kai41314
WTB: Single-ended Tube Monoblock under $500
Item: Single-ended Tube Monoblock
Price Range: $500
Item Condition: Used
Extra Info: Let me know if you have one for sale.
Edited by kai41314
you missed a 0 there right?
Yes I would have to agree!
On 05/10/2017 at 4:53 PM, kai41314 said:
Price Range: $500
2 minutes ago, peterears1 said:
Would sell at around $2500
Confusing ???
Maybe. I just remember when I started my SET journey ,  I found the entry point higher than the OP suggested. And these were my first step into the SET world...with 300bs. No harm done I hope.  ☺
    • By hakiu
      Price: $3800 Item Condition: Used Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Belmont State: Queensland Payment Method: Cash on Pick up , EFT Reason for selling: Upgraded to boulder 1060
      I got original wooden crates , so its possible to ship interstates.  However, given its weight ( net: 16kg each , gross: more than 20kg each), would highly prefer local pick up.   Comes with 4 extra 6AS7G tubes
      A pair of rarely offered Audio Valve Baldur 70 "Baby Baldurs" monoblocks for sale. RRP was $12500.00 when purchased. The 300 big brother is currently $34000. They are both outstanding amplifiers. Typical review.....These 70W tubed monoblocks are very well made and pleasant to look at. The Baldurs possess all the strengths associated with tubes, but also have an extended, airy top end. Overall, the Baldur 70s are very musical sounding, and for USD $9000/pair provide good performance, especially for their power range.....  Very good condition with a few minor marks. Operationally perfect.
      For further info and review see: http://www.audiovalv...ve baldur70.php
      During the CES show in   Las Vegas 2003, the need for a smaller version of Baldur 200+ became apparent. Size and price were main cause for the search for an alternative consumers entrance into the ‘world of BALDURS’ !
      Thus said and done, AudioValve can offer you, as shown in the accompanying illustrations, the final developments and esthetics of BALDUR 70 (“baby-baldurâ€). World premier performance was at the ‘High-End-Show’ in Frankfurt-Germany, Summer of 2003.
      Like in all AudioValve’s  larger model power-amps, our proven fully automatic bias regulator –short ABR- at the powertubes, also appears here in the power stages of BALDUR 70. This is  world wide unique and this feature is a ‘must’ for relevant tasks to stabilize the bias of the power valves and actually belongs standard into 21fst century  tube-technology   - at least with AudioValve ! -
      Safety, reliability and durability are synonym for our tubeamps for over a decade! Apart from the high reliability of the outputstage, the ‘baby-Baldur’ unites further interesting, typical AudioValve’s refinements on the part of the concept. As for the powertubes, BALDUR 70 utilizes only four 6AS7G’s / ch. where BALDUR 200-plus uses eight 6AS7G’s per channel. (And in doing so, it’s the only world-wide power stage, using 8 tubes coupling a clean 150Watts power-output to a dampingsfactor of 100!!)
      The baby-Baldur cannot compete completely with the extreme standard of Baldur 200, but gives a real run for its money, and makes a quiet worthy and certainly more inexpensive entrance possible to a true triode Poweramp. And with this masterpiece one immediately recognizes the incomparable quality of a correct trimmed set of 6AS7G’s !! (75W/ch)
      But what makes this outputstage something special? It is the sum of all consistently architected thoughts and accomplished development-steps. All electronics of the BALDUR 70 are on one enormous printed circuit board accommodated   -a masterpiece of a special kind-  evenly typically AudioValve, with the advantage that all the production models of whichever AudioValve model is exactly like its reference sample! In contrast to “hardwired†components , where the outcome varies with the construction technician…, as to often, unfortunately, the case is.  With free wiring one amplifier is hardly like the other.
      But that is certainly not the only reason for this one PCB; dynamic interrelations can settle in between elements in context of the total construction. Only the use of a well thought out and calculated printed circuit board, will stabilize these conditions.
      If using the power triode 6AS7G, first tried in 1982 in the original Baldur 100, there are a number of demands to meet before  this tube will perform to its maximum ability. For one there has to be a stable electrical environment to sustain this highly demanding tube if you expect maximum musicality during its entire lifetime.
      The intricacies  and traps with the 6AS7G are too many to perform this task without an automated bias circuit and simply cannot be done without AudioValve’s  ABR! Besides that will ABR forces all tubes effectively in a “common modeâ€, fundamental for any multiple tube design.
