garrycol 0 Posted June 19, 2017 Share Posted June 19, 2017 My mum lives in Belmont Lake Macquarie and for about a month has been having TV reception problems. Usually no problems in the mornings but as they day progresses, the channels become pixelated or the signal dropping out for a few seconds before coming back for a little while then dropping out again. As the location is behind a ridge most of the antennas are high up on poles so not easily retuned by homeowners. My Mum does remember receiving a note in the letter box from the local MP a little while back saying some areas were suffering reception problems but does not recall the detail, Neighbours have similar issues and some have called in antenna installers to fix. Obviously the networks have changed their transmissions somehow and this is causing the issue. Does anyone know if any such changes have been made and what they were. My Mum at 89 is a bit too old to climb the pole and move the antenna to a new position. Thanks Garry Link to post Share on other sites
alanh 0 Posted June 19, 2017 Share Posted June 19, 2017 Garry, When the digital switchover occurred there was indeed some big changes in your area. Mostly it was caused by the Illawarra and Hunter Valley (Newcastle) main transmitters being on the same transmission channels. In summer there is ducting in the atmosphere so the Illawarra signals are interfering where the Newcastle signals are weak. Also the Central Coast has a single frequency network where there is multiple transmitters on the same transmission channels. This is all because there is only 5 blocks of channels available. There is a new set of Band 4 UHF transmitters at Optus/Hutchison Site Belmont Water Reservoir Violet Town Rd BELMONT NORTH NBN28, ABC30, SBS31, NEN (Prime)32, NRN(SCA)33 Firstly, disconnect the antenna at the receiver and go to the installation menu and do a full automatic scan and wait for it to finish. This will erase all existing channels. Now reconnect the antenna and do another scan. If the signals from Belmont North are strong enough the receiver will store channels 28 - 33.now stop the scan. As this scan occurs or after it is finished check the bar graph on signal strength. You need around 80 % for reliable reception. Go to http://myswitch.digitalready.gov.au type in her street address and to the top right corner and click on transmitters available. Select Belmont north. and see if she is in a green zone. If you can return an indoor antenna from Jaycar try https://www.jaycar.com.au/slim-digital-tv-indoor-antenna-with-amplifier/p/LT3206 It should be mounted on its side with the telescopic rods folded out as a single vertical line with a tip to tip length of 548 mm. If that is unsuccessful or undesirable https://www.jaycar.com.au/heavy-duty-uhf-phased-array-tv-antenna/p/LT3154 phased array or other brands from antenna installers mounted with its longest side horizontal. It should be able to me mounted on a short pole outside and cabled using quad shielded coax cable. Alanh Link to post Share on other sites
garrycol 0 Posted June 19, 2017 Author Share Posted June 19, 2017 Thanks for the information but that all seems relevant to some time ago - at least a year ago and TV reception was fine then. This issue has just started in the last 4 weeks or so. Indoor antennas do not work in the location and never have and as such all antennas in the area are about 6m higher than the roof line. The current antenna is fully digital and worked fine until a few weeks ago. So do you know of any changes made in the past month. Cheers garry Link to post Share on other sites
alanh 0 Posted June 19, 2017 Share Posted June 19, 2017 Garry which transmitters is she watching Newcastle, Belmont North Wyong or Sydney directly? Alan Link to post Share on other sites
garrycol 0 Posted June 19, 2017 Author Share Posted June 19, 2017 (edited) Hi Alan - i have no idea - the aerial and all the others in the area point to the North West so not Sydney. The aerial was professionally installed when digital came then a couple of years later the whole lot fell down in a storm and a totally new aerial installed - it has a phased array aerial similar to the one you linked above and under it a linked basic yagi style antenna underneath. As I said all was OK until about 4 weeks ago then it started playing up - it is related to the transmissions not the aerials - the neighbour cannot watch TV at all where at least my mum's is watchable. The TV says signal strength is good even though it is pixulated. Oh - at about the same time a new mobile phone tower was erected about 300m away - should no be an issue but who knows. cheers Garry Edited June 19, 2017 by garrycol Link to post Share on other sites
