ArneS
Cheap Isolation fix - Vast Improvement
I am a fan of rubber, or more appropriately viscoelastic urethane polymer you probably know better as sorbothane. It usually comes in 50 or 80 durometer hardness and both have their vices and virtues. Natural rubber going by the name of Linatex is another that I have toyed with over the decades again in the 50-80 duro range. Not for under speakers but under electrical components, and not every component will benefit. My Yamaha SD2000 CD player refuses to play ball at with rubber,
all the different types do nothing but loosen the grip on the music and narrow the soundstage. I think if you try to couple/decouple the outside of the chassis of any electrical component as much attention needs to be deployed to the internal construction and its subsequent damping.
Many brands of quality racks use sorbethane for shelf isolation. SGR to name only one.
Edited by PicoWattson
A quick check on the net shows that the manufacturer of the base product of sorbithane state that the weight that the material supports is of great consequence to it's ability to absorb vibration. It ain't just one size fits all, and a hit and miss approach can cause as much degradation as improvement.
The thing I like about the Bunnings pads is that they are made of shredded rubber aligned in a similar manner to particle board. The idea of having small pieces with dead ends throughout is to stop the vibration from continuing at each dead end. In theory this would have to be one of the best designs of vibration dampening regardless of frequency range. In practice one would have to try for themselves, but it definitely has merit.
Max Townshend thought Sorbothane was good enough to use on the Rock II.
It does however collapse over time, I changed it originals about 2 years ago, they had dropped by about 4mm in 29 years, when replaced the SQ was much better, just hadn't noticed the gradual decline.
I have the IKEA Butchers Block under TTs and Sorbothane pieces under just about everything .
There is no Bunnings around here.  Do you have the Bunnings product name , or link to it or something so I can point my brother toward it ?
(He has a Bunnings close enough).
Thanks.
Thanks.
There are these:
 https://www.bunnings.com.au/whites-on-site-100-x-12-5mm-rubber-anti-vibration-mat-4-pack_p3961547
however I have also been using smaller ones found in the same section. They are about 3.5 cms square. Pack of 8 for under 5$. https://www.bunnings.com.au/whites-50-x-50-x-12mm-anti-vibration-squares-8-pack_p3961977
Edited by ArneS
17 hours ago, Sime said:
How long ago was the purchase made in a Hi-Fi from a woman in Canberra?
A while ago now.
14 minutes ago, ArneS said:
There are these:
thanks.  Wow that really does look 'cost effective'.
And the results are way better than doing nothing at all.
Different densities.
I used a mix of the 50 x 50's and 100 x 100's in a friends system. But used only the 100 x 100 type density for places in my system. I bought a big sheet of it ages ago and cut it up to different sizes, worked out much cheaper than the small packs of squares.
Do you mean this as the "big sheet"?
https://www.bunnings.com.au/swing-slide-climb-grey-play-equipment-rubber-paver_p3321288
https://www.bunnings.com.au/swing-slide-climb-1-x-1m-20mm-thick-paver-play-equipment-rubber-shockpad_p3321609
1 hour ago, enikoy said:
No, it was sold as an anti vibration product just like the small small squares are, and was identical in composition as in the 100 x 100 ones. I grabbed one on clearance a couple of years ago for $10
Saw those and no, this was about 1m x 1.2m anti-vibration mat. 12mm thick.
You can see I have a piece cut to si9ze under the 50mm think bamboo the CD player is on, and I have one in my hand that I cut for under my stands before I spiked them and placed them on a thinner bamboo board instead.
20170711_191558.jpg.694999fa5c4496b8f446f64b953d1fcc.jpg20171026_154537.jpg.cdd8142ca21aecdc8f9e14affe9d8e45.jpg
5 hours ago, ArneS said:
There are these:
Just got back from Bunnigs with 2 packs of the 100 x 100 pads .
Put 3 under my TT and am going to cut the spare into 4 for my preamp.
Question : - l have my rack sitting on carpet over the old wooden floorboards, no spikes. Would these pads help if l put them under the rack?
I would think so, Grumpy.
Under the rack feet that is, I have squares under the feet of my non-flexy flexy rack, also protects the carpet from the threaded rod ends :)
Went to Bunnings myself for some Vermiculite, found these in my trolley......
Going under the vintage Wharfedales.
25 minutes ago, Noum said:
Wow!
I hope the 'B' people don't see this thread :lol:
What would we do without IKEA and Bunnings hacks!
Guest Sime
@Noum this is those stands being compared to something similar to what’s been discussed here, only a production version of the bunnings equivalent.
