Snoopy8
GIESELER Groß DAC Review
44 minutes ago, MattyW said:
Might try one between my pre and power amp, though in no rush.
Be careful between the pre and power - it screwed up the balance of my system, was too much of a good thing. But my pre and power amp are from the same designer/manufacturer. I found it very effective between source components and my pre.
I'm guessing if the pre/power amps are from the same manufacturer then chances are they are already matched, so might actually be beneficial if your pre/power amps are from different manufacturers.
Thats my guess...
On 17/01/2019 at 9:44 PM, Max Headroom said:
Its not about the exact quality of the copper in the cable, but impedance balancing which has a far more significant impact
Thanks for the heads up Max. Unfortunately they appear to be out of stock and removed from the Burson website.
On another front, picked up a Gross with Kraftwerk PSU today and will be giving it a spin tonight :)
Good pickup.  You will be in for a very pleasant surprise when comparing it with the Klein II. 😀
Looking forward to that. I was happy with the Klein II, maybe holding out for a Fein II but the price was too good to refuse. The previous owner upgraded to a Dac in the $US 6K territory... ;)
Will report back with my impressions.
Just some quick impressions after a few hours with the Groß and the Kraftwerk PSU which replaced the Klein II dac.
I won't reach for the audiophile thesaurus here so I'll be as brief and to the point as I can. Right from the start you know you are in the presence of a fine dac. When I replaced the Klein I with the Klein II, I felt the same sonic signature (Gieseler house sound?) was there, but just bigger and better in every department.
Going from the Klein II to the Groß + Kraftwerk was a similar experience but..... magnified by 10. Soundstage just deeper (listening to some Classical choral works is amazing as the voices shift and weave across the soundstage left to right, up and down, in and out). Bass even at very low levels, (like a note from the back of the orchestra) very tuneful and controlled and just there like it wasn't before. Probably helped by the lower noise floor of the unit + the Kraftwerk. Overall the sound is just luscious and liquid in a way that doesn't sacrifice dynamics or detail. Two words also come to mind: weight and authority. I could go on..
This is only after a few hours but having lived with the Klein I and II dacs I know there is more to come and this time, much more! In answer to someone's query as to how specifically the Groß is an upgrade from the Klein II, I would say specifically : in every department you care to name. and the difference is not subtle.
I'll close by saying that in my experience Clay's dacs give you an entry into the world of serious HiFi. You start to understand what great gear is capable of. Each upgrade removes another veil and gets you closer to the Nirvana that, more than just putting a smile on your face, is like a revelation after years of listening to gear that is just very good.
The Groß tells you that you have made another huge leap and if the rest of your gear is up to it, you may well rest on that part of the mountain for quite some time :)
Edited by lemarquis
I agree that what you bought was a steal.  And thank you for the writeup.  So, why didn't you upgrade earlier?   😜 😁 🤣
Full RRP for the Groß and Kraftwerk was a bit out of budget after springing for the Eos Reference. :popcorn:
On 15/07/2019 at 6:09 PM, Thelastjedi said:
Would you say any one of geiseler dacs offer a smooth and warm sound?
Seems mike that’s their house sound. But don’t confuses that with not being dynamic and punchy, with astounding bass depth and reach.
You can rest on that mountain for quite some time. To spend more doesn’t necessarily bring improvement, and if you spend a lot more your system has to be seriously good to be able to take advantage of the improvements. Enjoy!
23 minutes ago, obitankenobi said:
Anyone have experience with the Gieseler DAC vs the Auralic Vega and can share their experience?
Closest is this
Konverter was released before the Groß DAC...
On 12/03/2018 at 12:10 PM, Snoopy8 said:
I did an unusual compare yesterday. Not against another 2 channel DAC but a multi channel AVR.
The MRX -1120 came close to the Groß in a limited test and I could easily live with the 1120.
What that exercise did was also to highlight once again why I love the Groß. DSD superb, sound stage so wide that it almost replaced the rear channels of a multi channel recording. :wub:
 What we did not do was compare16/44.1 non classical music. The Groß does CD quality PCM so well and has this ethereal quality that is addictive (that word again!). Time and time again, I have difficulty stopping and want to listen to the next song. It is this quality that sets the Groß apart. :thumb:
I recently acquired the last Gross dac unit from Clay before the product was discontinued. It has Clay's Gold Tune Kraftwerk built-in.  One of the reasons I bought the Dac was to explore the Hi resolution Pcm musics as well as Dsd format.
