10 hours ago, powerav said:
Sound wise I find it to have much more detail than previous AVR's but one big downfall is no dual bass EQ, compared to a Denon 4300 or Integra models the bass is pretty much non existent except for those big movie moments like explosions and stuff, much more noticeable on music concerts where detail is better but the fun factor is gone from having dual subs. Looks like I'll have to muck around with these MiniDSP things, for a premium product you shouldn't have to.
Is there a way of having subwoofers activated for 2 channel music?
I'm a little perplexed here. Are you saying that even with the mains crossed over at say 80hz, that in stereo mode there is no output from the subwoofers?
There are various modes. You can have 2.0, 2.x, 5.x. But if using crossover, defaults to using subs.
Yes I know, but my question was in relation to Power AV's findings.
Perhaps the Marantz 6012 may have been a better choice then!?!
No that is all good now, it improved when ARC was turned off.
Not sure, the only benefit that has is the Sub eq, I will still have to turn Audyssey off.
7 hours ago, Hi-Fi Whipped said:
@POWER AV
is is it wrong I had a little chuckle when I read your findings, we all knew it was coming!
This isn't about me but i gave up on room eq a couple of years ago simply applying the theory of the purest untouched signal is the best, something a lot of 2ch experts preach. I don't have the perfect room but lots of plush soft furnishings and carpet help I'm sure. I don't even need to add bass and treble tweakings.
i must say it's been a game changer for me by making changes to speaker positioning etc. but I do have one of those dspeaker sub eq thingys you speak of as I reckon the sub bass is the critical signal to get right, let the upper frequencies sing  I say!
the CA 751r has been the component to seal my theory, the dynamics this thing has is insane for 2ch and surround, I've never heard sound this good from anything I've owned.
But no room eq isn't for everyone and it's got to the point where for me ignorance is bliss.
in your case, I wouldn't throw the baby out with the bath water just yet, reckon I've said it before but look at it as a bonus that you can either use or not, if it sounds good with eq just keep it off. Plus I'm sure there's plenty you can do to improve it if you can be buggered too, it's a cracking reciever from all reports so maybe just have some patience man!
YES, YES and YES to everything you have said.
The CA 651r and the Integra's without Audyssey were the best for me.
I remember when I had the Integrated Amp set up with HT bypass all in same room of course. The Integrated sounded superb against the Denon 4300 but that had audyssey on when I sold that and got a Integra 30.5 there was little difference. Integrated stereo amps don't have any type of room correction.
Now the Anthem with ARC of in stereo mode is just like an integrated amp and a very good one.
All I really need is a mini dsp thingy for the dual subs now and I should be right.
I think all this room correction stuff is like some religious cult as soon as you speak out against it you get people either coming out and supporting or trying to shut you down.:)
Edited by powerav
30 minutes ago, JSmith said:
:lol: touché. That is one in about 20,000 ever made! (You'll probably find more now :)). I won't be buying that.
seriously though surely what you put in is exactly what you want out, why do you want to fiddle around with processing.
3 minutes ago, powerav said:
touché
:D Sorry, didn't mean it that way, was actually just looking into this the last few weeks as a new option.
There seems to be a few here and there now... but generally as you say usually don't have RC.
JSmith :ninja:
Some more entertainment for you all :popcorn:
Did a complete factory reset of the Anthem, set up subs as best I could as per the guide @Snoopy8 linked, thank you. Re did ARC and i noticed that the curves were much flatter than last time. I also just tried to measure in a 1 to 1.5 Metre radius only. I think this is what did it rather than try to cover a large area, I think.
Anyway fired everything up played just 30 secs of my test pieces. The Police certifiable - Wow that Bass on this one was back in a back in a big way. Billy Joel At Shea Stadium just the first minute and you'll know if it's right and it was. Then on to SACD 5.1 Dire Straits BIA - Your Latest Trick, yep that's the best i have heard that and so on.
I am even leaving ARC on for everything.
2 Channel music, as we all know this is always hard to get right as all recordings are so different, I actually like it with Anthem Logic Music, the stays in the Left and Right channels. Need a lot more listening to evaluate that but positive so far.
I suspect that your 2 subs was out of phase to one another and had slightly different volumes.  With properly integrated subs, ARC does a fantastic job as you have discovered.  Glad this saga has turned up ok.
Anthem Logic Music and Cinema are both good.  They seem to sound more natural.
@Snoopy8 is there a pure direct mode just so I can compare or is pure direct just as simple as mode set to none and Arc turned off?
In the Anthem menu, set Process Analog Audio Input to No, which will bypass digital conversion and signal processing.
Ok that is only if using an analog input, no direct mode on digital inputs like other Avr's.
looks like I need to get a Dac now to try it out.
Hi all, ad me to the MRX720 and the Integrated 225 club, I'm not an Anthem fan boy but have both of these and think they are great, Anthem make good Amplifiers
Finally managed to watch a movie today, Spectre.
