gypr1961
WITHDRAWN OR RELISTED: FS: AMR DP777 SE DAC
Item: AMR DP777SE with Gemini cable
Price: 4700 ONO
Item Condition: Excellent
Reason for selling: Not used
Payment Method: Pickup - Cash, Bank Transfer
Ive now got a pair of avantgarde zeros so the amr is redundant.  I was going to keep it for a second system but I doubt I'll ever get around to it so it time to let it go
Ive had a couple of questions about which version this is so just to clarify, this is the "signature" edition. Some people seem to think the version with the quad board upgrade or USB board upgrade is the SE "signature" edition, it isnt.  The signature is a complete overhaul of the previous version which was the base model with a quad board upgrade.
Edited by gypr1961
This item has been withdrawn from sale or relisted.
    • By herringboy47
      Item: Yaquin MS22b - Nice little phono stage, responsive to a range of MM cartridges - I like it with the Stanton range
      Specifications:
      ●Tubes: 12AX7B × 2
      ●Output Voltages: 0.5V (400Hz input)
      ●Output Jacks: One group of gold plated RCA jacks
      ●Input Sensitivity: ≤4.0mV (400Hz, 0.5V output)
      ●Input Jacks: One group of gold plated RCA jacks plus a grounding terminal
      ●Signal Noise Ratio: >85dB (A weight)
      ●Distortion: ≤0.11%(400Hz input)
      ●Power supply voltage: 110/220V 60Hz/50Hz
      ●Dimension:200H * 170W * 125L(mm)
      ●Gross weight:3.3kg
      Price: $150 (firm)
      Item Condition: As new
      Reason for selling: Surplus to needs
      Payment Method: Pickup - Cash, Paypal, Direct Deposit
      Extra Info: Review here: https://forums.stevehoffman.tv/threads/i-review-the-175-tubed-yaqin-ms-22b-phono-preamplifier.267043/
    • By Milesey74
      Item: Integra DHC 80.3 Pre
      Price: $1000 plus postage PRICE DROP: $900
      Item Condition: Excellent and all original packaging
      Reason for selling: ATMOS journey
      Extra Info: I have had this pre since new. It is an excellent sounding pre and was the last Audyssey model used by Integra. The room correction, and sound is simply superb from this pre. It has full balanced inputs and outputs as well as RCA jacks.
    • By Fikub33
      Item: Burson HA 160D Headphone Amplifier, DAC & Preamp
      Price: $475
      Item Condition: V. Good
      Reason for selling: No Longer Using (sold headphones a while back)
      Burson Audio HA-160D Headphone Amplifier
      A really sweet sounding, transparent, open and powerful sounding DAC, Pre-amp and headphone amplifier.
      In v.good condition. I used this to drive a set of high end Senheiser T1 headphones and it worked a treat. After I sold the headphones I primarily used the unit as a dac and preamp running straight into my power amp and its works really well in that set up as well.
      Sold with original box, manual etc. so happy to ship at buyers cost.
      Specifications
      Input impedance: 47 KOhms
      Frequency response: 5Hz (-0.3dB) to 35 kHz (-1dB)
      Signal to noise ratio: >98dB at 0dB gain
      THD: <0.001% at 6mW/300 Ohms
      Channel separation: >70dB/10kHz
      Output power: 650mW/300 Ohms, 800mW/60 Ohms
      Output impedance: line out 60 Ohms, phones out 5 Ohms
      Power dissipation: <25W, internal, regulated power supply
      Dimensions: 265 mm x 250 mm x 80 mm
      Connectors
      Inputs:
      1 x USB Connection (Support up to 24bit @ 96Khz with 10ppm low jitter
      clock)
      1 x Coaxial RCA (Support up to 24bit @ 192Khz)
      3 x gold plated RCA (line level input)
      Outputs
      2 x headphone jacks 6.35mm
      1 x pre -out with 10Db gain
      Weight: app. 7 kg
      Color: silver anodized aluminium
    • By jdh500
      Item: Benchmark DAC 1
      Price: $450
      Item Condition: used but work as new
      Reason for selling: have a later DAC 1 HDR
      Payment Method: Pickup - Cash, Paypal if posted
      Owned from new, originally purchased from a Sydney HiFi store for arround $1400. Made in the USA, extremely well made and compact DAC, includes 3 digital inputs, can be used as a DAC or DAC/Pre-Amp/Headphone Amp.
      Comes as shown in photos with original user manual, box and power lead.
      Was used in my study connected between a Squeezebox Touch FLAC music streamer and also a computer. Using AKG 702 and HD600 headphones.
      Pickup preferred but will post at buyers cost, ie. approx $30 registered post.
      copy of user manual and reviews are readily available on the internet.
      reviews:
      http://www.6moons.com/audioreviews/benchmark/dac1.html
      https://benchmarkmedia.com/products/benchmark-dac1-digital-to-analog-converter
