ArneS
Cheap Isolation fix - Vast Improvement
If you raise any speaker of the floor or surface and use a stand, it's going to sound less boomy.  You can hear that difference even on an iPad speaker
Oh well.. Looks like I'm going to Bunnings tomorrow
I have cut these into quarters to replace the rubber or plastic feet under the electronics.  I feel they would be much better than plastic or rubber which has hardened over time.
I do note that these squares are promoted for use with heavy equipment that has obvious vibrations (eg. washing machine), the anti-vibration may be less effective for lighter loads (electronics).  Still, at this price there is virtually nothing to loose from experimenting with them.
Yeah, the smaller ones are of greater density in structure compared to the 100mm x 100mm ones.
Let us know how they turn out mate
Quote
They turned out well.  I used a 10mm spade drill bit to create a recess for the bolt/washer.
A full-size one can be used with four bolts securing them to the chassis.
Edited by audiofeline
On 10/26/2017 at 4:38 PM, Grumpy said:
Just got back from Bunnigs with 2 packs of the 100 x 100 pads .
Put 3 under my TT and am going to cut the spare into 4 for my preamp.
Question : - l have my rack sitting on carpet over the old wooden floorboards, no spikes. Would these pads help if l put them under the rack?
Well a brief listen to a few favourite tracks today with the pads under my TT and preamp was a little strang.
First thing that had me a little stunned (l wasnt expecting to hear much change straight away) was what l thought was a slight lack of bass - could it be that the bass was presented more cleanly, with less mudiness?
Also, even more noticeable was the higher frequencies which seem to reach higher and cleaner with seperation that im sure l dont usually hear.   l put that down as a result of the bass being cleand up.
l dont usually believe a lot of these reports of cheap and easy tweeks that CAN improve the listening experiece, but these little pads sure have done something to my setup
Under the Rock, seems to make the sound a bit lighter, but then again the PHO-8 is still running in too.
Under the Luxman, have not tried it yet.
The rock does sound dark
@Grumpy
It's a little confusing at first isn't it, I have to work out a similar thing when i placed bamboo boards under my speaker stands, the bass  seemed to disappear at first! but it was just that the muddiness was gone.
Edited by Noum
Oops typos
Bass is still there, the PHO tightened that up.
Been reading this thread with great interest. But I am a little confused.
I have floorstanders on carpet (with a garage underneath).
Should I be putting my speakers on spikes or bamboo or those isolations pads from bunnings?
If my question does not belong here then I apologise.
I'm in a carpeted unit with garage under concrete slab, I found best result to my ears was spiking the stands of my ML-1's and placing them on bamboo boards. At first there seemed a noticeable reduction in bass, but it was in fact that the bass had become more accurate, at least this is to my ears.
Floorstanders are akin to standmounts on stands the way I see things.
Not an expensive path to try either.
I only use the anti-vibration stuff under component platforms, in my case bamboo again, and under the feet of my equipment rack.
Works for me anyway.
Try both and see which sounds best to your ears with your system.  It's the only sure fire way of knowing which will sound better.  Both tweaks are so cheap you've got very little to lose by experimenting.
On ‎26‎/‎10‎/‎2017 at 5:16 PM, Batty said:
Went to Bunnings myself for some Vermiculite, found these in my trolley......
Going under the vintage Wharfedales.
Have they helped your sound?
Too many variables to tell, just swapped cart, phono and these slipped into the system.
They do however protect the surfaces my gear sits on :)
On 10/28/2017 at 1:15 AM, Grumpy said:
...l dont usually believe a lot of these reports of cheap and easy tweeks that CAN improve the listening experiece, but these little pads sure have done something to my setup
Cheap and easy tweaks can fall into two areas:
1.  Cheap and easy tweaks that actually work (for most people, they are dependent on the equipment and setup you have)
2.  Cheap and easy tweaks that don't work and are just designed as an elaborate prank by some to demonstrate how gullible audiophiles are.
My preferred version is the first.  In many cases it's easy to see which version you are dealing with.  At other times it can be difficult to differentiate the two varieties without trying, with the risk of egg on your face.
This is why I try to make only one change at a time, all too often I have made too many changes at once to really understand what each has brought to the table.
Although I do like that they protect the carpet with the ones under the threaded rods in my rack :cool:
The spikes stop the speaker boxes from moving on a soft surface in response to the movement of the drivers (Newton's Third Law).
Isolation pads stop the promulgation of speaker box vibration to the floor and from floor to speaker box.
Both may be of use.
On 23/10/2017 at 12:52 PM, ArneS said:
...I might have been satisfied with my AVR’s sound had I just isolated everything in the first place and went from there. And though I’m happy I have that power amp, I think I’d have been happier setting things right up in the first place.
Out of respect to the store that sold me the gear in the first place, I want to note that after running the system post isolation of speakers and components- but without the power amp, I'm most definitely not happy with the sound with the avr on its own. It does movies and tv rather sweetly but true two channel hifi just isn't its forte. The power amp lifts things into a new dimension- as it should I suppose.
Edited by ArneS
Well blow me down with with a feather.  Just tried this little "hack" and it has made a difference.
I put the small blocks under amp, DAC and CD player. Everything just seems a little tighter and more defined.
I have to say thanks to ArneS. What a difference!
