seaninbrisbane
FS: Revox B790 turntable + Ortofon ML20FL Super cartridge (no stylus)
Item: Revox B790 turntable + Ortofon ML20FL Super cartridge (no stylus)
Price: $450 $450 $400 $350
Item Condition: Excellent, although it has been repaired, which is only visible from rear.
Reason for selling: It was an impulse buy and it requires a new stylus.  Too many other things going on to spend some time with it.
Extra Info: Have carried out basic testing and it seems to be okay: https://youtu.be/31h9ms_zqE8, but as I mentioned it will need a new stylus.  Pickup only, so that you can take a look at it before purchasing.
Edited by seaninbrisbane
Will you sell me the cartridge only ?
final price drop to $350.....otherwise I'll keep it and buy a new stylus......don't really want to start buying vinyl again though!
    • By Matyk
      Item: c19 plug
      Price:  40$
      Item Condition: new
      Reason for selling: never used
      Extra info
      will swap for a furutek c15..
      this was off a isotek sequel upgraded cable.
      plug is new .
      either 40$ for this or a swap for a c15.
    • By Darkstar
      Item: Threshold SA3.9e Stasis Pure Class A Stereo Power Amplifier
      Price: $4000
      Item Condition: Good Condition with some light superficial markings. Conservative 7.5/10 mainly due to age.
      Reason for selling: Surplus to Needs
      Up for sale is a RARE Threshold SA3.9e Stasis Pure Class A Stereo Power Amplifier. These amps rarely come up for sale. For those who know the Nelson Pass timeline will know that Threshold was one of the companies he worked for before venturing out into his own line of products. Threshold amps have become collector pieces these days and this SA3.9e would sit proudly in any audiophile/collector’s system.
      Rated at 60W pure Class A at 8 Ohms, it will drive all but the most inefficient speakers with clean, distinctive layering and an all round “picture” perfect details. Compared to todays Pass Labs products the Threshold is faster sounding, tighter and more in-control, mids are smooth without any odd or harshness, and the high are extended and free of grain.
      Nelson liked the SA 3.9e the best of the threshold amps from the 90s era mainly because, for its rated output, it was biased higher into class A and thus sounded more "liquid".
      These are very good amps and contend with the best out there that is 3-4 times more in value. Happy to audition and let your ears be the judge.
      Photos: Will post pictures later tonight
    • By JVS-1
      Item: Musical Fidelity A5cr Pre-Amp with Phono in MM/MC Switchable
      Price: $1700 ono
      Reason for selling: Upgraded
      Payment Method: Pickup - Cash, Paypal, Direct Deposit
      Extra Info: Happy to pack and ship at buyers expense via Fastway or TNT. Please PM for quote.
      I've had this unit since new, can't find the original manual after moving house several times over the years, so here's the link for details and specs. https://www.musicalfidelity.com/uploads/manuals/English/a5crpreamp_eng.pdf
      Never given me any grief and still works perfectly as it did from day 1.
      I always ran it with my Infinity Betas with great success, but am now upgrading to a valve pre as Arnie Nudell always recommend for them.
      https://www.youtube.com/watch?v=XIil7MWcZaM
    • By campo007
      Item: Timestep Technics SL-1200, SL1210 New Precision Bearing
      Price: $450
      Item Condition: NEW - UNOPENED (JUST GOT IT)
      Reason for selling: NEW DIRECTION
      Payment Method: Pickup - Cash, Paypal, Bank Deposit
      Extra Info: Will ship Australia wide at buyers expense.
      This is a brand new unused Timestep bearing for the Technics SL-1200 & SL1210. I just received it from Dave at Timestep, but decided to go in a new direction while in transit. The price i've proposed is the price i paid less GST and shipping from the UK. So saving around $80.
      Technics SL-1200 SL-1210 New Precision Audiophile Bearing
      The standard bearing cannot keep the oil in place.  Instead a high viscosity "anti-fling" oil must be used.  "Other" bearings can only be "topped up" and the oil not actually replaced.  Imagine not being able to change the oil in your car, only adding a bit now and again
      Why would you want to change the oil ?  Well we found a fairly heavy oil works best with the Funk Platter and thinner oil for very heavy platters.  But you have the choice, you can take our advice, or change the oil to whatever, whenever !  BTW, unlike others, our bearing fits the Funk platter perfectly, as it should !
      The Timestep bearing has the spindle as a solid single piece of polished 303 Stainless Steel with a much larger base diameter and the bearing is polished PB102 Phosphor Bronze. A silicon nitride ball and PTFE thrust pad are fitted. The whole assembly is in a captive oil bath so that you can use more suitable thin oil, or any oil of your choice.
      One image shows the Timestep bearing shaft on the left and the Technics on the right. The Technics bearing shaft has a cut out just below the brass part, resulting in a diameter of just 5.9 mm, the Timestep bearing shaft at this point is 10.4mm. This gives the Technics a critical bending moment around the reduced diameter.
      The main part of the Technics shaft bearing surface is 7.1mm diameter and the Timestep one is 11.1mm which results in a bearing surface increase of nearly 2.5 times more (actually 2.445). And that's a lot!  The other image is looking down into the captive shaft bearing. At the bottom would normally be the P.T.F.E. thrust pad and the silicon nitride ball bearing, and a lot of very nice oil.
      So with 1.76 times diameter at the weakest point and 2.5 times more bearing surface area, you can see why we get such great performance.
      We deliberately use the existing Technics bearing housing because it fits properly and being cast has great strength and rigidity, also it does not ring like a brass bell.  It keeps the cost down too !
      You don't need any special tools, you don't need to modify the PCB and you don't need to remove parts to get it to fit.  A simple Philips screwdriver is all you need and less than 15 minutes of your time.
      This is the best selling Technics bearing, users have reported more solid bass, considerably better timing, greater soundstage and a general "feel good" sensation.
    • By bzr
      Item: Siltech Royal Signature Princess XLR 1.5m interconnects
      Price: $3500 includes postage.
      Item Condition: Very good
      Reason for selling: Same as the dog with nuts, upgrading.
      Payment Method: Pickup - Cash, Paypal, EFT
      Extra Info: These need no introduction. Siltech cables have been in more best of systems than any other. Bought from the only importer, Uncle Boris.
