Hallelujahs hallelujah ad infinitum.
I got it to work! On both my mrx 700 and mrx 300!
I bought a serial cable from Altronics ($9).
Updated the amps firmware via said cable.
Downloaded most recent Arc 1 software.
Windows 10 recognised and installed the microphone.
Only hiccup was me ignoring the microphone calibration file.
When I finally located the microphone calibration file and put it in the Anthem folder - hey presto.
So Brisbane, Gents, it can be done! I’m happy to assist or lend out any of the equipment I used.
And a big Thankyou Snoopy8 Sensei.
Hi guys, I may move from Denon to Anthem in the future for my next AVR (MRX-720 most likely).
Can it be configured for Atmos top middle only position in a 5.2.2 or 7.2.2?
Just wanted to close out my ARC issues from my earlier posts. Turns out there was no issue with my MRX300 receiver or ARC1 kit. My issue appears to have been with an older PC which said my microphone was installed correctly but then would not run ARC. As soon as I tried a different PC ARC worked perfectly. My receiver is now nicely calibrated for my strange shaped room. Big thank you to forum member Spoctordock for assisting me with my diagnosis. If you are having similar problems with ARC I would recommend trying a different PC if you have access to one. :)
Now off to watch ‘Logan’ for the second time! 😃
So I received my Tripp Lite Keyspan USB to RS232 converter, installed its software and hey presto... My AVM 50 is now found by my PC (Windows 10) and ARC COMPLETELY works.
Anyone know if the sweep tones can be volume adjusted? Seems the receiver goes into a config mode but I dare say it's sweeps aren't at 75dB but more like checking out reference peaks. With highly efficient speakers this unfortunately made across the street have to hear the tones... [emoji51]
I can say at first glance (well, first listen, technically speaking) comparing ARC adjustments on vs off I am impressed.
The low end of the dialogue and vocal body is really evened out across the entire front soundstage.
I let it do full spectrum (up to 5K adjustments). I know some expert tips discuss setting the Max EQ to 300hz - which might be quite valid.
However I find my FR very flat above 600hz onward so the minor adjustments probably aren't hurting the phase or wave form too severely but I will compare this much more over the weekend.
Opening up that discussion - - are there any sneaky tweaks on ARC people recommend such as Max EQ?
No ability to adjust volume. Buy some flowers or chocs for neighbours. :lol:
There are tweaks in the first post.
Geeks Guide to using ARC-2 (Secrets of Home Theatre)
Super Geek Guide to Tweaking ARC-2 (Secrets of Home Theatre)
Good to hear ARC finally working.
Hi guys! Proud owner of AVM 60 here.
I read somewhere in this thread you can store upto 4 different profiles of loaded settings from arc2.
Will that be on SAVE/LoAD SETTINGS
under = save user settings
Load user settings
Reset on the fly adjustments
Load factory default
Thanks in advance.
Guest DarkNark
Have you run ARC yet?
If I remember correctly, when you run ARC you will have some tabs that you can rename and alter the settings as you require. I have a MRX510 so I only have two tabs and thus two profiles, but later generations allow four profiles. Once you finalise ARC and upload the settings the 2/4 profiles will be available to choose in the menu.
@Snoopy8
Load user settings
Congrats!  Those are settings for the AVM60 itself
Dave is spot on.  You need to run ARC on your computer. It guides you though steps.  Also, have a look at some of the info in the first post of this thread and post questions if stuck
https://www.stereo.net.au/forums/topic/231088-anthem-av-owners-thread/
Bit jealous of the multiple profiles!! I'm on AVM 50 so ARC1 for me... [emoji51]
Congrats and enjoy. It's great gear.
If only they did a D2 Statement 4K!
Load user settings
Thanks in advance.
I have been only using 5.1 since last year and it already sound awesome.Every time I have guests and hears my system they always say it sounds better than the movie house.
Last week i added 2xparadigm surrounds and use the mobile arc to calibrate 7.1
It work alright with no hiccups.
Tested the sound and it sounds very good.
I haven’t watched a movie yet.
But I’m already looking forward when it comes.
You didn't consider going 5.1.2 instead? Or the model you have doesn't do Atmos? Personally if I had to choose between the two, I'd take the overheads.
I have the AVM 60.
And yes I am considering Atmos,and that will be my next project.
I’m thinking of using four KEF Q50a instead of bouncing it to the cieling I’m going to mount it directly into the cieling.
Or get it professionally done with Atmos speakers with dynabox.
I just don’t know yet which of the two option is the best .
