STAIN0 Posted October 2, 2017 Share Posted October 2, 2017 (edited) feel free to give this a go My lux to lumens calculator First page calculates your 16:9 image sq.ft. Just input either your 16:9 image "height", "width" or "diagonal" in mm (just one will do) and the yellow box will give you your image area in sq.ft. Most of you will know your screens diagonal in inches, so i have also put a simple inches to mm converter on that page if you need it. On the next three pages (change page by clicking the tabs in bottom left corner) you can calculate your image brightness (Ft Lamberts), Nits and your globes Peak Lumens. Simply enter your- "screen area" calculated from first page, "Lux" reading from your light meter Screen "gain" Thanks also to @IMDave for his input *Edit fixed a few bugs - 3-10-17 Edited October 2, 2017 by STAIN0 2 1 Link to comment Share on other sites More sharing options...
betty boop Posted October 4, 2017 Share Posted October 4, 2017 thanks staino, i.e. been keeping tabs of this kind of thing on paper, but i'll plug in this tool. thanks for putting together and sharing. pretty handy 1 Link to comment Share on other sites More sharing options...
STAIN0 Posted October 4, 2017 Author Share Posted October 4, 2017 No worries. Hope it helps. Let me know if there are any bugs, or if you have any suggested updates. 1 Link to comment Share on other sites More sharing options...
Wavetrain Posted October 10, 2017 Share Posted October 10, 2017 16 foot lamberts or more is the golden rule. 23.5 foot lamberts and then you can add Bias lighting! Link to comment Share on other sites More sharing options...