Wow, I have never heard my system sound so good. Now it motivates me to go 7.1 even more now, currently 5.1
Sent from my R7sf using Tapatalk
So you have set it up with the ARC software?? mine sounds great for movies but I'm more about the music and my 720 impresses me on 2 channel when I get the chance to use the lounge room and that isn't often with teenagers and wives etc, that's why I have a few systems
Yes, using ARC.
I have a 2 channel Bel Canto amp I use for music as well as HT bypass to run front speakers
How are you using for 2 channel ie CD player/streamer into digital or analog inuputs?
Turntable via a phono stage into the analog input and the beaut Play-fi app that works with the 720 that taps into my NAS drive, works faultlessly and very easy to use, the DACs in the 720 seem to work great as well, very happy with this allrounder as it keeps the family happy and me with the music when I get the chance
I haven't had a good chance to really test play fi yet, from what I've seen looks pretty good.
Need to get kids off Xbox:angry:.
I need a good week by myself, might be worth sending the kids and missus on a holida:thumb:
Just realised there is a hires critical listening button on the play fi app!!!!!:)
I am going to have to get 2 separate sources, one for movies and one for Music.
Will keep HTPC for music of all types, video concerts, surround music and 2 channel music and probably a Nvidia shield or similar for movies.
Music of all types is still far better including 5.1 music concerts with ARC OFF. Movies are better with ARC On so currently with all content on the one device (HTPC) it's too much of a pain having to keep on turning Arc on and off, exactly the same thing with Audyssey.
So is the Anthem back up for sale yet? ... ;)
cheers Terry
Edited by TerryO
    • By N_R
      Item: Anthem MRX-510 or above any model
      Price Range: $700 +
      Item Condition: New or Used
      I am looking for Anthem MRX receiver from model MRX510 and above range, basically 7 channel AVR.
    • By flipswitch
      I’m a bit confused about this now, because I’ve gotten different answers.
      I am using the HDMI arc connection ( it’s the only HDMI out) (Denon avr-x1600h) connected to the HDMI arc on my tv ( Panasonic fz950 OLED  (which is full bandwidth)
      I have my 4K blu ray player and PS4 Pro connected to my avr HDMI ports.
      When I’m playing a 4K movie with Atmos on my blu-ray player, am I getting it down-converted to something lower quality, or full lossless atmos?
      I understand that playing something from my tv, eg the Netflix app, I wont be able to get Atmos.
       Eg;
      When playing a movie with atmos connected to the  HDMI ARC port of my tv, my AVR says Dolby Atmos – True HD.
      Now when playing it on the HDMI non arc port, it says the say thing, Dolby Atmos -True HD.
       Everything sounds the same.
    • By Arry74
      Don't know how to explain this but here goes.
      I have an Anthem 720 together with 7.1 speakers plus a Panasonic TV plus just purchased an Apple 4K TV device.
      Netflix via the TV and the Anthem the sound is awesome, and when I press the mode button it says it is playing in surround sound.
      Netflix via the Apple 4K TV it says Dolby Atmos but the sound is no where as good. It stutters and sounds awful and you have to turn the volume up so much to get anywhere close to the same via Netflix on my TV.
      Any ideas what this could be?
    • By coffee25
      Item: ANTHEM AVM60 11.2Ch Processor
      Price: $2950 ONO
      Item Condition: As new with all accessories and books, no box, can arrange suitable transport box with protection. Also have ARC Mic.
      Reason for selling: Fund upgrade
      Payment Method: Cash, Paypal, COD Only
      Extra Info: Can Post anywhere is Aus - $50.
      Audiophile-Friendly 11.2 Pre-Amplifier/Processor
      Few A/V Preamplifier-Processors offer the innovation and performance found in the all new AVM 60. Features include Dolby Atmos & DTS:X immersive audio decoding, support for UHD Blu-ray and 4K60 through HDMI 2.0a with HDR. HDCP 2.2 and 18.2 Gbps are also included allowing switching for compatibility with the latest video formats.
      Audiophile-friendly features include a toroidal power supply, premium differential-output D/A converters with 32-bit conversion and sampling rate optimized filters for hi-res sound. Premium A/D converters with 106 dB signal to noise ratio ensure the highest- quality sound when using analog sources.
      DTS Play-Fi offers easy-to-use music playback from popular streaming services and locally networked sources, controlled through iOS, Android or PC apps.
    • By Arry74
      Hi
      I have recently purchased an Anthem MRX 720 AVR however i need another 2 channel amp to power my two additional outdoor speakers.
      My speakers are PSB CS1000 https://www.westcoasthifi.com.au/product/psb-cs1000-outdoor-speakers/
      They are way too overkill for outdoors due to neighbours and not being able to talk so I dont need to play them really loud etc.
      Any recommendations for a 2 channel amp to connect to my Anthem to power these?
      I used my Anthem currently to power 2 x floor standing speakers, center, sub and 4 x In ceiling speakers.