Wondering if this is still the current firmware version or is there a new software upgrade?
19 hours ago, jomjom said:
I have the AVM 60.
When I was researching, I was building my room from scratch, and I just didn't end up going with in ceiling. After a lifetime hearing how important enclosure design and constructions it to sound reproduction, it seemed antithetical to just stick them in the ceiling. Plus I was insulating every cavity, so I'd need to build baffle boxes or go the dynabox route. Plus the cost of decent in ceiling speakers. So I ended up getting kef q100s (when they were clearing out speakers a year or so back) and mounting them on brackets aimed at the seating position. I've never regretted it. It is hard getting decent brackets though.
So I'd definitely agree with your idea of mounting Kef q50a's on the ceiling. That would work pretty well and neater than the q100s on brackets. The q50 is basically the same speaker as the q100, same driver - just a better enclosure on the 100 - hence the better frequency response from the same speaker. Eg the 100 is 49hz at -3dB where the q50 is 96hz at -6dB (which means at -3dB it is probably looking like 110hZ). Which just proves my initial thoughts on the importance of enclosure on the sound...
You can get the q100s still about the same price too.
Ok thanks.
I’ll get my wife to download and extract for me.
On 02/03/2018 at 12:02 PM, betty boop said:
I understand this is the case, have seen mentioned before,
"If the AVM 60 looks a lot like Anthem’s top A/V receiver—well, essentially, it is a de-amplified edition of the brand’s 11.2-channel MRX 1120 (reviewed last month), at a $500 savings and with all-channels balanced (XLR) preamp outputs where the speaker outputs would otherwise be"
Read more at https://www.soundandvision.com/content/anthem-avm-60-av-processor-review#K1rwLiQ8jemxjGYy.99
If the  AVM 60 is a de-amplified version of the MRX 1120 at a $500 discount, are most people getting the MRX 1120 over the AVM 60?
$500 for a amplifier seems a good buy???
sergeant just depends what you are chasing i guess. id personally pick up a rotel 1075 or better 2nd hand for similar money- you wouldn't be able to fit amp like that in an avrs casing. amps have never been more affordable... there is a elektra theatre 7 going for $1200 in classifieds, and a theatre HD went for $2k... these weighs more than AVRs around ! better heat sinking and more gutsy power supply genuine power house with the veritable iron fist in a velvet glove.... and no concerns of power claims or anything there with power reserves on tap.
Dont get me wrong, i have owned AVRs myself even gutsy ones ... also used AVRs as pre processors .... and some including talking about I'd easily recommend in that role. where come in is if say want to still use a gutsy amp for main channels and say the built in for surrounds or heights and such. and there is also the approach of external channels altogether which some take as well.
many roads ... :)
The AVM 60 also has a better power supply and better analog circuitry.  The MRX 1120 is a convenient 1 box solution but does compromise on the amplification.  Anthem used to publish the power output when driving 5 channels, but sadly now hide behind the misleading power when only 2 channels are driven.
If you want a better HT experience, then AVM 60 + multi channel power amplifier is the way to go.  However, the MRX 1120 is a good compromise when space, WAF etc..  needs to be considered
Thanks for your ideas, betty and snoopy.
I've always thought that separate pre and power are better but when you look at the MRX 1120 vs AVM 60. Similar price and very similar components, but you have to spend another $3k+ to get a reasonable power amp if you got the AVM 60.
I have power hungry Krix speakers but fortunately, I still have my Emotiva XPA-5 Gen I (which I bought for < $1000 in the good old days). However, this solution, I will lose by 7.1 setup and have a 5.1 instead. This is why the dilemma to get the MRX 1120.
Why not get a 2 channel power amp?
Just in case you are interested...
Still waiting for ARC Genesis to come online
Yeah, I'm interested to see what the Arc genesis is like. Not that I have any issues with the current arc!
On the AVM60 vs 1120, I have the 1120, and have no complaints. My HT room isn't that large. My speakers are all kef Q series, with 4x 900's plus others.
An all in one is just easier and if you don't already have the 11 channel amp to spare or want to have a stack of X channel amps.
Plus I never really figured how you control the volume with a pre  / post amp. Do you lock the amp at a fixed volume? Max volume? Or what?
    • By kerisabe
      Item Condition: Mint, very low hours. Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: North Melbourne State: Victoria Payment Method: EFT, Cash on Pickup. Reason for selling: Surplus Further information:
      Silver Audio Research DAC 9.
