Well I tested the system changing the Max Eq to 300 and then 500 and for me it removed the soundstage and became flat. I tested one movie scene and switched b/w the settings and didn't like what I was hearing. Snoopy8 did I have to change my mains to full range in order to test this setting?
On 12/23/2017 at 7:33 AM, Marc said:
$3999 for an Anthem MRX 1120!!!!!
Wow, that's an awesome offer, but it's now expired.
Is this deal likely to come back every X'mas or end of financial year?
Is the streat price for the MRX1120 close to this?
Yeah I missed that as well. I was trying though but no go for me.
Is the Anthem MRX 1120 exactly the Anthem AVM 60 but with a power amp built in?
Anthem does not do this often. If you look around and are prepared to bargain, you should get close to this. I heard that a demo one went even lower... :)
I understand this is the case, have seen mentioned before,
"If the AVM 60 looks a lot like Anthem’s top A/V receiver—well, essentially, it is a de-amplified edition of the brand’s 11.2-channel MRX 1120 (reviewed last month), at a $500 savings and with all-channels balanced (XLR) preamp outputs where the speaker outputs would otherwise be"
Read more at https://www.soundandvision.com/content/anthem-avm-60-av-processor-review#K1rwLiQ8jemxjGYy.99
13 hours ago, franin said:
Would arc work with Windows 8.1 ?
ARC runs on Win 7 or later
Sorry, mentioned earlier but not in later posts.  Suggest having in profiles:
  • Standard
  • Full L&R Max Eq 300 Hz
  • Full L&R Max Eq 500 Hz
  • Full L&R&C Max Eq 500 Hz  (changed this from earlier suggestion to include centre)
@:-) thank you for helping out.  Will one day convert you from crappy Audyssey :na: Yes, trolling :lol: pls report me :P OH! you are a moderator? :)  Back to topic...
https://hometheaterreview.com/anthem-avm60-preampprocessor-reviewed/
AVM60 has balanced outs, separate headphone amp, better analogue to digital converters, a lot quieter internals.  Read unconfirmed speculation that it could do more equalisation, more PEQs underneath.
The AVM60 had to be superb because it is supposed to replace the acclaimed AVM50. When announced and looking like a MRX box, caused a fracas on AVSForum running over many pages.
haha i am not wedded to anything. only ever owned one marantz unit :D dont use audyssey for my 2ch rig and seperate measurement and eq for that instead :) though am very happy with the marantz and audyssey pro and its a gift keeps giving (next update june) I never say ...never :P
Yes Snoopy ; the adc's are improved if you like analog input according to audioholics as well . I can imagine a quieter signal path too with the unbalanced circuitry being converted to balanced for the xlr's depending on implementation.
Quote
Anthem's pre-pros have always had audio advantages and the AVM60 continues that trend. The A/D converter is upgraded in the AVM60.  Anthem claims that the premium A/D converters are capable of delivering a 106 db signal to noise ratio ensuring high quality sound when using analog sources.
https://www.audioholics.com/av-receiver-reviews/anthem-mrx-520-720-1120-receivers-and-avm60-processor
On the ARC frequency cut off its good that Anthem don't eq the whole spectrum ; with some theres no choice :cool:
Quote
ARC's calibrated microphone maintains its 5kHz limit and does not default to correcting frequencies higher thank 5kHz
Not sure I’m getting the Pre amp tomorrow so it will have to be Tuesday as Monday is a Public Holiday. But hopefully I should be getting a crash course on how to use ARC tomorrow
Have a look at the ARC videos in the first post of this thread. It is very easy to use and you will be guided thru the process. Don't worry about tweaking in Targets, let it run and upload and you are good to go.
Thanks. What about the measurements that we have to enter in manually. The guys over here at the store calibrating their systems with arc say you don’t have too.
You need to put in the speakers distances and then you can use quick measure to adjust the volume on the sub to 75db or close. Should be right to go after than.
Is that just for the quick measure or does it apply for the whole process as well ?
Let me elaborate on what Simon said.
Firstly,  ARC does not measure delays of speakers, subs themselves (other packages do  but it can be inaccurate). You need to enter the speakers/subs distances within the setup of the unit to MLP (main listening position) where you are doing the measurement
The next step is to ensure that the speakers and subs have the same loudness.  There is a Quick Measure within the ARC to do this.  Do Quick Measure for Left & Right Speakers.  When you run it, it will show more or less the same average dB at the bottom.  If not, then you may need to ensure left & right are same distance to MLP.  Sometimes, room like mine , opens up one side and you lose a bit there.  Nothing you can do there.  ARC will compensate.
Then use Quick Measure to measure the subs. Ideally, they should be within 1 dB of left, right speakers.  You may need to adjust the gain at the back of the sub; Quick Measure is live, so you can see as you adjust. And of course, wear ear protection while doing all of this.
Once you have entered the distances and ensured that subs and speakers are the same loudness, you will be ready to start the ARC process proper.  Go to Measure and follow the instructions. ARC Overview will give you a good idea.
Oh okay. I have 4 subs that we’re originally plugged into the back of the Marantz with a Y xlr cable for Both subwoofer Channels. I’ve still got the Audyssey last distances for the two sub channels. I might have to use those distances.
