13 minutes ago, franin said:
Don’t want too be in the room as my AV Gear is in another room.
Have a look at this, the limit for the ARC low speed cable is 3m.
http://www.ebay.com.au/gds/USB-Cable-Length-Limitations-and-how-to-break-them-/10000000001067998/g.html
Still think it is easier if you use a laptop with existing cable..
I’ll check the manual for the supplied length hopefully it should be okay
On 02/03/2018 at 3:47 AM, DarkNark said:
I can't see why you would run virtualisation software on your Mac when you can buy a laptop with Windows 10 installed for the same price that you can download Windows 10.
While certainly a solution for some, the limited periods wouldn't suit me.
No I don’t think you can buy a windows machine for nothing. Some might think that’s more than their worth but that’s a little off topic.
What I said was Mac users don’t need to buy a physical windows host to run ARC. They can run windows in a virtual environment. Many Mac users will already have vmware or parallels and run any windows software they need this way already. Otherwise they can download virtualbox from Oracle (for free), load a developer windows image from MS (for free) and run ARC.
The dev images are good for several months, after which you can always download a new one. If you only need to do a one-off or rare task like run ARC to setup your equipment then it’s a handy thing.
If your room EQ is changing everyday, because... you live on a park bench or something. Then perhaps this isn’t for you. But then you probably have more important issues to worry about like your rummy mates selling your Anthem, or the damn 9pm sprinklers going off every Wednesday.
Just measured mine, 3.7m.
Can I use with my 4 subs the XLR SUB 1 AND SUB 2 also the RCA SUB 1 and SUB 2 at the same time ?
Maybe?
Quote
I want to biamplify some of my speakers. Can I use the RCA outputs on the preamp to feed some amp channels and the XLR outputs to feed others?
Although they put out a signal simultaneously, using them for biamplification will cause an imbalance since the XLR outputs are louder. It's a lot simpler to just use a Y-splitter.
This came from the FAQs.  While this is referring to bi-amping, I think the same principle applies because there is an imbalance.  If you can adjust for the imbalance, it is theoretically possible?
Thanks for that. That is right actually I remember reading awhile back that RCA and XLR run at different volumes. I’ll stick with my Y Splitter.
Still waiting for my call when my Anthem arrives. I’m having withdrawal symptoms
Guest DarkNark
Ok
Edited by DarkNark
Play nice
Guest DarkNark
Good luck with it all. Keep us informed with how you progress. I hope you are impressed with the ARC system as much as I was. It was a stunning change for my system the first time I ran it. [emoji4]
On 3/2/2018 at 2:34 PM, Snoopy8 said:
Sorry, mentioned earlier but not in later posts.  Suggest having in profiles:
  • Standard
  • Full L&R Max Eq 300 Hz
  • Full L&R Max Eq 500 Hz
  • Full L&R&C Max Eq 500 Hz  (changed this from earlier suggestion to include centre).
 @SimonNo10  interested in your feedback, even negative, so that others can learn from it.
Thanks mate. I hope so too :)
Sorry haven't had time to test those settings yet.
5 hours ago, Snoopy8 said:
Maybe?
There's a 6 dB differential between XLR and RCA (in favour of XLR). Using it on a sub is less of a problem, than say, fronts, but be careful running ARC on the subs in this configuration as ARC will make some interesting decisions.
I’ve asked this question in another thread but I want too ask it here as well. Audyssey when calibrating uses 0.0db in there MV as reference is Anthem the same ?
Not sure I understand your question, but let me explain what I know of ARC.
During measurement, ARC aiming for 75 dB as reference but will sometimes go higher.  ARC will then adjust the relative levels of the speakers.  Screen shot of levels within ARC, sorry quite faint because it is greyed out and cannot be changed by user.
Oh okay I’m used too Audyssey setting the receivers / preamps at 0.0 when calibrating with there mic. Just curious to find what my reference point in the master volume in the Anthem.
Looking at that pic where is says calibration offset I’m assuming is based it on master volume being 0db. Correct
Guest DarkNark
I didn't adjust my volume knob to any position. I had previously been playing music and my volume knob was at -35 dB. I ran ARC and away it went.
With Audyssey I noticed regardless what volume it is when calibrating it automatically switches too 0.0db
Guest DarkNark
Ok. I am not sure I noticed what it was because when I ran it, I left the room. Only advice I can give,  wear earplugs. :)
Ok. I am not sure I noticed what it was because when I ran it, I left the room. Only advice I can give,  wear earplugs. [emoji4]
Will do thanks :)
OK, I now understand the context of your question. ARC sets its own volume during measurement, but I do not know at what number.  I doubt it is the 0 dB.  My highest volume during movies is about -20 to -15 dB and any more would bring the neighbours out!
p/s as an aside, I do not know how people claim they watch movies at reference level (0 dB ??). Remember, this a log scale measurement. I get more than enough slam at -20 with the dual subs.  My equipment will do 0 dB but not sure the ears will survive?