After a month of listening I think the Dac has finally burnt in. That said, listening to DSDfiles hasn't drawn me in yet, despite the level of details the format produces is much better than that of the Red Book (I compared two versions of Diana Krall The Look of Love). Perhaps my current source (an old Hp i7 laptop, Windows8) and Foobar to feed the files to the Gross Dac are not up to the task. In a separate thread I am seeking advice how to improve this (weak) link within my limited budger.
That said, listening to Red Book files has never been better. Indeed I have started to question myself whether I need to listen to Hires and Dsd formats?
One thing I know for sure: Mr Gieseler has made a mistake by discontinuing the production of this great dac. Are you sure that the Fein 2 is better?
Chu
Glad you like the Gross and it was a steal buying the last one. 👍
2 of us compared the Fein II with the Gross and found it to be slightly better.  See Fein II reviews:
Worse still, the Fein II was cheaper than Gross + Gold Tune PSU. Clay made the mistake of pricing the Fein II too cheap!  Many of us have told him that his DACs pricing was too low, but he refused to listen. 😂  So, everyone gets incredible value for money DACs which can compete with the big boys costing a lot more.
Happy listening...
On 17/01/2019 at 3:40 PM, Max Headroom said:
...Guys get a pair of Burson Audio Cable+ Pro cables. They will bring the Gieseler DACS up an amazing level when they're matched with the Gieseler Kraftwerk Power Supply.
...yes I've got good gear, great speakers and expensive interconnects...
Thankyou, thankyou, thankyou!!
I've just received a Burson Audio Cable+ Pro cable and I'm initially trying it between a humble Rega A2D phono stage for my Dual CD503-2 turntable, into a Naim NAC32.5 pre-amp. The difference it makes is pretty amazing.
Next I used it between my Gold Tune enhanced Kraftwerked Klein III DAC and the 32.5. Note: The Kraftwerk made a dramatic further enhancement to my already high satisfaction with the Klein III in my system.
A favourite discovery on Tidal is this
‘Joni 75: A Joni Mitchell Birthday Celebration (Live)
TIDAL.COM
TIDAL is the first global music streaming service with high fidelity sound, hi-def video quality, along with expertly curated playlists and original content —...
The Burson cables enabled me to hear gently-brushed cymbals at the end of the Brandi Carlile rendition of ‘Down to You’, and everything else I listened to was also enhanced above the very high baseline noted earlier. I’ve managed to buy another set just now from a US eBayer but everywhere else seems sold out.
This Sara K track starts with Russian dialogue on a street busy with traffic; again, the extra atmosphere revealed by these cables is striking:
TIDAL.COM
Listen to 4atahyta 4y-4y (Russian dialogue) on TIDAL
Ever since I’ve had my Klein my fitness has been in decline...as a retiree I spent far too many hrs on my a** revelling in the amazing music I can stream from Tidal or my own 16/44 FLACs.
Edited by lenticularis
Christmas competition:
Who can construct a Limerick incorporating the following:
Ever since I’ve had my Klein my fitness has been in decline "
my fitness has been in decline          It’s just like when I went from Bose
to joining SNA and finding Gros
35 minutes ago, lenticularis said:
That’s gold, Henry
Thanks! I can’t go past a Limerick..
hopefully there are better ones ‘waiting in the wings’!
my fitness is in decline,
It really makes my system shine
...exercise and I just don't align!
Improved!
Warning, ownership of a Klein may force one to break out in a rhyme.
Not always of course,
just from time to time.
Actually mine's a GroB, but close enough.
There once was a man who bought a DAC,
He proudly placed in in his hi fi rack,
But since owning the Klein,
With His fitness in decline,
He now resembles a 300 pound burlap  potato sack.
    • By MJJW
      Item: Audiolab - MDAC
      Price: $450 Neg.
      Item Condition: Excellent
      Reason for selling: Replaced with another DAC
      Payment Method: Pickup - Cash, Paypal, COD Only, Can Post at buyers Expense
      The DAC was purchased new and is in Excellent Condition selling as I have replaced with another DAC. Also, functions as a relatively good headphone Amp.
      I cant seem to locate the Remote Control, but I have on good authority (I’ve checked the compatibility on Logitech site) that any of the Logitech Remotes will interface with the unit, although I’ve never really used it myself as I have always used the unit as a Fixed Output Level mode, and used the Integrated AMP to control the volume etc.
