linds1234
Bizarre Problem- with a solution.
Hi All,
3 weeks ago my reception for all of the Channel 7 range (Physical ch6) and most of Channel 9 went from 10/10 (Signal Strength and Quality) to 0/10 Quality (Ch7) and 4/10 Quality (Ch9). Whilst the signal strength remained at 10/10.
Steps I took to fix it:
- Replaced the masthead amp
- Cleaned all the contact points of the existing antenna
- Tried an LTE filter (which was a reach)
- Tried a new antenna with a different radiating pattern.
- Raised the antenna 1.5M
- Pointed it to an alternative broadcast tower
Came to the conclusion that I had a multi-path propagation issue. So the next step was to play around with antenna placement for a better spot.
But before I do that, I thought I'd turn off the Server PC, with this suspicion that it *might* have a faulty PSU. Sure enough, PC off = perfect reception on all channels. Then it dawned on me, 3 weeks ago I installed 2 new case fans in there: https://www.amazon.com/Antec-Tricool-Speed-120mm-Case/dp/B00314W992
Turns out one of them was faulty, causing EM interference through the mains.
A-single-faulty-case-fan.
Will never get that diagnostic time back! Thought I'd share it in the hope that it helps some other poor soul in a similar situation.
Lindsay
Nice one and good troubleshooting steps.  Yes interference can be a very annoying issue.
