4 hours ago, Snoopy8 said:
Been using a Harmony remote with my 710 and no problems. Your better half may not be pointing the remote long enough at the unit?  Try adding a short delay and teaching the wife to point the remote longer.
Is it best for AVR to be turned on first or last? Will have to look into the remote software to work out how to achieve this, I have a Harmony 650
Same Harmony model. Sequence depends on your equipment. My plasma tv is very slow in starting up, hence is first and I added a delay before switching to hdmi.
In your case, suggest AVR first, make sure it switches to correct input. It may help because your wife may not be pointing the Harmony long enough for it to complete its sequence.
To make changes, go into My Harmony, select the activity, customize this activity.
Will give it a go, thanks
6 hours ago, 2LOUD2OLD said:
Interestingly has only ever happened when it has been my wife using the thing.
It is a fact that wives are unable to use a Harmony remote.
Hi All
I've been meaning to update my experience into the thread for a while and it seems like today is a good day.
I purchased a MRX-510 from HifiExpress Ebay and it worked well apart from the fact it would shutdown when loud spikes in movies happened. If the receiver was unplugged for a while, it wouldn't happen again straight away, it could be hours or days, but it would happen again.
Once the issue happened, I could unplug all devices expect one source and unplug all speakers, so there was no sound and it would still shut down when it got to the audio spike in the movie. (The test I used was the start of the movie Iron Man - There is an explosion at about the 2 minute mark that would cause my 510 to shut down if the volume was -24 or louder with my speakers.)
I reported it to HifiExpress/Audio Active and I had to take it to Filatronics for repair. It came back without them being able to reproduce it (at the time I hadn't worked out that unplugging it corrected it for a while).
So I had some back and forth with Filatronics to try a few things, resets, disconnecting everything etc but it was still happening.
Both Filatronics and Audio Active were really good about it and decided they would replace it rather than making me go through the hassle of potentially more trips to the repairer. They didn't have another 510, so it was replaced with a 710 at no extra cost to me.
The 710 was in good condition, but the marks around the HDMI out showed it had been used a fair bit. No big deal.
The good news is that the 710 didn't suffer the same shutdown issue that the 510 did.
So to yamapro, this may be the unit I had that is now repaired unless they got another one in from somewhere (which they probably do from time to time).
To 2LOUD2OLD, with the 710 I have had the unit lock up once. I do use a harmony but I had manually turned on the zone 2 only and was playing some music (analogue source) for a while but it stopped at the end of the album. A while later I went inside and pressed the zone 2 power toggle, but it didn't go off. No other buttons on the front or remote did anything. Powered off at the wall and have not had the problem again so far.
Ben
Hi. I will be upgrading from 7.2 Yamaha to Atmos and the $1000 trade in on the 1120 caught my eye. Only ever had a couple of Yamaha avr's. Don't know anyone with Anthem so was wondering are the worth the extra $' s Im assuming the ARC is much better than yamaha's EQ.
Hi Stu!
By all accounts the Anthem ARC room correction software is among the very best available and a big step up from Yamaha's YPAO. That said I'm not sure exactly how much you would gain from it. The general consensus seems to be that the positives of RC software are mostly found in the lower frequencies ,and that electronic EQ should be limited to under the  Schroeder frequency, especially with speakers as well designed as your Cat12's. Which is why the Anthem ARC system allows you to limit the correction range (I think as low as 200hz up to 4 or 5Khz). But with you having a MiniDSP in place and having your delays/crossovers/EQ set by Paul - I'm not sure you would get the full benefit. I'd definitely speak with Paul first and see if he feels it'd be worth the premium.
Of course there are other reason to buy Anthem as they are well built and (IMHO) classy looking units.
Have used ARC in 3 untreated rooms in different houses, all with excellent results. When we first shifted to our new home, the family room was an echo chamber and ARC made it passable.
Am using a Behringer DCX2496 to integrate & optimise my dual subs. ARC gives excellent results when the subs are integrated.
Besides managing the subs, ARC improves the separation of channels, dialog is clearer on centre speaker.
The DCX2496 sounds impressive,  my mini DSP is 2x4 but only use 1 in and 1 out to my Behringer Europower 2x2000 watt to my 2 horn subs,
It does not matter whether you use a mini DSP or  Behringer.
ARC is treating multi subs as 1 sub channel. Multi subs should be integrated and optimised prior to running ARC. Integration can be as basic as ensuring that the phases are aligned to doing what Paul Spencer did with your setup.