alanh 0 Posted June 19, 2017 Share Posted June 19, 2017 Garry, I was thinking of interference. the mobile phone tower is the likely culprit. Remember that in 2013 there was a restack of TV transmission channels so that channels 53 - 68 could be sold to the mobile phone industry. It is likely that is the cause. They are legally entitled to transmit from the mobile tower but also from mobile phones using 4G/LTE from Telstra and Optus's 4Gplus. Your only protection is to insert a filter https://www.jaycar.com.au/fl694lp-4g-lte-tv-antenna-signal-filter-f-type/p/LT3067 at the input to any masthead or distribution amplifier and if you have neither then at the antenna input to the receiver. This would also help the neighbour. There is no point putting the filter at the receiver input if there is any form of antenna amplifier because it will cause the interference to form. Alanh Link to post Share on other sites
garrycol 0 Posted June 20, 2017 Author Share Posted June 20, 2017 Thanks Alan - I agree the tower is a suspect - the only thing is that TV reception changes as the atmospherics change in the afternoon and evening - no issues in the morning then past 12 noon TV reception deteriorates - if it was the tower the interference would be 24/7 but anything is possible. I am physically 450km away and tried to get my mum to retune the TV today but I gave up as a lost cause so she is going to have to call the antenna man to come and fix - she will probably go halves with the neighbour who has worse reception. i was hoping the same one may have heard of a specific reason for the issues in the area. I appreciate your input - thanks Garry Link to post Share on other sites
GoudaK 2 Posted June 20, 2017 Share Posted June 20, 2017 I have done some work in Belmont and sounds you are pointing towards sugarloaf, there is a new one in Belmont itself, https://ozdigitaltv.com/transmitters/NSW/611-Belmont-North for a quick fix before calling installer turn Ariel to a Vertical position and point towards this tower and tune to these channels. Link to post Share on other sites
garrycol 0 Posted June 20, 2017 Author Share Posted June 20, 2017 You could be correct but the Belmont tower has been up for some time and issues only started a couple of weeks back. Even to realign the aerial the antenna guy will still need to come out due to its height above the house. Unfortunately due to high buildings near the boundary (Bunnings is one) a high antenna will still be needed even though the transmitter is only 1km but not line of site due to shielding buildings - both brick and steel. Thanks Link to post Share on other sites
I am not a duck 0 Posted June 21, 2017 Share Posted June 21, 2017 New Optus mobile site started up at 24 Bluebell St a few weeks ago. That may be the source of your problem. On 19/06/2017 at 3:39 PM, garrycol said: Neighbours have similar issues and some have called in antenna installers to fix. That is probably your best bet. Get some one in with the right gear to sort it out. Link to post Share on other sites
alanh 0 Posted June 21, 2017 Share Posted June 21, 2017 Garry, They need to get a TV antenna installer who has a digital field strength meter with a spectrum analyser. You can measure accurately the strength of the signals the errors in the signal as to whether they are caused by reflections or noise/interference, measure the additional distance reflected signals are taking and the level of interference and at which frequencies. As a result someone who knows how to use the digital field strength meter with spectrum analyser will be able to identify the cause and then after installation verify that reliable reception will continue under all reception conditions. Alanh Link to post Share on other sites
garrycol 0 Posted June 22, 2017 Author Share Posted June 22, 2017 12 hours ago, I am not a duck said: New Optus mobile site started up at 24 Bluebell St a few weeks ago. That may be the source of your problem. That is probably your best bet. Get some one in with the right gear to sort it out. Yes it is the suspect but if it was the mobile phone tower it would cause interference 24/7 - as it is interference only starts in the afternoon and goes into the evening - there is no interference in the mornings. Link to post Share on other sites
I am not a duck 0 Posted June 22, 2017 Share Posted June 22, 2017 On 6/20/2017 at 0:33 PM, garrycol said: I am physically 450km away and tried to get my mum to retune the TV today but I gave up as a lost cause so she is going to have to call the antenna man to come and fix - she will probably go halves with the neighbour who has worse reception. Let us know how she goes. Link to post Share on other sites
