keinesorge Posted October 19, 2018 Share Posted October 19, 2018 As soon i get some time... Its a 4.3 install & CRAAP settings for my main rig. If needed, the guys on the moode forum have also got the audiophonics power management script sorted for the latest release. 1 Link to comment Share on other sites More sharing options...
mwhouston Posted November 4, 2018 Author Share Posted November 4, 2018 If you haven't seen already there is a new build for 4.3. It can be done on the player with no loss of settings. Takes about ten mins. If you are on 4.2 get the new image and then upgrade or check for image with new build included. Link to comment Share on other sites More sharing options...
mwhouston Posted November 12, 2018 Author Share Posted November 12, 2018 I've heard a rumour that Moode 4.4 is coming out with an updated MPD. Hope I have that right. Lets hope it's an image. Ive been on the latest build for a few weeks. Most is good. The volume control works now. But if I select a track form file explorers view I don't get some of the file Info - artist and album. Hope they fix this. Link to comment Share on other sites More sharing options...
betocool Posted November 12, 2018 Share Posted November 12, 2018 So, in layman's terms.... what's the significant upgrade between 3.x and 4.x? I've been running the same 3.something for a long time and am very happy with it. Cheers, Alberto Link to comment Share on other sites More sharing options...
mwhouston Posted November 12, 2018 Author Share Posted November 12, 2018 (edited) 9 hours ago, betocool said: So, in layman's terms.... what's the significant upgrade between 3.x and 4.x? I've been running the same 3.something for a long time and am very happy with it. Cheers, Alberto I would say it is more about presentation of files, files being played and presentation of radio stations is particularly nice. Is there an improvement in sound, I would say yes. With 4.3 being a downloadable image there is no technical reason not to upgrade. If you go to 4.3, from within Moode, you can upgrade the build but you must be on 4.3. I would suggest you keep your sim with the current image and cut a new one. That way if there is something you don't like just replace the new sim. I don't think you will though. Moode appears to work smoother and there are more "tuneable" selection for your DAC and other devices. I haven't tried it but I think you can now blue tooth files to the Pi for streaming. I would recommend the upgrade, for me it's only about 20mins of work and the last two upgrades I have done worked flawlessly. Edited November 12, 2018 by mwhouston Link to comment Share on other sites More sharing options...
bob_m_54 Posted November 13, 2018 Share Posted November 13, 2018 Also, you can select to list Artist, by Album Artist, which I thought was a very good feature.... :) Link to comment Share on other sites More sharing options...
mwhouston Posted November 13, 2018 Author Share Posted November 13, 2018 1 hour ago, bob_m_54 said: Also, you can select to list Artist, by Album Artist, which I thought was a very good feature.... I don't care about this info. but ill say you can. It may not be to the degree you think it should be but i think it is deep enough. Link to comment Share on other sites More sharing options...
bob_m_54 Posted November 13, 2018 Share Posted November 13, 2018 Haha, it's been one of my pet issues with it, and other Pi software, as you have probably guessed. It does make a big difference when you have around 3800 albums, with a great many compilations in there as well though. I just wish the same could be said for Yamaha Network enabled AV Receivers as well. Link to comment Share on other sites More sharing options...
mwhouston Posted November 18, 2018 Author Share Posted November 18, 2018 Though I have been on Moode 4.XX for a while (and on the latest build) I had never tried the Blue tooth conectivity. Today I gave it a go between my iPad II and a Pi 3B+ with an Audiophonics ESS9028 DAC HAT. It took a few goes but only over 10mins and I had it going. Not only that once setup it's about two menu clicks to reconnect. I would never consider blue tooth a hi-Rez media connection but for convenience it is a killer. I ran iTunes from the pad where I brought some files down from the iTunes cloud and it all sounded excellent and real easy to use. And as I said once setup its a few menu selection to revert back to it. Well worth the setup and giving it a go. Link to comment Share on other sites More sharing options...
mwhouston Posted December 18, 2018 Author Share Posted December 18, 2018 (edited) Those who are on 4.3 can do an in-Pi upgrade to 4.4. And why not? Takes about 5mins over wifi. Edited December 18, 2018 by mwhouston Link to comment Share on other sites More sharing options...