I used a program called Multi Sub Optimisation (MSO). Prior to that, I tried using REW to integrate my dual subs but MSO with ARC produced an outstanding result.
Unable to comment on YPAO (Yamaha) because I have not used it. I am confident you will find ARC very good.
What's the build quality of Anthem components Like?
Asking, due to interest in their new STR 2 channel integrated ?
Build quality is generally good for the Anthem and layout of both the front and back is well thought out.
What will be interesting is how people will be using ARC for 2 channel in the STR. Dirac is accepted for 2 channel but ARC is usually used for HT. But Anthem pre pro owners can use ARC, so would like to hear from them how good ARC is for 2 channel.
I'm comparing the Anthem MRX1120 to Yamaha RX-A3070.for a 7:2:4 setup. I was told the 1120 will only use the Atmos speakers when playing an Atmos sound track BD. Where as the 3070 can be configured to use the Atmos speakers when playing non Atmos soundtrack if you wanted. Any Anthem users thoughts on this....
I was also told the 1120 has 7x140 watt and 4x100 amps (2 100 watt Sterio amps) not the 11x140 watt like the book says.
According to the manual (I have non Atmos 710), the 1120 will use the height (Atmos) speakers with AnthemLogic, Dolby Surround, DTS X.
 The 1120 has 5 Class A/B 140 watt amplifiers and 6 Class D 60 watt amplifiers. Some reviews, including SNA, got it wrong by saying it is 11x 140.
Note that the 3070 has 9 x 150W, so you do need an additional 2 channel amplifier for 7.2.4
Also, 1120 power consumption is 570W, not sure what the 3070 is.
More importantly, have you heard both the Anthem & Yamaha?  And Anthem has ARC, considered one of the best room correction software. Have not read about anyone rating YPAO well.
If I go the Yamaha path, I have the Cat 12C's for mains so 9 ch. ok
With the 1120 would 4x140 for surrounds and 4x60 for the hights be the best.
You cannot reassign the main amps on the 1120.  No idea whether this is possible on the 3070?
The Yamaha is starting to sound better, with 9ch. at 150 watts. Just got a call back from Anthem dealer, he said at first 11@140. But then said what you recon, 5@140,6@60.
Two anthem dealers have tryed to sell me the Yamaha over the Anthem, unless I'm looking at the AVM60 pre/pro and $10k for amps
I am not so sure about the Yamaha 9 x 150 W.  If you can find out the power consumption, that will give you a better idea of its power capabilities.
Guessing here, but I suspect the Yamaha may have better margins??
Going back to my suggestion about listening to both - the Yamaha will likely sound different to the Anthem.  Let your ears be the judge...
Yamaha 3070 has 9 x 150W, power consumption of 490W (from manual). Anthem 1120 has 5 x 140W, 6 x 60W, power consumption of 570W.  The power consumption is a better indicator of how much power the amps can produce.
Can assign surround/rear amps to zones 2,3,4, probably not able to re assign main amps ?
Good side by side comparison of specs
https://www.crutchfield.com/S-fXQVgDOQdyi/compare_022RXA3070_973MRX1120/Yamaha-AVENTAGE-RX-A3070-vs-Anthem-MRX-1120.html
A review of both AVRs plus others
https://www.themasterswitch.com/best-av-receivers
Thanks for info. The two Anthem dealers near me, nether have an MRX 1120 to listen to. Only the AVM60.  A bit disappointing. I supose they think if you can afford Anthem you can afford to go all out. Reminds me of a time years ago in a hi fi shop I went to to listen to some Boston Acustic speakers, you had to go though the blue carpet room into the red carpet room, full of all high end gear, and I was given the impression that, 'you don't look like you can afford any of this stuff and we don't want to talk to you', never been back there.
One dealer had checked with the importer, Audio Active, and said 7 A/B class amps @140 and 4 D class @80 watts.
But I'll read these articles ........
Edited by SandS
https://www.anthemav.com/products-current/series=mrx-series/model=mrx-1120/page=specs
Definitely 60w for secondary speakers and 5 x 140W, see above specs.
Shame that the dealers and importer cannot get it correct!
Shame the two dealers near me can't give me a demo.
Don't let the 1120;s 6x60watt height/rear surround channels put you off Sands ; they are class d so more efficient than the 3070;s class ab which makes the power consumption snoopy mentioned all the better in anthems favour . anthem too may be more conservative in how they rate their amps output :)
Noteworthy too; the yam has useless composite and component analog inputs unlike the 1120 and upsamples video to uhd  res . The anthem afaik just has a clean video passthrough which makes more sense to me when we have superior deinterlacing/.scaling in our sources/displays where it belongs imo..