Edited by Snoopy8
Typos
Agreed. If I listened at my place at -15 dB on my D2v, I'd be deaf.
Well I just got the call it should arrive today. Excited and nervous :)
    • By kerisabe
      Item Condition: Mint, very low hours. Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: North Melbourne State: Victoria Payment Method: EFT, Cash on Pickup. Reason for selling: Surplus Further information:
      Silver Audio Research DAC 9.
      Selling due to surplus in my system. Unit is in mint condition, very low hours of use. Serious buyers only, can check condition upon pick up. Located in North Melbourne, 5 mins walking distance from Queen Victoria Market.
      Some review articles to read:
      http://www.enjoythemusic.com/magazine/equipment/0320/Audio_Research_DAC9_Digital_To_Analog_Converter_DAC_Review.htm
      https://audiophilestyle.com/ca/reviews/audio-research-dac-9-review-r644/
    • By gwavz
      Item: Anthem AVM 60 Processor
      Price Range: $2000-$3000
      Item Condition: Used
      Upgrade time and need a processor to go along with a WTB Power Amp please! Would consider other receivers/processors. Balanced output desired, but not essential
    • By :) Go Away (:
      Hi Guys,
      Need some advise and guidance regarding the power amplifier requirements for home theatre use.
      I have Anthem MRX710 powering my 7.1 setup in Home theatre, my components are as below.
      Fronts: Ascension Summoner 863SQTL (150 WRMS, with 91 dB 1w/1m sensitivity)
      Center: Ascension 253SQ (120/200 wrms/max (@ 60Hz plus), , with 91 dB 1w/1m sensitivity)
      Surrounds: Polk T15 (20 watts → 100 watts, with 89 db 1w/1m sensitivity)
      Surround back (Ceiling mounted): Micca M-8C (100 watts, with 90dB 1W/1M sensitivity)
      Subwoofer: Martin Logan Dynamo 600x
      Room size: 4m x 3.8m (Acoustically treated with Acoustic pin boards, Martini Absorb HD50 on all 4 walls with carpet on the floor, ceiling untreated.)
      I like loud volumes when watching movies to get the same feel and punch one gets from commercial theatres. However, I have never gone past -10db volume level with Anthem, as I find other members of the household start complaining before I even get a chance to listen at reference level. This is for mainly HT use, I do occasionally listen to two channel music but it is not my main stereo listening room.
      Some demo audio at close to reference level sounds amazing and feel like increasing the volume even more, however I find some movie scenes at the loud volume seems to be bit distorted or somewhat incoherent that I find the need to turn down the volume. I am not sure, if this is the limiting factors of Anthem's power amp stage or just room acoustics.
      So far, Anthem has been the best AVR, I have ever had and Sound quality is really really great. Lately, I have been questioning, if I should add a power amplifier to the mix, and if I did, will there be much improvements to the sound quality vs the money spent? I am mainly thinking about adding 2 or 3 channel amp for front stage. I have seen countless posts on the net where people suggest adding power amp to AVR to boost the sound quality, given the Anthem MRX710 driving 7 channels, I don't think it outputs more than 80-90 watts per channel.
      Will adding power amp to my setup give me better bang for buck?
      As for the budget, It is very limited at this stage and I am thinking somewhere the range of $1000 for 3 channels. Unfortunately, most in this range are somewhat at the same power rating as the Anthem or less, that I think will not make much difference adding them.
      What do you guys recommend, Is power amp really necessary and will it be a better investment? if so, what amps would you recommend to go with Anthem MRX710?
      Anthem's MCA325 is an ideal choice to match with Anthem MRX but at $3600, it is way out of budget for me. Should I get some inexpensive amp now or perhaps I should save up and go for it when budget allows and be done with it or I am looking at this at wrong way and should perhaps target my speakers. I am quite happy with the front stage, my surrounds are cheap speakers, but they do their job.
      What has been your experience when adding the power amp to relieve AVR of some of the channels?
    • By :) Go Away (:
      Item: Anthem MRX-510 or above any model
      Price Range: $700 +
      Item Condition: New or Used
      I am looking for Anthem MRX receiver from model MRX510 and above range, basically 7 channel AVR.
    • By flipswitch
      I’m a bit confused about this now, because I’ve gotten different answers.
      I am using the HDMI arc connection ( it’s the only HDMI out) (Denon avr-x1600h) connected to the HDMI arc on my tv ( Panasonic fz950 OLED  (which is full bandwidth)
      I have my 4K blu ray player and PS4 Pro connected to my avr HDMI ports.
      When I’m playing a 4K movie with Atmos on my blu-ray player, am I getting it down-converted to something lower quality, or full lossless atmos?
      I understand that playing something from my tv, eg the Netflix app, I wont be able to get Atmos.
       Eg;
      When playing a movie with atmos connected to the  HDMI ARC port of my tv, my AVR says Dolby Atmos – True HD.
      Now when playing it on the HDMI non arc port, it says the say thing, Dolby Atmos -True HD.
       Everything sounds the same.