      Specifications:
      DAC:
      ESS Sabre32 9018 chip
      Resolution:
      32 bits
      Maximum Sampling Frequency: 84.672MHz
      Digital input:
      2 x 24-bit/192kHz coaxial, 2 x 24-bit/96kHz Toslink optical, 1 x 24-bit/96kHz USB
      Digital output:
      1 x coaxial, 1 x Toslink optical
      Output voltage:
      RCA: 2.25V RMS,XLR: 4.5V RMS
      Total Harmonic Distortion:
      RCA: <0.002%, XLR: <0.0008%
      Frequency response:
      20Hz - 20kHz (± 0.2dB)
      Dynamic range:
      RCA: >115dB, XLR: >122dB
      Crosstalk:
      RCA: <-120dB, XLR: <-130dB
      Dimensions (H x W x D)    59 x 250 x252mm
      Colour   Black
      Standard accessories        power cord, user manual
    • By wanta911
      Item: Metrum Acoustics Pavane (level 1)
      Price: $3500
      Reason for selling: Too many DACs
      Preference will be given to local sale as I prefer buyers to know exactly what they are purchasing and have the opportunity to test. If no interest locally, I will post at cost.
      I am the original owner. Bought in February 2016 from Addicted to Audio. The DAC is in excellent condition and has been a wonderful mainstay in my setup. One of the RCA outputs will turn with some light pressure but it has been like that from day one and does not affect playback. Local buyers are welcome to inspect & test, just send me a private message. I am tied up most Sundays until 2:00pm but available after that as well as Monday to Friday evenings and Saturdays.
      Please be patient if sending a message, I do not live at my computer desk.
    • By zakblue
      Item: Emotiva XDA-1 DAC/Digital Preamp
      Price: $250
      Reason for selling: NLR
      Payment Method: Pickup - Cash, Paypal, Bank Transfer
      Happy to ship Australia wide at buyers expense.
    • By AlurkA
      Item: Accuphase DAC-50 Option Board
      Price: $700 ONO (RRP $1500)
      Item Condition: Perfect, used it for a few months in my E-470.
      Reason for selling: Have since moved on to separates and sold the E-470
      Payment Method: Cash, Paypal, COD Only
      Extra Info: A plug an play option board for a number of Pre and Integrated Amps in the Accuphase line-up.
      Features and Compatible Accuphase products:   http://www.accuphase.com/model/dac-50.html
    • By 8thdegree
      Item: BENCHMARK DAC3 HGC + SoundAffairs Linear PSU & Mods
      Price: $4350 $3990
      Item Condition: Excellent (being conservative, see note below*)
      Reason for selling: Have gone 'ethernet'...
      BENCHMARK DAC3 HGC. Black version. James Soh SoundAffairs external AC to DC Linear PSU and mods—Ultima Femto Clock, Ultima Voltage Regulator, etc. Have had the unit since March 2019 (bought new). Including retail for the unit (A$3700), the price of the PSU and mods (A$2200), double-freight and import duties via Singapore (A$600), overall retail price is ~A$6500. Reason for selling is that I am moving in a different direction with my sources & DAC, to networked audio over ethernet. This unit is USB-based. DAC comes with original remote.  *Some might say the unit is "as new" given that the little nicks on the PSU were there when it shipped to me! However, since it's been modded I suppose technically the Benchmark unit itself is definitely not "as new". PAYMENT VIA PAYPAL ONLY.   Well, if you're interested in this listing you probably have done your research already. This listing is not for just the highly sought-after Benchmark DAC3 HGC—as if that weren't enough—but for that unit extensively modded by James Soh of SoundAffairs in Singapore, including his all-important custom Linear DC PSU:      Benchmark DAC2 family modification
      WWW.MYSOUNDAFFAIRS.COM For customer reviews, please click here Change the simple oscillator circuit that is used for the ESS9018 Sabre DAC with our Ultima FEMTO low jitter clock then replaced the critical...     Even in its BASE retail form, the Benchmark DAC3 HGC is on a number of high-profile current 'best of' lists, including Stereophile's Recommended Components in its highest "A+" designation:    Recommended Components: 2019 Edition Digital Processors | Stereophile.com
      WWW.STEREOPHILE.COM Digital Processors Editor's Note: The sound of any particular CD transport/digital processor combination will be dependent on the datalink used-see "Bits is Bits?" by Christopher Dunn and...     Quite some cost, logistics and waiting times in orchestrating this combo I can tell you...here's your chance to leverage my expended effort and get hold of this setup, ALMOST NEW, with NO WAIT TIME, and at a STEEP DISCOUNT.
      ESTIMATED DELIVERY COSTS AROUND $120 INSURED. THE ACTUAL COST MAY DEPEND ON DELIVERY LOCATION. PICKUP IN SYDNEY POSSIBLE TO AVOID THIS, SUBJECT TO PAYMENT BEING SECURED AHEAD OF TIME (PAYPAL ONLY).
      Photos: See extensive pics. The small nicks are visible on the PSU pics.
