There should be little difference but suggest calibrating ARC with and without the power amp and report back here.
Regarding sonic differences, it does depend on the equipment involved including interconnects.
Thanks I’ll have to give the ARC calibration a try and test the difference.
Very true, Snoop.
I think the question is also able to be asked what dB in output gain do the compared amps mentioned provide?
Generally speaking I'd say that means for every decimal point xx of a volt received the amp then multiplies internally.
A more high output amp means it needs a less 'hot' input to achieve your speaker's requirements for output volume.
A lower output amp would mean you effectively can turn up the source louder, potentially leading to its internal DACs working slightly differently (or better) which can yield a possible slight variation in tonal behaviour.
You could test this by a simple 1khz tone measurement on a decibel meter and ensure each amp at the same receiver/processor level stays unchanged. You then adjust any decibel variance in increasing the output level for the speaker channels.
Im glad you guys talked me out of selling my Anthem AVM 60. Ive been playing around with Genesis this time calibrating each speaker at 200hz. I was told about the Schroeder Frequency and It sounds great, more detail in the movies. Basically let the speakers naturally do what they do. I originally started at 500hz and that sounded good but 200hz  even better. So a big thanks  very happy guy here. Btw does the Marantz Audyssey with the App allow to adjust at different freq ?
On 14/02/2019 at 9:50 AM, Neilsy said:
I've ordered a Keyspan USA-19HS off eBay and should arrive within 2 weeks.
I'll give it a crack and report my findings if it gives success or not
Hi Neilsy - Can I ask which Ebay seller you sourced your Keyspan adapter from? Still working well?
The best source I can find in Australia is Digikey store at AUD$64 delivered.
PS - If any forum members have an old MRX 310/510/710 they’re considering selling, feel free to PM me.
Edited by OzJustin
It's a Tripp Lite USA-19HS. I think a few people resell them so any seller would do.
Mine worked as soon as I plugged it in. Here's a link to one on eBay
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F183936167800
17 hours ago, sfdoddsy said:
Thanks guys. That Comsol one is pretty expensive at $45 so the Tripp Lite is probably worth the few extra dollars to know that it will work.
On 26/08/2019 at 7:00 PM, OzJustin said:
Is anyone using an Elektra Theatre or Anthem MCA amp with their Anthem receiver? I’d love to compare the sonic differences between an Elektra, Anthem and Emotiva amp.
I too would like to know the answer to this question...
Me too.
I use an Anthem processor, Anthem M1 statement amp (for subs) and two Emotiva XPA5 but I don't have any Elektra in hand to help with that part.... [emoji51]
1 hour ago, Neilsy said:
I use an Anthem processor, Anthem M1 statement amp (for subs) and two Emotiva XPA5 but I don't have any Elektra in hand to help with that part.... emoji51.png
I think the query was anthem receiver's built in amp compared to external amp (Elektra etc).
3 hours ago, kitschcamp said:
Don't know if anyone noticed, but Anthem are adding IMAX Enhanced to our current receivers!
When IMAX enhanced is disc based or a high quality DOWNLOAD service, and I can get a projector that will work with it, I'll be doubly excited.
I'd be happy enough with Anthem for a firmware fix that addresses that damn DTX:X HRA issue so I can frigging finish watching the Fast and Furious UHDs... Given imax is a variant of the DTS:X codec, I hope they actually manage to test the less common HRA - that said, if imax enhanced is streaming, it sure won't be DTS:X MA...
Edited by Mobe1969
Bit harder than that ; op was wanting comparisons with MCA power amps :)
Does anyone know the ETA on when this IMAX enhanced will be available?
Well, the article was 6th September, and it said within six weeks, so I guess sometime in October.
I hope I can finish watching these Fast and Furious films finally, and they have fixed DTSX HRA...
I would be interested in hearing comparisons for any and all variants. I just found it interesting going from the Anthem MRX inbuilt amp to an external Emotiva amp there was a noticeable difference to the sound. Granted I have not had the chance to run ARC again with the power amp to see if it 'restores' the original Anthem sound but I'd be curious to know. It would also be interesting to hear if anyone has done a direct comparison of the sound differences between an Anthem MRX inbuilt amp and the Anthem power amps e.g. MCA, P, STR etc series. I would expect it would preserve the original warmth and detail with greater soundstage added but who knows for sure...
Just as a general overview Justin any of the power amp options would be an improvement depending on how hard your speakers are to drive [ the avr's use class d as well as a/b to help the smaller power supply] You will more likely get ' all channels driven' specs with a power amp  ; and more headroom for transients .
Also generally the Elektra has the advantage for atmos etc of being 7ch rather than 5 and good value looking at the MCA 525 ; https://sydneyhifimonavale.com.au/products/anthem-mca-525-power-amplifier . potentially one less chassis for 7.1.4 too :) The Emo XPA mk3s are configurable if 1 box is best and are class H so very efficient compared to class a/b  ;)
Quote
At very low power levels, their efficiency is very similar to Class A/B (a tiny bit better).
And, at full power, their efficiency is also quite similar.
However, at medium power levels, which is where most amplifiers operate most of the time, they are significantly more efficient.
