petetherock
Oppo Uhd 4K Player
The other thing I have noticed is that the 203 does not have a Ejection LED light on it to see where the ejection button is in the dark
Agreed, guess they expect us to just use the remote eh?
My Glass door is closed when using so Me thinks if the Oppo disk opens it will damage the Player as the glass is thick and heavy and the player will lose
On 2017-6-20 at 5:42 PM, Addicted to music said:
http://hometheaterhifi.com/reviews/video-player/blu-ray/oppo-udp-205-4k-ultra-hd-audiophile-blu-ray-disc-player-review/
finally we have some distortion plots...
OPPO top of the line players have always measured well.
Anyone else notice that both the hometheaterhifi.com and the http://hometheaterreview.com/ advertise the OPPO 205 on their sites or is it just me with my cookies?
Edited by Seandres
Stop raiding the cookie jar...
My player keeps telling me there is a FW update available.  When I try and update server is unavailable?????
I didn't realise there was already another FW update.
You can download it HERE
Then do it via usb.
Just now, blairy1503559527 said:
Yupp, it's up on the interdyne website.  Downloading now
Just make sure you take note of the warning about which FW you're currently on before you try to install this one.
Thanks Kazz.  I'm on 0605 and it won't let me update via internet or usb...
OK well that's weird.  :huh:
updated here no probs straight off the net. i imagine they have incorporated the hdmi handshake fix they sent me a beta for .... heres hoping anyways :D
I notice ast night our Oppo 203 has HDMI hands shark issues. I notice this as I was testing the Harmony and the Problem I have with the both Oppos turning on and both two have different Codes.
have you done the latest update. as no handshake issue with my pioneer kuro at least. havent checked the projector as yet :)
but if having some issue. even after the update be sure to contact oppo to advise. and dont take any blow offs from oppo devotees blaming all your other gear and harmony and logitech and what not !
I contacted Oppo last night about there issue with the Both of the Opppo's (103d and 203) turning on with different codes numbers
1 minute ago, Blackman1503561291 said:
The last update I did was 10 days ago.( I forgot the Number was it was)
you would need the very latest. I've been running a beta for couple of weeks or so that fixed the handshake issue the last one created. I got all sorts of fob offs from the oppo chorus on avs. contacted oppo locally, had to do some testing of things for them and send them quite a few oppo logs it records and next day they got a fix for me. and its been fine since. I would be very surprised if the fix hasnt come through with this current update. and confirming it has worked fine with the kuro with this update. will confirm with the projector once get enough of a chance to check over.
good to hear !  i would load and run the very latest updates to see if helps you.
one quirk i have found is after an update for the first time....the harmony wont jog the oppo from sleep. have to use the oppo remote. after that... it will work fine to power down and power up again with all other gear. its not a big issue for me. and works reliable past that very first time after an update.
Edited by :) al
Going Shopping today and I will be back later this arvo. I will updat the Oppo and I will test both oppa again for this problem I have with Code 1 and 2. A tleast we get the handshake issue done now because the TV was doing funny things last night trying to connect.
This issue with both the Oppos i can do with just both of the Original ir controllers. No need the Harmony. If it works with an firmware update with the two original ir controllers it will work with the Harmony
Thanks Al
Edited by Blackman
Lastest relaease for the 203 & 205 was on the 26th of June here's what Oppo say about it....
Comparing to the previous Official release version UDP20X-45-0605, the major changes included in this version are:
  1. Added the “Track Type” descriptor when playing an SACD.
  2. Improved HDMI handshake stability when playing Dolby Vision content.
  3. Improved HDMI audio stability when using an HDMI Split A/V connection.
  4. General fixes and disc compatibility improvements based on recent and upcoming UHD Blu-ray releases as well as user-submitted samples.
However I can report that both my Oppos set to different channels on the remote still act as one when either remote is used to turn one on or off so that issue remains as before in fact since release of the 203 as far as i can tell and I'm not using a harmony which if some one is looking for one PM me.
Here's the details of the latest FW update for these two Oppo players andd what Oppo say they do.....
I sent a Email to Interdyn about this issue and he repled to me but he tells me that "quote" The gentleman said "but I don't believe that this can be resolved by changing any settings on the device. In fact, I think it would require a change in the way the units are built in order to preserve these settings".
If this is the case It would be the only device that you cannot use independently. I have Multiple Vu satellite Decoder at home, I have 3 Dreamboxes also at home and all have their own CODE number to make them independent and you can program all with different Codes and ALL operate separately.
Can any other member on this forum that has the Oppo 103D or even a 103 and also the Oppo UDP 203 try this and report your findings.
Bman I don't run two oppos but am confused why thus is even an issue going on. Surely you are not alone as oppo user with two units. @Kazz has two units not sure if responded how utilising?
Isn't the separate code selection yjere exactly for the case where have two units. Ie that clash in remotes ?
Yep I am running the 203 and 83 in the same system and previously the 203 and 103d (until I moved the 103d to the bedroom system and 83 to the ht system) I've had one occurrence of the harmony turning on both players but not the Oppo remotes doing the same.  Am not sure what's going on in your system but I suspect it has something to do with the power being switched off when they're not in use.
    • By mfroes
      Hi guys,
      I would really appreciate any guidance.
      I have front right/left speakers which are 6ohm 250w (nominal)
      central, rear left and rear right are 8ohm 150w (nominal)
      My amp is at the moment struggling to push all those speakers so i was wanting to upgrade.
      budget wise i think up to about 1k would be something for a 5 channel (just guessing here), if more how much more would be needed ?
      would there be one the would be HDCP 2.2-compliant ?
      if some that have atmos capability so i can buy some speakers and add in the future would be great.
      so would be 5.1.2 i'm guessing here?
      would a 7.1.2/7.2.4 be better ? havent seen a lot of bluray that comes with 7channel capability like that.
      the 7 i see usually are counting the atmos speakers.
      Thanks in advance for reading and for any suggestions that comes my way.
      Current Setup
      Receiver: Yamaha HTR-3066
      Front: NHT C4
      Centre: Gale 20
      Rear: Axis LS28
      Subwoofer: Sound Dynamics THS-10
    • By nheron
      Item Condition: As New Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Kurraba Point State: New South Wales Payment Method: Paypal gift, Bank Transfer, Cash on Pickup Reason for selling: Bought a smart TV Further information:
      One Google Chromecast Ultra in as new condition (no box). Bought brand new from The Good Guys late 2019. Have since bought a smart TV so don't need the streaming capabilities of the Chromecast.
      Shipping to anywhere in AUS is included in price.
    • By lordvader82
      Item Condition: Lightly used Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Reservoir State: Victoria Payment Method: Paypal Reason for selling: No longer used Further information:
      I purchased this player while saving up for a meatier 4k player. So I no longer need this
      Lightly used. Resonable offers considered.
    • By lordvader82
      Price: $120 Item Condition: Used Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Reservoir State: Victoria Payment Method: Paypal Reason for selling: No longer required Further information:
