sclalars
I've made the worlds "greatest" vinyl/record cleaner (so far)
Hi everyone!
A mad man you says? no,no,no, I'm serious about this. This is truly the far best record washer ever made.(as far as I know)
I've been listening to records since the early seventies, and I have tried many different washing methods, but no one of them is even close to wash the records so clean as this machine do.
I have friends who wash their records in washers like the expencive VPI 16.5, and after a clean in my machine, they are amazed. Well, enough bragging. :cool:;)
Let me show you.
I had a hard time planning, to make this work, and of course there are better solutions regarding design, but at that time, this is what I came up with. I'm going to make myself a new one soon, a much simplier one, but with the same function.
Here's a couple of drawings I've made, one with automatic function, and a simplier one, a hand driven one.
Both is based on this machine, an ultrasonic cleaner.
(Ultrasonic cleaning uses high frequency sound waves to agitate in an aqueous or organic compound. Cavitation bubbles induced by the agitation act on contaminants adhering to substrates like metals, plastics, glass, rubber, and ceramics. This action also penetrates blind holes, cracks, and recesses.
Often colloquially referred to as a sonicator, is a cleaning device that uses ultrasound (usually from 20–400 kHz) )
[ATTACH=CONFIG]21144[/ATTACH]
The automatic one:
[ATTACH=CONFIG]21141[/ATTACH]
And the hand driven one:
[ATTACH=CONFIG]21142[/ATTACH] [ATTACH=CONFIG]21143[/ATTACH]
More to come!
Lars
The heading should off course be "viny/record cleaner" not washer (those damn foreigners). Is there any way to edit this? Seems it's only possibel to edit the text, not the heading?
Lars
A mad man you says?
Lars,
Let me be the judge of that. I know 'mad' when I see it :cool:
And sorry, you don't qualify (just yet) for the loonies club ;) I reckon you have nailed the shortcoming of most RCM's. And those ultrasonic cleaners are VERY effective, yet gentle. Certainly more efficient than an RCM.
Do you envisage a problem with the labels being immersed in the solution?
2sheds
Lars,
2sheds
No, never had a problem with that. It takes about 4 minutes for the records to turn one round, so the water rinses off long before that happens.
And, off course the label never touch the water below.
Some more info about the design:
One of the problems was to make it to go as slow as possible. I searched the net for small motors with as little rpm's as possible, and with the one I found, I had to add a "slightly" large wheel.
Here's some pictures from the start of the project:
I startet out by making a stand for the wheel and motor:
This is my first experiment (many changes to come ;))
[ATTACH=CONFIG]21150[/ATTACH] [ATTACH=CONFIG]21151[/ATTACH] [ATTACH=CONFIG]21152[/ATTACH] [ATTACH=CONFIG]21153[/ATTACH]pencil.png
Lars
No,no, Young Skywalker, I made mine before this one came on the market:nana, and not to forget, I can wash up to 15 records at the time!
And one more thing, mine is much cheaper:D
Mine costs 450$ AU, the one you refer to costs 2680$ AU. Some difference huh?
Lars
Edited by sclalars
I did'nt like the looks with clear acrylic, so I decided to go for a white frost look instead:
I made some mistake while making it, but that's how it is to be a "pioneèr" is'nt it?
Here I forgot to cut out for the electric panel:
[ATTACH=CONFIG]21154[/ATTACH] [ATTACH=CONFIG]21156[/ATTACH]
But I did'nt forget this;)
[ATTACH=CONFIG]21155[/ATTACH]
Here I've made a test wheel (anyone reconize the speakers in the background?):
[ATTACH=CONFIG]21157[/ATTACH] [ATTACH=CONFIG]21158[/ATTACH]
Lars
Thank you Lucky!
Well, its pretty easy to make one. Just have patience, and I'll show you:)
Lars
Here's the motor I'll be using:
[ATTACH=CONFIG]21169[/ATTACH] [ATTACH=CONFIG]21173[/ATTACH] [ATTACH=CONFIG]21174[/ATTACH]
To turn the large wheel I needed a rubber ring ( Hope you understand. My technical English is worse than my terrible english ;))
[ATTACH=CONFIG]21175[/ATTACH]
Lars
I expected wood too! Very simple idea and very nicely exicuted as always mate! nice work!
Linc
And of course the motor needed a housing:
[ATTACH=CONFIG]21179[/ATTACH] [ATTACH=CONFIG]21180[/ATTACH] [ATTACH=CONFIG]21181[/ATTACH] [ATTACH=CONFIG]21182[/ATTACH]
Lars
Linc
Thank you Upfront!
Well, not everything is practical to make out of wood ;)
Lars