      Selling due to surplus in my system. Unit is in mint condition, very low hours of use. Serious buyers only, can check condition upon pick up. Located in North Melbourne, 5 mins walking distance from Queen Victoria Market.
      Some review articles to read:
      http://www.enjoythemusic.com/magazine/equipment/0320/Audio_Research_DAC9_Digital_To_Analog_Converter_DAC_Review.htm
      https://audiophilestyle.com/ca/reviews/audio-research-dac-9-review-r644/
    • By gwavz
      Item: Anthem AVM 60 Processor
      Price Range: $2000-$3000
      Item Condition: Used
      Upgrade time and need a processor to go along with a WTB Power Amp please! Would consider other receivers/processors. Balanced output desired, but not essential
    • By :) Go Away (:
      Hi Guys,
      Need some advise and guidance regarding the power amplifier requirements for home theatre use.
      I have Anthem MRX710 powering my 7.1 setup in Home theatre, my components are as below.
      Fronts: Ascension Summoner 863SQTL (150 WRMS, with 91 dB 1w/1m sensitivity)
      Center: Ascension 253SQ (120/200 wrms/max (@ 60Hz plus), , with 91 dB 1w/1m sensitivity)
      Surrounds: Polk T15 (20 watts → 100 watts, with 89 db 1w/1m sensitivity)
      Surround back (Ceiling mounted): Micca M-8C (100 watts, with 90dB 1W/1M sensitivity)
      Subwoofer: Martin Logan Dynamo 600x
      Room size: 4m x 3.8m (Acoustically treated with Acoustic pin boards, Martini Absorb HD50 on all 4 walls with carpet on the floor, ceiling untreated.)
      I like loud volumes when watching movies to get the same feel and punch one gets from commercial theatres. However, I have never gone past -10db volume level with Anthem, as I find other members of the household start complaining before I even get a chance to listen at reference level. This is for mainly HT use, I do occasionally listen to two channel music but it is not my main stereo listening room.
      Some demo audio at close to reference level sounds amazing and feel like increasing the volume even more, however I find some movie scenes at the loud volume seems to be bit distorted or somewhat incoherent that I find the need to turn down the volume. I am not sure, if this is the limiting factors of Anthem's power amp stage or just room acoustics.
      So far, Anthem has been the best AVR, I have ever had and Sound quality is really really great. Lately, I have been questioning, if I should add a power amplifier to the mix, and if I did, will there be much improvements to the sound quality vs the money spent? I am mainly thinking about adding 2 or 3 channel amp for front stage. I have seen countless posts on the net where people suggest adding power amp to AVR to boost the sound quality, given the Anthem MRX710 driving 7 channels, I don't think it outputs more than 80-90 watts per channel.
      Will adding power amp to my setup give me better bang for buck?
      As for the budget, It is very limited at this stage and I am thinking somewhere the range of $1000 for 3 channels. Unfortunately, most in this range are somewhat at the same power rating as the Anthem or less, that I think will not make much difference adding them.
      What do you guys recommend, Is power amp really necessary and will it be a better investment? if so, what amps would you recommend to go with Anthem MRX710?
      Anthem's MCA325 is an ideal choice to match with Anthem MRX but at $3600, it is way out of budget for me. Should I get some inexpensive amp now or perhaps I should save up and go for it when budget allows and be done with it or I am looking at this at wrong way and should perhaps target my speakers. I am quite happy with the front stage, my surrounds are cheap speakers, but they do their job.
      What has been your experience when adding the power amp to relieve AVR of some of the channels?
    • By :) Go Away (:
      Item: Anthem MRX-510 or above any model
      Price Range: $700 +
      Item Condition: New or Used
      I am looking for Anthem MRX receiver from model MRX510 and above range, basically 7 channel AVR.
    • By flipswitch
      I’m a bit confused about this now, because I’ve gotten different answers.
      I am using the HDMI arc connection ( it’s the only HDMI out) (Denon avr-x1600h) connected to the HDMI arc on my tv ( Panasonic fz950 OLED  (which is full bandwidth)
      I have my 4K blu ray player and PS4 Pro connected to my avr HDMI ports.
      When I’m playing a 4K movie with Atmos on my blu-ray player, am I getting it down-converted to something lower quality, or full lossless atmos?
      I understand that playing something from my tv, eg the Netflix app, I wont be able to get Atmos.
       Eg;
      When playing a movie with atmos connected to the  HDMI ARC port of my tv, my AVR says Dolby Atmos – True HD.
      Now when playing it on the HDMI non arc port, it says the say thing, Dolby Atmos -True HD.
       Everything sounds the same.