mwhouston Posted April 22, 2019 Author Share Posted April 22, 2019 MoOde 5 is out and ready for download as an image file. A mate has been using it a little more than me and thinks it stable. I’ve had about 2 hours listenIng on my portable Pi and so far so good. Yes a little different again. Also there is a new beta MPD you can try. I haven’t. 1 Link to comment Share on other sites More sharing options...
keinesorge Posted April 22, 2019 Share Posted April 22, 2019 4 hours ago, mwhouston said: MoOde 5 is out and ready for download as an image file. A mate has been using it a little more than me and thinks it stable. I’ve had about 2 hours listenIng on my portable Pi and so far so good. Yes a little different again. Also there is a new beta MPD you can try. I haven’t. I'm still using 3.81 - 3.84 for the voicing of my setups. 1 Link to comment Share on other sites More sharing options...
mwhouston Posted April 22, 2019 Author Share Posted April 22, 2019 20 minutes ago, keinesorge said: I'm still using 3.81 - 3.84 for the voicing of my setups. It’s definitely worth the effort of upgrading. Took about 20mins in total. Link to comment Share on other sites More sharing options...
keinesorge Posted April 22, 2019 Share Posted April 22, 2019 1 minute ago, mwhouston said: It’s definitely worth the effort of upgrading. Took about 20mins in total. Cheers mwhouston, Does the UI work well with mobile devices ? In my work area i'm using a PC.. no issue with the layout. But in my main rig (and using a phone) i found 4.3 to be a bit tricky to use. Link to comment Share on other sites More sharing options...
betocool Posted April 23, 2019 Share Posted April 23, 2019 If you install the MPDAndroid client on your phone the GUI I find is more manageable than Moode. Give that a try. Cheers, Alberto 2 Link to comment Share on other sites More sharing options...
mwhouston Posted April 28, 2019 Author Share Posted April 28, 2019 Moode 5.1 is out. You must upgrade to Moode 5 then through System Check for new software. Moode will download and install 5.1. Reboot and re-configure. The whole procedure is very smooth and fast. I never upgrade to a new major version until the X.1 is out. I did install 5.0 on my portable system but now have brought both my main and portable Pi’s to 5.1. Worth the effort. Also at each major upgrade I make a small donation. I’d like to see Moode continue to improve and I hope this ensures that. 2 Link to comment Share on other sites More sharing options...
betocool Posted May 7, 2019 Share Posted May 7, 2019 I'll have to take the leap to 5.1. I'm still on 3-point-something. Cheers, Alberto Link to comment Share on other sites More sharing options...
mwhouston Posted May 7, 2019 Author Share Posted May 7, 2019 (edited) Just a warning. I’m back on 4.4 because I was getting clicks when music was playing. Higher the rez more of the clicks. But others with the same DAC as me are having no problems. Ill wait for 5.2. Edited May 7, 2019 by mwhouston Link to comment Share on other sites More sharing options...
keinesorge Posted May 7, 2019 Share Posted May 7, 2019 Oh cool. I’ll have a look see. Link to comment Share on other sites More sharing options...
mwhouston Posted May 12, 2019 Author Share Posted May 12, 2019 My man Dan the man says 5.2 is out. Time to try. Link to comment Share on other sites More sharing options...
mwhouston Posted October 13, 2019 Author Share Posted October 13, 2019 If you are on Mo0de 6.XX you can upgrade to 6.3 via the Pi. No need to download images. If not on 6 you must download an image. Link to comment Share on other sites More sharing options...
keinesorge Posted October 13, 2019 Share Posted October 13, 2019 11 hours ago, mwhouston said: If you are on Mo0de 6.XX you can upgrade to 6.3 via the Pi. No need to download images. If not on 6 you must download an image. Oh cool. Do you know if is has a real time kernel with this release ? Link to comment Share on other sites More sharing options...
betocool Posted October 14, 2019 Share Posted October 14, 2019 I just punt 5.something a few weeks ago and happy with the results. Spotify a bit of a pain to get working properly and still a bit quirky, but still good. Cheers, Alberto Link to comment Share on other sites More sharing options...
keinesorge Posted November 6, 2019 Share Posted November 6, 2019 I've just tested 6.3.0 and this one sounds pretty good. A contender to the 3.8.4 release with the real time kernel option. Wow. 2 Link to comment Share on other sites More sharing options...
mwhouston Posted November 6, 2019 Author Share Posted November 6, 2019 I’ve been on 6.3 on my temp portable system for a while. All sounds good and works well. Happy. Link to comment Share on other sites More sharing options...