A tape measure is all you need. Worthwhile to re-measure, and you do not need to be that accurate, ARC distances are 0.3m (1 ft) apart.  The other thing is ARC expects the subs to be integrated. Have a look at Calibrate dual woofers with ARC (Poor Audiophile),   This is minimum you need to do (and it uses Quick Measure! :)).
Thanks I will have a look
Sorry One more question so I have to adjust the phase as well as mentioned on that link ? I was told ARC 2 handles that.
ARC treats multiple subs as 1 integrated sub, even though it has 2  sub ports (in parallel) on AVM60.  It will adjust the phase of the multiple subs together as if it had 1 sub.
That’s good.
Hey guys another I’m looking at ordering a longer USB cable for the mic to the computer. Will that affect the results if the cable is quite long ?
The supplied cable is quite long. Surely you can place the laptop in the center?  How big is your room ???
Don’t want too be in the room as my AV Gear is in another room.
    • By dheck
      Item: Paradigm Perfect Bass Kit or Anthem Room Correction ARC1M
      Price Range: Less than new.
      Item Condition: New or Used
      I'm looking for the calibration mic to use with PBK and ARC Genesis with a Paradigm Seismic 110.
      Prefer local to Sydney.
    • By kerisabe
      Item Condition: Mint, very low hours. Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: North Melbourne State: Victoria Payment Method: EFT, Cash on Pickup. Reason for selling: Surplus Further information:
      Silver Audio Research DAC 9.
      Selling due to surplus in my system. Unit is in mint condition, very low hours of use. Serious buyers only, can check condition upon pick up. Located in North Melbourne, 5 mins walking distance from Queen Victoria Market.
      Some review articles to read:
      http://www.enjoythemusic.com/magazine/equipment/0320/Audio_Research_DAC9_Digital_To_Analog_Converter_DAC_Review.htm
      https://audiophilestyle.com/ca/reviews/audio-research-dac-9-review-r644/
    • By gwavz
      Item: Anthem AVM 60 Processor
      Price Range: $2000-$3000
      Item Condition: Used
      Upgrade time and need a processor to go along with a WTB Power Amp please! Would consider other receivers/processors. Balanced output desired, but not essential
    • By :) Go Away (:
      Hi Guys,
      Need some advise and guidance regarding the power amplifier requirements for home theatre use.
      I have Anthem MRX710 powering my 7.1 setup in Home theatre, my components are as below.
      Fronts: Ascension Summoner 863SQTL (150 WRMS, with 91 dB 1w/1m sensitivity)
      Center: Ascension 253SQ (120/200 wrms/max (@ 60Hz plus), , with 91 dB 1w/1m sensitivity)
      Surrounds: Polk T15 (20 watts → 100 watts, with 89 db 1w/1m sensitivity)
      Surround back (Ceiling mounted): Micca M-8C (100 watts, with 90dB 1W/1M sensitivity)
      Subwoofer: Martin Logan Dynamo 600x
      Room size: 4m x 3.8m (Acoustically treated with Acoustic pin boards, Martini Absorb HD50 on all 4 walls with carpet on the floor, ceiling untreated.)
      I like loud volumes when watching movies to get the same feel and punch one gets from commercial theatres. However, I have never gone past -10db volume level with Anthem, as I find other members of the household start complaining before I even get a chance to listen at reference level. This is for mainly HT use, I do occasionally listen to two channel music but it is not my main stereo listening room.
      Some demo audio at close to reference level sounds amazing and feel like increasing the volume even more, however I find some movie scenes at the loud volume seems to be bit distorted or somewhat incoherent that I find the need to turn down the volume. I am not sure, if this is the limiting factors of Anthem's power amp stage or just room acoustics.
      So far, Anthem has been the best AVR, I have ever had and Sound quality is really really great. Lately, I have been questioning, if I should add a power amplifier to the mix, and if I did, will there be much improvements to the sound quality vs the money spent? I am mainly thinking about adding 2 or 3 channel amp for front stage. I have seen countless posts on the net where people suggest adding power amp to AVR to boost the sound quality, given the Anthem MRX710 driving 7 channels, I don't think it outputs more than 80-90 watts per channel.
      Will adding power amp to my setup give me better bang for buck?
      As for the budget, It is very limited at this stage and I am thinking somewhere the range of $1000 for 3 channels. Unfortunately, most in this range are somewhat at the same power rating as the Anthem or less, that I think will not make much difference adding them.
      What do you guys recommend, Is power amp really necessary and will it be a better investment? if so, what amps would you recommend to go with Anthem MRX710?
      Anthem's MCA325 is an ideal choice to match with Anthem MRX but at $3600, it is way out of budget for me. Should I get some inexpensive amp now or perhaps I should save up and go for it when budget allows and be done with it or I am looking at this at wrong way and should perhaps target my speakers. I am quite happy with the front stage, my surrounds are cheap speakers, but they do their job.
      What has been your experience when adding the power amp to relieve AVR of some of the channels?
    • By :) Go Away (:
      Item: Anthem MRX-510 or above any model
      Price Range: $700 +
      I am looking for Anthem MRX receiver from model MRX510 and above range, basically 7 channel AVR.