Thanks for that CWT. Having recently upgraded to an Emotiva 5 channel power amp I can certainly attest to the extra power (room filling sound) that it provides. The actual sonic quality and detail of sound doesn’t seem quite as high as the inbuilt Anthem amp though. That was why I was curious what other Anthem owners found when plugging in a separate power amp.
Finally got an email from anthem apparently we will be getting the Imax upgrade later in November.
I bought an MCA 50 when I was using a denon 4000 AVR (as the internal Denon amps were under-powered for anything more than stereo)
I now have an Anthem MRX 720, but still use the MCA 50 - why would I go backwards...... and require the 720 to run hot.
I have done some A-B testing, but not enough to make a comment.  Especially with my old ears.
Plus, my speakers aren't hard to drive (VAF soundwall)
If someone in Adelaide is desperate for a comparison, let me know.
Benje
So "within six weeks" from the article at the beginning of September is now late November... :P
So "within six weeks" from the article at the beginning of September is now late November... [emoji14]
Yep! That is the reply I got from Anthem
Benje
Hi Benje
Did you notice the same sonic signature between the MRX720 inbuilt amp and the MCA50? What is the main difference for you? I’m very curious on this one. :)
    • By dheck
      Item: Paradigm Perfect Bass Kit or Anthem Room Correction ARC1M
      Price Range: Less than new.
      Item Condition: New or Used
      I'm looking for the calibration mic to use with PBK and ARC Genesis with a Paradigm Seismic 110.
      Prefer local to Sydney.
    • By notchasingrainbow
      Item Condition: Mint, very low hours. Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: North Melbourne State: Victoria Payment Method: EFT, Cash on Pickup. Reason for selling: Surplus Further information:
      Silver Audio Research DAC 9.
      Selling due to surplus in my system. Unit is in mint condition, very low hours of use. Serious buyers only, can check condition upon pick up. Located in North Melbourne, 5 mins walking distance from Queen Victoria Market.
      Some review articles to read:
      http://www.enjoythemusic.com/magazine/equipment/0320/Audio_Research_DAC9_Digital_To_Analog_Converter_DAC_Review.htm
      https://audiophilestyle.com/ca/reviews/audio-research-dac-9-review-r644/
    • By gwavz
      Item: Anthem AVM 60 Processor
      Price Range: $2000-$3000
      Item Condition: Used
      Upgrade time and need a processor to go along with a WTB Power Amp please! Would consider other receivers/processors. Balanced output desired, but not essential
    • By :) Go Away (:
      Hi Guys,
      Need some advise and guidance regarding the power amplifier requirements for home theatre use.
      I have Anthem MRX710 powering my 7.1 setup in Home theatre, my components are as below.
      Fronts: Ascension Summoner 863SQTL (150 WRMS, with 91 dB 1w/1m sensitivity)
      Center: Ascension 253SQ (120/200 wrms/max (@ 60Hz plus), , with 91 dB 1w/1m sensitivity)
      Surrounds: Polk T15 (20 watts → 100 watts, with 89 db 1w/1m sensitivity)
      Surround back (Ceiling mounted): Micca M-8C (100 watts, with 90dB 1W/1M sensitivity)
      Subwoofer: Martin Logan Dynamo 600x
      Room size: 4m x 3.8m (Acoustically treated with Acoustic pin boards, Martini Absorb HD50 on all 4 walls with carpet on the floor, ceiling untreated.)
      I like loud volumes when watching movies to get the same feel and punch one gets from commercial theatres. However, I have never gone past -10db volume level with Anthem, as I find other members of the household start complaining before I even get a chance to listen at reference level. This is for mainly HT use, I do occasionally listen to two channel music but it is not my main stereo listening room.
      Some demo audio at close to reference level sounds amazing and feel like increasing the volume even more, however I find some movie scenes at the loud volume seems to be bit distorted or somewhat incoherent that I find the need to turn down the volume. I am not sure, if this is the limiting factors of Anthem's power amp stage or just room acoustics.
      So far, Anthem has been the best AVR, I have ever had and Sound quality is really really great. Lately, I have been questioning, if I should add a power amplifier to the mix, and if I did, will there be much improvements to the sound quality vs the money spent? I am mainly thinking about adding 2 or 3 channel amp for front stage. I have seen countless posts on the net where people suggest adding power amp to AVR to boost the sound quality, given the Anthem MRX710 driving 7 channels, I don't think it outputs more than 80-90 watts per channel.
      Will adding power amp to my setup give me better bang for buck?
      As for the budget, It is very limited at this stage and I am thinking somewhere the range of $1000 for 3 channels. Unfortunately, most in this range are somewhat at the same power rating as the Anthem or less, that I think will not make much difference adding them.
      What do you guys recommend, Is power amp really necessary and will it be a better investment? if so, what amps would you recommend to go with Anthem MRX710?
      Anthem's MCA325 is an ideal choice to match with Anthem MRX but at $3600, it is way out of budget for me. Should I get some inexpensive amp now or perhaps I should save up and go for it when budget allows and be done with it or I am looking at this at wrong way and should perhaps target my speakers. I am quite happy with the front stage, my surrounds are cheap speakers, but they do their job.
      What has been your experience when adding the power amp to relieve AVR of some of the channels?
    • By :) Go Away (:
      Item: Anthem MRX-510 or above any model
      Price Range: $700 +
      I am looking for Anthem MRX receiver from model MRX510 and above range, basically 7 channel AVR.