Note too; 1 review mentioned the yam may have impedance concerns with rare hard to drive impedances..   No support for four-ohm loudspeakers apart from front stereo pair
Any chance either dealer can give you a NAD T777mk3 audition ? just to complicate things sorry:ninja:http://www.nadelectronics.com.au/nad_au/home-theatre/t-777-v3-av-surround-sound-receiver/c-37/c-1102/p-1601
Edited by cwt
    • By flipswitch
      I’m a bit confused about this now, because I’ve gotten different answers.
      I am using the HDMI arc connection ( it’s the only HDMI out) (Denon avr-x1600h) connected to the HDMI arc on my tv ( Panasonic fz950 OLED  (which is full bandwidth)
      I have my 4K blu ray player and PS4 Pro connected to my avr HDMI ports.
      When I’m playing a 4K movie with Atmos on my blu-ray player, am I getting it down-converted to something lower quality, or full lossless atmos?
      I understand that playing something from my tv, eg the Netflix app, I wont be able to get Atmos.
       Eg;
      When playing a movie with atmos connected to the  HDMI ARC port of my tv, my AVR says Dolby Atmos – True HD.
      Now when playing it on the HDMI non arc port, it says the say thing, Dolby Atmos -True HD.
       Everything sounds the same.
    • By Arry74
      Don't know how to explain this but here goes.
      I have an Anthem 720 together with 7.1 speakers plus a Panasonic TV plus just purchased an Apple 4K TV device.
      Netflix via the TV and the Anthem the sound is awesome, and when I press the mode button it says it is playing in surround sound.
      Netflix via the Apple 4K TV it says Dolby Atmos but the sound is no where as good. It stutters and sounds awful and you have to turn the volume up so much to get anywhere close to the same via Netflix on my TV.
      Any ideas what this could be?
    • By coffee25
      Item: ANTHEM AVM60 11.2Ch Processor
      Price: $2950 ONO
      Item Condition: As new with all accessories and books, no box, can arrange suitable transport box with protection. Also have ARC Mic.
      Reason for selling: Fund upgrade
      Payment Method: Cash, Paypal, COD Only
      Extra Info: Can Post anywhere is Aus - $50.
      Audiophile-Friendly 11.2 Pre-Amplifier/Processor
      Few A/V Preamplifier-Processors offer the innovation and performance found in the all new AVM 60. Features include Dolby Atmos & DTS:X immersive audio decoding, support for UHD Blu-ray and 4K60 through HDMI 2.0a with HDR. HDCP 2.2 and 18.2 Gbps are also included allowing switching for compatibility with the latest video formats.
      Audiophile-friendly features include a toroidal power supply, premium differential-output D/A converters with 32-bit conversion and sampling rate optimized filters for hi-res sound. Premium A/D converters with 106 dB signal to noise ratio ensure the highest- quality sound when using analog sources.
      DTS Play-Fi offers easy-to-use music playback from popular streaming services and locally networked sources, controlled through iOS, Android or PC apps.
    • By Arry74
      Hi
      I have recently purchased an Anthem MRX 720 AVR however i need another 2 channel amp to power my two additional outdoor speakers.
      My speakers are PSB CS1000 https://www.westcoasthifi.com.au/product/psb-cs1000-outdoor-speakers/
      They are way too overkill for outdoors due to neighbours and not being able to talk so I dont need to play them really loud etc.
      Any recommendations for a 2 channel amp to connect to my Anthem to power these?
      I used my Anthem currently to power 2 x floor standing speakers, center, sub and 4 x In ceiling speakers.
    • By LWA Staff
      Item: Anthem MRX520 AV Receiver
      Price: Was $1000 StereoNET Special $850
      Item Condition: Excellent 2ndhand condition
      Payment Method: Cash, Paypal, Credit Cards, Bank transfers, ZipPay
      Shipping: To anywhere but the dark side of the moon
      Extra Info: This just traded MXR520 AV Receiver is in superb condition and has it's remote and operating manual and we've reduced the price just for SN members!
      Anthem say: The award-winning Third Generation MRX Series of high-end multi-channel A/V receivers are known the world over for their excellent sound quality, efficient power handling, and the ease with which they integrate into an entertainment system. The MRX Series is packed with exclusive audio innovations like Anthem Room Correction (ARC) Technology and Advanced Load Monitoring (ALM) Technology, 4K Pass-Through with fast HDMI switching and more. You can read more about it here on their site.
