loser
2017 JVC Projectors
39 minutes ago, jutta said:
That's usually where lag is discussed, around gaming.
But not always. I need to dial in more than 300ms audio delay to sync with video playback.
Wouldn't that be your amp and not the PJ?
What he said
I'm not sure what you and the other guy are on about. I delay audio in my HTPC software player because video lags significantly from my X7000 projector.
That 300ms is considerably more than a typical avr can manage I must say Satanica ; I hope its easy to judge as it can be a bit of a pain to dial in close when lips are just not right ..  denons as an example can delay up to 200ms [ handily by input ]  and a dvdo duo vp I had was similar manually but had an auto setting very thankfully :)
Quote
 Precision AV LipSync
Eliminates audio-video sync problems. Automatically adds precise delay so audio and selected video are perfectly synchronized. User-set audio delay up to 200 milliseconds can fix sync errors with cable, satellite, etc.
Here is some AV Sync Test Files I made a while ago.  There is one for all the major frame rates as AV Sync can be different depending on the refresh rate you use.
AVSyncTestPatterns
AVSyncTestPatterns
Thanks, with JRiver Media Centre can set audio delay for (24Hz) and (50Hz, 60Hz) separately.
Yup - Just another of the many great Video Features of MC (disclosure - I'm an Admin on their forum).
I thought your name looked familiar.
Thanks Richard at ozts. Got my X9500 today.
Got the Oppo 203 hooked up directly. Latest firmware. Looks amazing in HDR mode.
Downside my Marantz AV8801 suddenly doesn't play any audio.
Connecting another cable from the 8801 to the X9500 nada no picture even from a non 4K PC source on the X9500. It isn't the HDMI port. Or the cable. So something about the Marantz just isn't sending video to the projector.
Waiting for the 8802A to arrive next week.
Ps is there a special setting in the 203 to output video on HDMI1 and audio on HDMI 2 outputs? Can't seem to find it.
Also where is the low lag mode in the menus? Can't seem to find it.
I was getting worried my Marantz AVP had decided to give up.
So I labeled the cables - and unhooked the Marantz. I figured I should do that with the 8802A on the way.
To see if my Marantz was still working, I had no choice but to unbox the Sony Z9D. Downside of the cheaper prices in Australia - no installation. Doing it on my own was not an easy task. Needed the wife to help slot the TV into the stand. Thank goodness for the air conditioning.
The good news is the Marantz 8801 still shows a signal to the Sony. Next step, try the Oppo direct to the ZD9 and see how the opening sequence on Star Trek looks.
The ZD9 looks good but honestly I don't think at 65" and literally 1.5m away I can see a difference in 4K resolution. The JVC on the other hand shows a much bigger improvement in apparent resolution.
The good news is that reconnecting the Marantz and Oppo to the JVC, audio is back so it must just have been an earlier glitch.
I know I know. We can't really tell anything with screenshots. Too many variables. But it was sooo pretty.
wait till the 8802A comes. with the 8801 might have to play with edids on the jvc inputs, 8801 was pre 4k uhd spec and the 9500 might not like it !
should be able to send audio out one port though video the other. was the whole idea of dual ports...
I think when I unplugged the 8801 for a while the HDMI handshake seemed to have worked.
Shame the photo is anything but.
Will be ordering the 5500 next week sometime and a 130 inch scope screen to boot and the 8802a.Bloody excited is an understatement.Waiting to be stunned after owning a projector not even capable of native 1080p for the past 10 years or so.And I will be posting pics if that's ok with the police.Painted the theater black and now can not see 1 foot in front of me with the lights on.Running cables at the moment for my big change and looking forward to becoming a member of the JVC eshift club.
Have you confirmed the 8802A?
It won't handle Dolby Vision. And Marantz has been very evasive if it will.
The 7703 and the rest of the 2016 ones have been confirmed to support DV though.
If you can wait the 8802 will be replaced at the end of 2017.
Or look for the Yamaha 5100 or AVM60. Both have been promised DV firmware update.
Not that the JVC will handle DV either. But if you ever get a TV that does.
Hey doggiehowser, yea I have been advised on the DV thing but only need the 8802A via projector in my theater room so all is good there mate.I won't be splitting hairs between DV and whatever else.As long as I can move forward with atmos and utilise my Audyssey pro kit I will be happy mate.The projector will be a huge step up for me so that combined with the bigger screen and atmos is basically where it's at for me on a overall plain.
Congrats Doggie as I would of loved the 9500 but needed other stuff also.What size screen are you using mate?
120" 16:9
I'm happy with how the Marantz 8802A sounds.
Don't get me wrong.
But having known what I know now, I can't in good conscience recommend it to others.
Anthem's Room EQ is also very highly regarded.
I might still go for the 8804 or 8803 when it comes out but having just bought the 8802A and needing to replace it so soon is painful
with a projector DV is a non concern, unless running dual displays or anything id stick with the 8802A. atleast get a audyssey pro capability with it rather than the plastic uncalibrated mic and cardboard rocket and phone app they intend to supply with the 8803/4
22 minutes ago, doggiehowser1503564764 said:
120" 16:9
Don't get me wrong.
Fair enough mate.I can only begin to imagine the nice depth in your image on a screen that size with the 9500.sounds like a nice pairing.I will be buying off Oz theatre screens also.
Hi al, by the way thanks for your help mate on the DV thing as it has saved me from spending extra cash when there is no need too,so thanks for that.I find it a little unfortunate for the people who have paid for a top of the line product like the 8802 and not have it get the DV upgrade.Anyway I will take my chance on it as it has all the bells and whistles.If I want DV in the future then I will buy a cheaper unit for the lounge room and let the cheaper unit do the work instead of my wallet.I won't be throwing money at these companies for nothing anymore only to be shown the door.
The weird thing is that Dolby Vision is designed to be dynamic in terms of brightness support which would lend itself to projector use really well, where 1000nits of 120" would burn your Retina [emoji51]
I suspect DV on projectors might take later to appear but not out of likelihood.