Edited by Sime
Yes I can see that and am well aware of both products, Simon. The Auralex are a bit different as they are of a different composition of materials. Both are more costly too....
Just saying ;)
Edited by Noum
Typo
    • By gypr1961
      Item: Avantgarde Zero 1 XD Active Speakers DSP
      Price: $18,000
      Item Condition: Mint
      Reason for selling: Time for a change
      These are the top of the line model, above the pro model and come with DSP, digital and an analogue (A/D card) for turntables etc.
      They are incredibly dynamic! They sound just as good when theyre shaking the house or playing whisper quiet.
      I have all original packing
      As im going to need a complete new system Im happy to look at trades + cash
      Specs can be found here https://www.avantgarde-acoustic.de/en/products/zero-serie/zero-1-xd.html
    • By Yardbird
      Item: Trevor Lees Floor standing speakers
      Price: $150
      Item Condition: Used
      Reason for selling: suit someone with better skills than me
      Extra Info: bought these off another member in poor condition both the cabinets and drivers. They cost a heap more than what I'm now selling for. I have since spent many hours and money getting these going again including a restore on the cabinets themselves.
      I have replaced all the foam surrounds, dust caps around the drivers and inspected the crossovers and resecured etc. Got the speakers working again but I then broke on wire to the voice coil of one of the drivers (check photo) so I'm over these now.
      An easy fix for someone with the ability. Or a new replacement drive is about $120 local which makes these still crazy cheap. Cabinets are good in condition and this is a quick fix to get a Proac sound.
      No grills.
    • By olegau
      Item: HiFi stereo system
      Price: 1200
      Item Condition: very good
      Reason for selling: too many stereo systems
      Carefully selected Hi-Fi stereo system. All in good condition and working order.
      Separated sale:
      1. ROTEL RA-980BX Integrated Amplifier $390
      The amp was checked and serviced recently.
      It has OP amp sockets, DIYer could change the OP amps to get different sound. Open the the top cover and then change the OP-Amp you like.
      There are three pairs of Ops: original AD712 (vintage sift sound, JRC4558 (modern  more clean and detailed sound) and LM4562 (bit more detaied). Currently installed LM4562. Many other OP-Amp suits for this amp..
      Dimensions: 440 x 121 x 347mm
      Weight: 10.1kg
      Example:
      2. Speakers: Ascension Woodfox Ribbon 822SRTL Bookshelf Speakers. $890
      Dimentions: 500 H, 270mm W and 315mm Depth. Weight is approximately 18kg each. High quality woofer using an Papyrus cone, ribbon tweeter, Rose Mahogany Veneer.
      Two years old.
      Power 120W
      8 ohms
      Sensitivity 91db
      3.  Sold.  Subwoofer: Infinity Primus PS-8 $170
      See spec attached
    • By Midget
      Item: ELAC FS 247 Floorstanding Speakers
      Location: Terrigal Central Coast NSW (Will ship Australia wide)
      Price: $2400 $1985 + Shipping (includes $20 donation)
      Item Condition: Used. Smoke, pet, child free owner. Very minor micro abrasions on top surface and minor fading to fabric grill, excellent condition.
      Reason for selling: Downsized to a smaller apartment
      Extra Info: Each box is 110x40x30cm with a weight of 20.2kg, Made in Germany
      System type 2.5-way Enclosure type Bass-reflex Frequency response ± 3dB 30 - 50000 Hz Nominal impedance 4 Ohm Amplifier Requirements 30 - 250 W Sensitivity (2.83V/1m) 89 dB Tweeter JET III Woofer 2 x 150 mm (6 in.) AS-XR cone Dimensions (H x W x D) 1022 x 170 x 270 mm / 40.24 x 6.69 x 10.63 in. Weight 17,8 kg / 37.4 lbs.
    • By ajricho
      Item: Richter Wizard Mk II speakers
      Price: $190 negotiable
      Item Condition: Good. Tweeter and mid-range drivers replaced-details below
      Reason for selling: These were my parents speakers-selling on their behalf. They have moved into a retirement home and no room for them. Unfortunately also too big for my house
      Payment Method: PayPal, Cash - Pickup
      Extra Info: As mentioned, these were my parents speakers - they bought from new in 1996. They had problems with them in the early years of ownership, with the tweeter and mid-range drivers replaced on each by Richter under warranty. The original drivers may not have been available as they are different. The tweeter in each is a Vifa TC20TD05-06. Mid-range in each is a Vifa P17WJ-00-08. The Woofers weren't replaced and still original Audax HT170G2. The speakers are fully functional and the cabinets and covers are in very good original condition
