petetherock
Oppo Uhd 4K Player
2 hours ago, Quark said:
Perhaps it's intended that the region free mods move to external USB type as some did for the previous models.
The rest looks like very much incremental changes on the analog side.
yes be interesting what region freeing options pop up, now being released. and yeah doesn't look like anything bar incremental changes on the analog side.
This isn't a scientific calibrated measurement test but I figured since I had both the Panasonic 900 and the Oppo 203, I'd swap them over to see how they fared.
I had just watched Star Trek 2009 UHD and Deadpool UHD on my JVC X9500 and the Oppo 203 combo and using Kris Deering's recommended settings on the X9500, it looked superb.
So I decided to put in some key scenes on the Panasonic for comparison.
The Panasonic also had a Dynamic HDR slider which a lot of guys in AVS recommended setting at +4 on the JVC Z1/RS4500. I know it is not a like for like comparison but I figured I'd give it a try.
My first impression with Dynamic HDR at default was that the image looked softer overall on the Panasonic. In the opening logos down to the detail on the actors faces - lots of close ups in the opening scene of Star Trek.
Then I switched the Dynamic HDR to +4 - which appears to raise the black level - so there was more detail in the shadow details - my go to scene is Scotty's black jacket when he is running through the darker parts of the engineering deck just before he and Kirk are cornered by security. I think there may be a bit more detail in the jacket but in the preceding scene, Bones and Spock are having a private conversation and I noticed how smooth Spock's face was. Switching down the Dynamic HDR to 0 restored the pores in his skin so I am not sure if I want to use the Dynamic HDR slider all that much. But even then I felt the Oppo looked marginally sharper.
My plan was to eventually use the Panasonic with the JVC and the Oppo with the Sony ZD9 - because the latter combo are supposed to get a Dolby Vision update later on but I may eventually get an Oppo 205.
good stuff doggie to explore for yourself. re the jvc, rather than using others settings, and dont know what kris deering setting using, but have you got the RM files ?
http://rmadvancedcaldisc.com/rm-uhdhdr-10.html
essential for basic setup I'd suggest :)  if nothing else will make sure dialled in :)
3 hours ago, :) al said:
first under hood shot I've seen of the 205,
can compare with the previous 105D's innards,
some changes apparent, one curious thing the new toroidal in the 205 no longer comes metal encased ? and bare instead ?
also no apparent connector for region free on the 205, so likely as with the 105 have to be pulled apart for an internal install.
There are benefits..
You cant see it there but on the website the USB is now better supported for DSD and PCM is up to 786khz.  They also advertised they have circuit to reduced jitter in audio for  HDMI.
From those pic the PSU has been significantly changed to the 2 channel audio pcb not just the transformer.   Where there's WIMA caps for what looks like PSU rail decoupling they have been changed to SMD around the opamps.   There are advantages of doing this, all beneficial technically as well as cost savings.    Where there's individual diodes for a bridge rectifier there are now 3 individual full wave bridge rectifiers, SMDs of course.
Funny how the ESS 9038 is white in that pic!
there is one odd quirk with the hdmi in that both hdmi audio and video have to be used if wanting the jitter reduction :) not really sure how that is implemented in practice :)
https://www.oppodigital.com/blu-ray-udp-205/blu-ray-udp-205-Features.aspx
it explains it in the specs.
I wonder if InterDyn in Melbourne has stock to go, since it is likely that Oppo Digital was waiting till intercontinental distributors to have stock, that seems how they have done it in that past. The parent company in the US have "Buy Now" showing, but the Aussie not yet. Maybe tomorrow?
yeah the only way i can see that setup is being used for music only as they suggest there, i.e. for pcm and dsd source and then id have hooked up for std dmi for movies i.e. audio and video.  it interests me the hdmi audio only and jitter reduction aspect as what benefit that might bring :)
probably worth checking with them, the lifestyle offer which I received via email said arriving may. people in the us are receiving or received already :)
There's a 1GB RAM in the 105 that helps to buffer the data of the HDD via USB that's not there on the 205.  Perhaps because the 205 uses the USB 3.0 and they believe it's not necessary to include it....Im just guessing!  Better to send an email to query that.
