers than the ones that came with the receiver and was looking at a few bookshelf speaker options. I have seen a few Edifier model and also a Pioneer SP-BS22-LR Bookshelf Speaker. I only have up to $300 to spend.
      I know nothing will blow me away with my current set up and budget, but it's a start to listen to what I have.
      Does anyone have any suggestions?
    • By Tobiwan
      Item Condition: Very Good Used Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: Taylors lakes State: Victoria Payment Method: paypal, EFT, cash on pick up Reason for selling: upgraded Further information:
      I am selling my old Chrono series floor standers and center ~ 6 years old very well looked after.
      I think it's a bargain of a price
      Pair of Canton Chrono 509.2 DC floor stand speakers
      Canton Chrono 505CM Centre Channel Speaker
    • By viper87
      Item Condition: Used - all drivers work perfectly but there is cosmetic damage. Shipping Options: Pickup is available Suburb or Town: Camden State: New South Wales Payment Method: Cash Reason for selling: They've been collecting dust for too long. Hi,
      I've had these beauties tested and all drivers are functioning perfectly, they sound incredible.
      Matching serial numbers as indicated in the photos and they also come with a stand for each speaker. There is some cosmetic damage so please refer to the photos.
      Local pick up in Sydney region. I don't have an amp, i had them tested at a hifi store so you'll need to byo if you want to test, my appologies.
      They were left to me from a family member who has passed away, I know theres someone out there who will appreciate them.
      Edit: I'm no longer accepting PayPal I'm only accepting cash, my apologies to anyone wishing to use this service but there are too many scammers. Still happy to prove they're fully functional to those who are serious about the purchase.
      Edit 2: I'd also like to mention that I've included the speaker stands in the purchase price to offset the cosmetic damage. I know their valuable and I believe that's a fair trade.
    • By ViVa
      Having tried a couple of couriers in the past with limited success. I need another pair of speakers (total 70kgs) moved from Melbourne to Sydney.
      Recent quotes from e-go (cheapest $), Pack & Send ($$$), Smart Send ($$$),  Interparcel (via TNT - road were affordable) - any other recommendations?
      So far, only PackSend and Smart Send offer Insurance of amounts over 2k.
    • By Judep
      Item Condition: used Shipping Options: Pickup is available,Audition is not available, but in-person pickup can be arranged with limited personal contact Suburb or Town: TALLEBUDGERA VALLEY State: Queensland Payment Method: Paypal, Cash on Pickup Reason for selling: Clearing out the spare room For sale:
      2x Meridian 5500 DSP Loud Speakers.
      Bundled with an old studio sale 5 years ago, these have never left the spare room.
      They have not been tested as they require a DSP main unit to operate which is not included in the sale. I have powered them up and the LED's go on.
      There is some broken glass on the name plate on one of the speakers. Some paint chips on the timber but nothing obscene. Photo's included.
      I'm assuming this is a fair price for these speakers.
      dsp5500-digital-active-loudspeaker-datasheet.pdf
