Z2TT
HSTC / Master STC logging plan question
Hello.
I require to do some logging using my Master STC / Hills HSTC.  I have been reading through the user manual that mentions how to do a log,
But I'm not sure how to enter the transponders that I want to be logged, they are mainly on C1/D3.  Can I enter these transponders that I want to log
directly to a meter or do I need to enter them using the computer program for the HSTC?
In terms of retrieving the log files, are they stored in a common format that can be read with MS Excel?
Or do I need to export them using some sort of program?
Any advice is appreciated.
Download the S.M.A.R.T software from the Hills or Rover website.
Hills site http://www.hillsantenna.com.au/Support/~/media/Hills Antenna/Software/ROVER SMART PRO programm ver 5_46.ashx
Rover require a login to download the software from their website.
Hills have version 5.46 on their website, Rover has Version 5.75.
Also, the "logging" feature won't continually log the transponder measurement/stats. It will run through the transponders in the current plan and store the results in a file on the unit. You can then use the SMART software to retrieve the file and then export if you want.
Edited by CMatten
a>This is a sample screenshot showing what is exported to Excel
This is a sample screenshot of the logged data within the S.M.A.R.T software.
As Cmatten says use smart, the easiest thing to do is setup a channel plan for whatever you want to log ie the 8 foxtel transponders  required for commisioning and then it will just log those rather than the 32 + transponders
On 9/10/2017 at 1:28 AM, Gary cunningham said:
hi can i save site reports on the meter and download to smartsoftware to give a report to my customers
Use the logging option on the meter. Then connect to your PC/Laptop and download the logs using the SMART software. Let me know if you need me details.