Not sure whether we see this as a bonus but they talk about interference etc etc etc and then there's the 802.11AC built in!   The 105 had a dongle but wasn't up to 803.11ac standards, well the 802.11ac wasn't standard back when the 105 was released.
Edited by Addicted to music
Do you see a lot of takers especially with all the issues the 203 has had, then there the $2200 rrp, possibly discounted to $1999 for early adopters?
yeah am still wondering why they have taken the power supply casing off it !  many makers with sensitive low signal level circuits tend to put casings on !  but anyways perhaps they worked out there wasnt an adverse effect in removing ?
I ws referring to the built in 802.1ac.....
i wonder what that effect will have on the audio...being internal.
not unusual to have wifi capability in things these days e.g. the marantz processor has it. however they did remove the network switching hub off from the previous model to improve things noise wise.
At least with the transformer you can take the cover off and do a DIY shielding with say some copper tape!  Or even better still find out whether the 105 transformer is compatible which looks like it is, but don't assume.
I suppose 5GHZ wifi is beyond the human hearing capabilities. :D
I am waiting for JVC to fix their Auto Cal software and get a sensor.
I saw that disc and it does appear to work well for a friend's X7000. The nice thing is that the X9500/7500 really looks pretty good out of the box and it is takes very few clicks to get it right which is what Kris had recommended - out of the box, it was just a little dark. I took some screenshots of the menu settings but I don't remember an owners thread here so I didn't post it.
    • By BMC HiFi
      Item: Loewe Reference 55 - UHD 55" (4K) TV (Price Drop)
      Price: $10,999 StereoNET Special $7,300 $5,500
      Item Condition: Shop demo, as new with original remote, carton, etc.
      Reason for selling: Demo Sale
      Payment Method: Pickup - Cash, COD
      Bargain, Priced to sell!!
      Preferred over OLED
      All Original packaging and accessories.
      4K UHD - 3840 x 2160p
      55 Inch - Width(34.9" 88.6 cm) x Height(19.6" 49.8 cm)
      Smart TV - Perfect for Netflix
      HDMI x 4
      USB Input x 3 - For media playback
      Extra Details below and from the Loewe website: https://ww2.loewe.tv/au/bild/loewe-reference
      Loewe is acknowledged as a specialist manufacturer and this is their top television model, the Reference, in a 55” size model. It is hand made in Germany with features that are not found on standard sets.
      Effortless Perfection.
      The new Loewe Reference sets exceptionally high standards. An achievement made possible by a perfectly synchronised performance: A crystal-clear Ultra-HD picture combines with outstanding quality sound from Loewe's unique integrated soundbar. A timeless modernist design meets ultimate convenience, thanks to the integrated hard disk recorder and Bluetooth audio streaming.
      Ultra High Definition ... for the best picture.
      The UHD display is combined with Loewe's unique glass high contrast filter panel, delivering even richer colours and deeper blacks - for a truly special picture. For TV broadcast signals that do not yet meet the UHD standard Loewe's up-scaling algorithm converts from the currently available Full HD 1,920 x 1,080 pixels in a seamless process ensuring visibly enhanced details and the clarity of Ultra HD 3,840 x 2,160 pixels.
      Loewe 3D Active Shutter ... for even more depth.
      From outer space to jungles or oceans … Sometimes, you want to truly immerse yourself in the action unfolding on your screen. Loewe's 3D Active Shutter technology brings images alive with vibrant detail - and not just for 3D content. Algorithms work invisibly behind the scenes - calculating which picture content should appear at the front and back - to transform even 2D content into an impressive three-dimensional home cinema experience.
      High-resolution art ... with the LUMAS app.