alanh 0 Posted June 23, 2017 Share Posted June 23, 2017 Garry, The times you quote are typical of using mobiles, however the weather also changes in this pattern as well. This why a digital field strength meter is required to isolate if the signal is fading from Mt Sugarloaf/ ducting from Illawarra which is weather related or if it is interference from the mobile phone tower. I should also add any corrosion in the antenna system will aggravate interference problems because it causes intermodulation. I assume being so close to the coast that salt laden air will cause antenna corrosion. Alanh Link to post Share on other sites
garrycol 0 Posted June 23, 2017 Author Share Posted June 23, 2017 Interestingly I tried to ring OPtus to discuss the installation of the mobile phone tower nearby but soon gave that away as a bad joke. I intially rang the advertised number and got through to the Phillipino Call centre. Unless you have an issue with your mobile service they are not interested. I asked to be put through to the behind the scenes admin area that deals with tower installation and got no where - a blank we have no numbers like that. To sound racist and I am not - Optus and Telstra really need to better understand the culture of the places that they set up their call centres because if the operator does not understand the issue the shutters come down in a face saving measure and you get no where. The guy did not understand that we had Free to Air and my TV service was not being provided by a service provider. If you get through to an Aussie they do actually try to help. I had a similar issue with Telstra last year and managed to find the private email address of the CEO - that got a response within 30 minutes - all sorted. I tried to find the private email of Allen Lew the Optus CEO but could not find it. These Telcos really need to also have contact details for more admin type issues not associated with day to day account delivery and get rid of the overseas call centres. Service is not in the lexicon for companies like Optus and Telstra I then tried to lodge a complaint with the Telephone ombudsman about not being able to contact the telco - not their problem though they did have a direct tel number for the OPTUS Fixed Infrastructure section but it was a dead number. Now I am not accusing the Optus tower of causing the issues but it would be nice to discuss with Optus so I may better understand if there could be a conflict. Link to post Share on other sites
I am not a duck 0 Posted June 23, 2017 Share Posted June 23, 2017 (edited) Interestingly, I have exactly this difficulty with a customer today, viz experiencing bad breakups in the evening only. An initial test this morning shows the digital TV signals have not deteriorated since I was called to repair the installation 4 years ago when the installing technician, for some inexplicable reason, installed the TV antenna with the incorrect polarisation. The property is behind a tree line, which can cause issues in some situations, but I do not consider this to be a factor here. There is also a Telstra mobile tower 400 metres away with the following radiation pattern for the frequency of interest most likely to interfere with TV reception: The property in question is located in the 210° sector, so it may be causing the issue if the tower gets loaded up in the evening, I don't know yet.The tower has been operational for over 12 months, & the customer has only had breakup for the last 2 weeks or so. There is a non LTE protected masthead amplifier at the property, an analysis of the signal shows there is some interference from the mobile phone tower, but not at a level that I would expect to cause issues at the time of measurement. It was a wet & windy day, so rooftop work was not possible. I intend to wait until the customer advises me the problem has returned in the evening, whence I shall go & investigate the signal once more, to confirm the source of the problem, & decide on the course of action to resolve it. I could not justify changing/replacing items until determining the cause of the breakup - it may be a problem with the reception/distribution equipment at the house. (Just by the by, there is a Telstra tower 200 metres from where I live, an Optus tower is about to be installed 100 metres from my property boundary. The requisite notices for the Optus installation were posted as required, Objections on the basis of possible TV interference would not usually be considered either pre or post installation. Technology changes, & sometimes this requires people affected by this change to remediate it at their expense. (I won't, however, get involved on the effect of RF radiation on living organisms. In my opinion the jury is still out on that one.) I expect when this Optus tower is switched on, there will be work for me (& others) to overcome interference from the TV antenna installations using non compliant masthead amplifiers within a couple of hundred meters of this tower, as happened when the Telstra one became operational.) EDIT: Attended the property yesterday evening & saw a couple of glitches, nothing showed on my meter.... Attended again today & removed the masthead amplifier as it isn't really required. Now to see how things go. Edited June 24, 2017 by I am not a duck Update Link to post Share on other sites