      Traditionally this task is performed with a screwdriver, to adjust the biascurrent, but that is only momentarily, if at all. Even selected tubes cannot hold there promise in the long term, because tubes run their own life, and a matched pair or quad will be matched only for so long!!
      The ABR of the BALDUR 70 will regulate each of the two triodes in one glass bulb and so on with the other tubes. All together the 6AS7 G is still protected by reversible devices. Whenever you see this tube in use, accompanied with only half a dozen components around this tube,skepticism will  be your best advisor.
      If you should have to change a powertube in the BALDUR 70, the respectively related ABR circuit will indicate so, and you exchange only that one to another, for ex. a new one. BALDUR 70 is more or less indestructible, even if you shortcircuit the output, or inadvertently, leave it running without load. That, by the way, applies to all our amps!
      BALDUR 70 reaches with a dampingfactor of 20 not the dream-value of its big brother, nevertheless in comparison with its competition it plays absolutely in the upper league; while generally dampingfactor of tubeamplifiers is not their strongest feature.
      In particular OTL designs with a damping factor of 1 or 2 will make you believe that they’re wonderfully musical. Well, maybe in exceptional cases, certainly not generally, simply because without control over the speaker from the amp, there is no such thing as musicality!
      The damping realized in BALDUR 70 means strong, clean, dry, thumpy and sharply outlined bass; accompanied of the soundstage and velvet high’s only known from real triodes.
      BALDUR 70 will not only drive ‘tube-friendly’ speakers, a wide range of dynamic speakers are well within the limits of its power; even magnetostatic speakers can easily be driven! Thereby, the BALDUR 70 will drive excellently a multiplicity of usual loudspeakers.
      Naturally BALDUR 70 has also a driver stage before output stage. AudioValve hasn’t let that pass unnoticed! It consists of four (!) double triodes/ch, responsible for tension-amplification and current-amplification, splitting of the complementary wave to feed the parallel-mirror-symmetrical coupling to powertubes.
      Filament voltage as well as plate voltage of the driver section are stabilized, and provide a solid, rock steady operation conditions. The r0emaining characteristics of BALDUR 70 resemble otherwise those of BALDUR 200-plus.
    • By zakblue
      Item Condition: Very Good Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Balwyn State: Victoria Payment Method: Cash, Paypal, EFT, BTC/ETH Reason for selling: No Longer Required Further information:
      75W per channel. About 220-240hrs on current Mullard EL34 tubes.
      Amp was serviced locally by Hifi Exchange and tubes replaced.
      I have the old tubes that I can pass to buyer.
    • By timelord9
      Price: $1150 Item Condition: Used - Excellent Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Melbourne State: Victoria Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Raising capital for domestic transducer development. Further information:
      Purchased 2nd hand last year, this amp has seen very little use. I have the original box, and am happy to post Aust-wide. The amp is in perfect working order and buyers can demo with my Focals. Pick up from Thornbury or Abbotsford.
      Specs:
      Frequency Response: 20 Hz - 20 kHz +/- 0.5 dB, 20 Hz - 50 kHz +/-2 dB Nominal Output Power RMS / 8 Ohm: 2 x 150 Watt Nominal Output Power RMS / 4 Ohm: 2 x 250 Watt Nominal Output Power Class A / 8 Ohm: 2 x 10 Watt Harmonic Distortion: < 0.1 % (1 kHz, 1 Watt) Input Sensitivity: 300 mV Signal-Noise Ratio: > 90 dB Input Impedance: 47 kOhm Inputs: 4 x Stereo RCA, 1 USB Outputs: 1 x Stereo RCA Pre Out, 1 x Stereo RCA Rec Out, 4 x 2 Speaker Terminal, 2 x 3.5 mm Jack (Power Control) Tubes: 1 x 12AX7; 2 x 6N1P-EV Colour: Black  Weight: 20.4 kg Dimensions (WxHxD): 430 x 152 x 435 mm
      Comes with remote.
      Note: This is the original SV237. The link below is with the updated digital input.
      https://www.vincent-tac.de/en/product-lines/tubeline/sv-237mk.html
    • By zakblue
      Price: $1300 Item Condition: Very Good Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Balwyn State: Victoria Payment Method: Cash, Paypal, EFT Reason for selling: No Longer Required Further information:
      Relist as I had to turn a couple of potential buyers away due to not being able to in-person audition. I don't have boxes for these so interstate postage is not possible.
      75W per channel. About 220-240hrs on the Mullard EL34 tubes.