      The new LUMAS Gallery app takes art into the digital dimension - and opens up new horizons. It allows you to enjoy selected works of art by internationally renowned artists - such as the Cuba series by the Stuttgart-based photographer Werner Pawlok - in high-resolution Ultra HD quality on your television screen. The LUMAS TV app is available on the new Loewe Reference TV home screen, so you can start selecting pictures straight away - using the Loewe remote control. Browse photographs, graphics, illustrations, digital art or paintings. When you find a picture that appeals, you can display it as a fixed image (for a maximum of 24 hours) or enjoy as part of a slide show.
      Quality Sound
      The Loewe Reference has a sound quality to rival even high-end hi-fi and home cinema systems: tangible bass, vivid middle, precise highs and an exceptionally wide dynamic range – the traditional hallmarks of Loewe Sound. The Loewe Reference sets particularly high standards. An integrated soundbar with eight speakers generates crystal-clear sound with a rich 120 watts of music output. In combination with the specially designed bass reflex box and integrated 5.1 audio decoder with Dolby Digital and DTS, the result is an impressive home cinema … and a perfect home concert hall. The Loewe Reference's cinema surround mode conveys amazingly authentic surround sound. At the touch of a button, it also allows you to switch between film and music mode. Special algorithms calculate the optimal overall sound setup for each situation: as powerful as possible while retaining sensitivity – ideal for cinema buffs and music fans.
      Loewe Mobile Recording ... any time, any place.
      You're stuck in traffic or can't get away from a meeting...you won't make it home in time for your favorite programme. You're out with friends...and you suddenly realise your weekly drama is about to start. The Loewe Reference takes the stress out of situations such as these. Loewe Mobile recording allows you to easily record programmes on the integrated Loewe DR+ 1 TB hard disk, even if you don't happen to be at home. Leaving you free to enjoy your favorite programmes at a more convenient time! All you need is a smartphone and an Internet connection. Simply open the new free Loewe Smart Assist app, select the program from the programme guide and press 'record'... Your Loewe TV will then take care of the rest. When you get back home, you can even watch your recorded programmes on your patio, or tucked up in bed using a tablet computer.
    • By HDobsession
      Item: Epson EH TW9300W projector
      Price: $2700 ono
      Item Condition: Immaculate
      Reason for selling: Upgrade to Epson 9400W
      Extra Info: less that 300hours (thought it was 100 where did the time go?) on the globe absolutely immaculate projector. Amazing 4K enhanced images.  Has been installed on ceiling mount so no bumps, scratches. It looks new. With warranty until 23rd June 2020! Includes a bonus new globe! Includes receipt for warranty.
      Includes
      - Projector TW 9300W
      - Extra globe (brand new in box)
      - 2 pairs of Epson 3D rechargeable glasses
      - Wireless transmitter (basically unused)
      - Warranty with receipt until June 2020
      - Power cable
      - remote
      I am more than happy to answer any questions. I'm only selling because I'm looking to upgrade to the next model. This unit is in perfect condition.
      SOLD
    • By Jabz10
      Selling my Sony VPL-VW520ES Native 4K Projector
      https://www.trademe.co.nz/Browse/Listing.aspx?id=1489613893
      Happy to sell privately.
    • By oztheatre
      Item: The all new native 4K Sony VPL-VW270ES 4K Cinema Projector (new 2019 model with all new lens) and Majestic Screen package is now available.
      Genuine Australian stock! This model is available in black or white.
      Groundbreaking price for native 4K cinema projection!
      RRP at $10,317 based on package with 100 inch Majestic Screen at full RRP.
      With 2 RF 3D Glasses and premium Majestic Evo4K Screen and top of the line Peerless geared projector mount!
      Priced From: $8289 inc GST and delivery Australia wide.
      Payment Method: Pickup - Direct deposit, cards 1%.
      Extra Info: This model doesn't have the lens memory feature that the 570ES has, however it has motorised zoom, shift and focus so you could use a 235 screen, it would just take a little longer to switch between formats when required.. perhaps 30-40 seconds using the remote. Otherwise a 16:9 format screen would mean no changing sizes or messing around with the remote.