alanh 0 Posted June 23, 2017 Share Posted June 23, 2017 Garry, Read http://www.acma.gov.au/Citizen/TV-Radio/Television/TV-reception/whats-wrong-with-my-tv-reception and the associated links. Just remember that the ACMA will do nothing if the mobile phone tower equipment is operating within its licence conditions. It will be up to the viewer to insert a 700 MHz filter as I mentioned above with no compensation. Alanh Link to post Share on other sites
garrycol 0 Posted June 23, 2017 Author Share Posted June 23, 2017 Thanks guys - I appreciate all the information. The guy who who put up the current antenna arrangement (before the Belmont Transmitter tower and the closer OPtus mobile phone tower) is booked in next week to sort the problem. He will definitely have to orientate the antenna to the Belmont Tower, possibly replace the actual aerial with one more suitable, remove the current amp and possibly replace with a 700Mhz filter - up to him to get it all sorted. I very much appreciate the advice and help provided - has been a bit of an eye opener. Garry Link to post Share on other sites
garrycol 0 Posted June 26, 2017 Author Share Posted June 26, 2017 Ok the antenna guy came out this morning - issue was the mobile phone tower and fixed with the filter - call out and filter $100 which is not bad - just cost me $250 to get my TV carted to the TV repairer. The guy new all about it and asked my Mum whether she had seen the advice sent out to everyone about the phone tower and TV reception - well no, because she thought it was junk mail and threw it out . Now I asked my mum to get the guy to reorientate the antenna to pick up the Belmont Tv Tower transmissions but she forgot to write it down so the aerial is still pointed towards Sugarloaf - but not such an issue as we never had the ducting interference problem from the Illawarra. Will just file that away if it plays up in future, Thanks for the advice provided by you guys - was spot on, on all counts. Cheers garry Link to post Share on other sites
Brian K 2 Posted August 31, 2018 Share Posted August 31, 2018 True ducting will happen near water on very hot days/nights. Belmont near the 16 footers and bottom end of Evans St and side streets in your area. Also Dudley and Merewether. Merewether is getting it from Coffs Harbour. A phone tower issue will be every channel 24/7. Plenty of signal strength but the quality is totally wiped out. This will show up on a meter. If Bunnings is in your way you are in the wrong area for ducting issues. You will most probably have line of site to the Belmont transmitter also. These idiots who leave old amps installed and install filters should be updating the amps with built in 4G protection. Better still, look for better off air signal and get rid of the amp or use a distribution amp if needed. Various streets off Evans, I've had to install 15 masts and go to Belmont with great success. Could not get any sense out of Sugarloaf and DON'T use phased array antennas, asking for trouble. Link to post Share on other sites
I am not a duck 0 Posted September 1, 2018 Share Posted September 1, 2018 Last post from garrycol over a year ago. 22 hours ago, Brian K said: A phone tower issue will be every channel 24/7 Not always, ime. Overload of a masthead amplifier or receiver front end might be marginal, dependent on propogation or loading of a cell site. 22 hours ago, Brian K said: DON'T use phased array antennas, asking for trouble. I'm curious, is that site specific? Link to post Share on other sites
Brian K 2 Posted September 1, 2018 Share Posted September 1, 2018 A true mobile phone issue will be 24/7 on every channel. An overloading amp may be all or some of the channels but not necessarily 24/7. Never use panels with trees or multiple transmitters around unless you absolutely have to for more gain to drive an amp. Been saying this for years and finally the gurus are agreeing with me. What is ime? Link to post Share on other sites
davewantsmoore 6,503 Posted September 1, 2018 Share Posted September 1, 2018 in my experience Link to post Share on other sites
Brian K 2 Posted September 2, 2018 Share Posted September 2, 2018 Thanks. Link to post Share on other sites