I have wooden floorboards and a tt on a sideboard. On my travels today I decided to stop at Bunnings on my way home and see if any improvement could be made. The first was to try the tt, which was hard to tell if the sound had tightened up, so I continued next to the speakers. Wow what a difference, the bass was tighter and the highs were more defined, but I was also hearing some sort of distortion on the highs, like it was over defined. It just didn't sound right, so I thought I might lower the VTA on the tonearm as I knew I had it slightly raised and what do you know the distortion disappeared.
The only thing I can think of is that I had the VTA slightly higher to compensate for the bass sounding slightly boomy when it was lower. The sound quality by using the vibration pads has made a very noticeable improvement, especially on wooden floors. Without a doubt great bang for buck improvement, will continue and try other components and see how that goes.:)
Pleased to hear you gents have had some wins. To me it was really easy to hear the improvement. For those with racks and speaker spikes already, I'm not sure how helpful doing this sort of tweak will be - but if like me all you were doing was sitting your speakers on the floor, and components directly on shelves - it's a cheap way to get some big improvements.  No brainer.
Both may be of use.
If using both solution, then there might be a need to add another solid substrate between spikes and anti-vibration pads. Possibly an inert stone or wood.
    • By gypr1961
      Item: Avantgarde Zero 1 XD Active Speakers DSP
      Price: $18,000
      Item Condition: Mint
      Reason for selling: Time for a change
      These are the top of the line model, above the pro model and come with DSP, digital and an analogue (A/D card) for turntables etc.
      They are incredibly dynamic! They sound just as good when theyre shaking the house or playing whisper quiet.
      I have all original packing
      As im going to need a complete new system Im happy to look at trades + cash
      Specs can be found here https://www.avantgarde-acoustic.de/en/products/zero-serie/zero-1-xd.html
    • By Yardbird
      Item: Trevor Lees Floor standing speakers
      Price: $150
      Item Condition: Used
      Reason for selling: suit someone with better skills than me
      Extra Info: bought these off another member in poor condition both the cabinets and drivers. They cost a heap more than what I'm now selling for. I have since spent many hours and money getting these going again including a restore on the cabinets themselves.
      I have replaced all the foam surrounds, dust caps around the drivers and inspected the crossovers and resecured etc. Got the speakers working again but I then broke on wire to the voice coil of one of the drivers (check photo) so I'm over these now.
      An easy fix for someone with the ability. Or a new replacement drive is about $120 local which makes these still crazy cheap. Cabinets are good in condition and this is a quick fix to get a Proac sound.
      No grills.
    • By olegau
      Item: HiFi stereo system
      Price: 1200
      Item Condition: very good
      Reason for selling: too many stereo systems
      Carefully selected Hi-Fi stereo system. All in good condition and working order.
      Separated sale:
      1. ROTEL RA-980BX Integrated Amplifier $390
      The amp was checked and serviced recently.
      It has OP amp sockets, DIYer could change the OP amps to get different sound. Open the the top cover and then change the OP-Amp you like.
      There are three pairs of Ops: original AD712 (vintage sift sound, JRC4558 (modern  more clean and detailed sound) and LM4562 (bit more detaied). Currently installed LM4562. Many other OP-Amp suits for this amp..
      Dimensions: 440 x 121 x 347mm
      Weight: 10.1kg
      Example:
      2. Speakers: Ascension Woodfox Ribbon 822SRTL Bookshelf Speakers. $890
      Dimentions: 500 H, 270mm W and 315mm Depth. Weight is approximately 18kg each. High quality woofer using an Papyrus cone, ribbon tweeter, Rose Mahogany Veneer.
      Two years old.
      Power 120W
      8 ohms
      Sensitivity 91db
      3.  Sold.  Subwoofer: Infinity Primus PS-8 $170
      See spec attached
    • By Midget
      Item: ELAC FS 247 Floorstanding Speakers
      Location: Terrigal Central Coast NSW (Will ship Australia wide)
      Price: $2400 $1985 + Shipping (includes $20 donation)
      Item Condition: Used. Smoke, pet, child free owner. Very minor micro abrasions on top surface and minor fading to fabric grill, excellent condition.
      Reason for selling: Downsized to a smaller apartment
      Extra Info: Each box is 110x40x30cm with a weight of 20.2kg, Made in Germany
      System type 2.5-way Enclosure type Bass-reflex Frequency response ± 3dB 30 - 50000 Hz Nominal impedance 4 Ohm Amplifier Requirements 30 - 250 W Sensitivity (2.83V/1m) 89 dB Tweeter JET III Woofer 2 x 150 mm (6 in.) AS-XR cone Dimensions (H x W x D) 1022 x 170 x 270 mm / 40.24 x 6.69 x 10.63 in. Weight 17,8 kg / 37.4 lbs.
    • By ajricho
      Item: Richter Wizard Mk II speakers
      Price: $190 negotiable
      Item Condition: Good. Tweeter and mid-range drivers replaced-details below
      Reason for selling: These were my parents speakers-selling on their behalf. They have moved into a retirement home and no room for them. Unfortunately also too big for my house
      Payment Method: PayPal, Cash - Pickup
      Extra Info: As mentioned, these were my parents speakers - they bought from new in 1996. They had problems with them in the early years of ownership, with the tweeter and mid-range drivers replaced on each by Richter under warranty. The original drivers may not have been available as they are different. The tweeter in each is a Vifa TC20TD05-06. Mid-range in each is a Vifa P17WJ-00-08. The Woofers weren't replaced and still original Audax HT170G2. The speakers are fully functional and the cabinets and covers are in very good original condition
