petetherock
Oppo Uhd 4K Player
49 minutes ago, duke said:
Did you reset factory defaults and also try erasing persistent storage:?
Yes, more than once.
17 hours ago, BuffySlayer said:
So I just updated to latest firmware via USB.
Previously, of the 4 latest 4k discs I'd tried, 2 worked and 2 would not. They'd spin up for over 60 seconds, then come up as unknown disc.
Of the 2 not working, one now plays (Black Panther), the other still does not (Avengers Infinity Wars).
Now though, instead of spinning up as Unknown Disc, it freezes the player, and I get a blue screen and have to turn Oppo off and on again.
Ironically, all discs work perfectly on my much much much cheaper Sony UBP-X700 that's in the lounge room 😡
Packing this up tonight, this thing is a lemon.
So disappointed after having a 105D that worked perfectly.
Anyone know if I need to send it back with power cord? (I'm thinking no)
Hi BuffySlayer, over AVS Forums they often recommend cleaning discs with these sort of issues.  I know it sounds stupid; they even recommend this for brand new discs!  Something to do with UHD manufacturing process leaves residue on some discs.
I've had issues over the past ~26 months with only two discs.  Wonder Woman was one.  Cleaning the discs worked for me 🙂
I use paper towels and white vinegar.  Damp the towel, clean from centre to edge all the way round.  Then dry the same way with another dry towel.
Good luck
2 hours ago, BuffySlayer said:
Have cleaned all the discs. Makes no difference.
Did you try installing the new firmware again?
Packed up and shipped back to Interdyn, will be interesting to see how/what they do to fix it.
Just been advised player is on its way back to me after having main board replaced. I have everything crossed 🤞
Well it turns out crossing your fingers doesn't fix a lemon.
Got player back today and obviously the first disc I tried was Infinity Wars, as it was the one that wouldn't spin up before.
Tried twice, Oppo went to blue screen and became unresponsive to any command. Had to turn off and on again. So I cleaned the disc again, and tried a 3rd time, same result. On the 4th attempt, a small, short-lived miracle happened and the disc spun up. I watched about 5 minutes, then stopped the movie and went back to the main menu. Upon selecting the disc to play again, you guessed it, blue screen.
On the bright side, I managed to watch a movie tonight, just wasn't the one I wanted to watch.
Another annoyance is that the fault on the repair paperwork listed the random slow motion and chapter menu popping up, but nothing of the much more detailed information I'd provided about the ticking noise of the laser and overly sensitive disc reading. Did they even check the disc reading mechanism? Who knows.
I've emailed Interdyn to ask for a replacement or a refund. Not happy Jan 🤬
I've had to send my Oppo back to Interdyn because I started getting many 4k discs constantly glitching yet they worked fine in my Panasonic.
First time they replaced the main board and that didn't help so they then replaced the loader.
From what I read on the AVS forums Oppo overseas always replaced the optical reader and that fixed their problem.
From the many emails I sent them with all the issues, I'm disappointed that they didn't replace the optical reader as you mention. Looks like they've gone for the cheapest fix first.
Edited by BuffySlayer
Additional information
I'm flabbergasted they didn't test it before they sent it back to you!
Well they said they did test it, but probably not that particular disc. As I noted previously, the fault on their report was just the intermittent slow motion issue, but no mention of the far more common issue of disc reading issues the player has had, going back to when I first purchased it. I've had to send them multiple files for discs that wouldn't play, which would then be fixed with a firmware update, but no one else seemed to have these issues, and I repeatedly told them that the reader would make ticking noises. Bloody frustrating as hell.
That's what I think  too seeing in my emails I sent them links to quotes that said how Oppo had fixed the problem overseas yet everything they did here didn't fix a thing.
Imagine, what are you gonna do if in a year time or so the Oppo suspended or no longer support for the Oppo Bluray Player which they're no longer making them...
very unfortunate to hear. sloppy service... nothing much else to say. locally they can be quite variable. one fruit loop I was dealing with at interdyn initially when had the 203 I strongly felt I might as well be putting my comments on post it notes on the back wall of the house so they could blow away with the wind. complete waste of space. the actual tech I was in contact with when I logged a problem though was fantastic responsive and had a firmware update initiated to fix issue I had in early days straight way. I've had no problems with the 205 since purchase and surely I hope and wish you can get to point where its the same to. can you take video footage. I would with smartphone and send it to them so you have proof of issue. shouldn't have to but its plain pathetic and a waste of everyones time and their money to with just doing half fixes rather than a complete fix as seems is needed here !
Well I've just received an email saying that the problem is likely to be the disc, and all the disc issues experienced are due to the manufacturing process & can only be fixed with a firmware update. In fact they are "99% it's not the disc reader"!!
Well, I politely disagreed, and pointed out that if it is the disc, why does it play fine in other players? And if I have to rely on a firmware update every time I buy a new disc, how long until my player is nothing but a paperweight?
I then pointed out that the only fix, both here and overseas, has been to replace the optical reader. I really want to punch someone right now.
    • By Stephen0804
      Item: LG UP970 4K HDR Blu-ray player
      Price: ~ $200 O.N.O.
      Item Condition: Very Good, not used often
      Reason for selling: got a new tv and am upgrading to get the features i require
      Extra Info: supports Dolby Vision and hdr, has Youtube and Netflix apps.
      would have to check if i have original box but i have everything that came with it.
    • By zakblue
      Item: Seiki SE39UY04 4k UHD 39" TV/Monitor
      Price: $175
      Item Condition: Good
      Reason for selling: NLR
      This tv/monitor is an early iteration of 4k (no HDR). It supports 4k at 30hz only.
      It also does 124hz at 1080p so great as a large gaming monitor with low input latency.
      It's an 'in between' size so if you've got a medium room it will likely work well for you.
      Local Pickup only.
      Reviews here:
      https://www.amazon.com/Seiki-SE39UY04-39-Inch-Ultra-Discontinued/product-reviews/B00DOPGO2G
    • By BMC HiFi
      Item: Loewe Reference 55 - UHD 55" (4K) TV (Price Drop)
      Price: $10,999 StereoNET Special $7,300 $5,500
      Item Condition: Shop demo, as new with original remote, carton, etc.
      Reason for selling: Demo Sale
      Payment Method: Pickup - Cash, COD
      Bargain, Priced to sell!!
      Preferred over OLED
      All Original packaging and accessories.
      4K UHD - 3840 x 2160p
      55 Inch - Width(34.9" 88.6 cm) x Height(19.6" 49.8 cm)
      Smart TV - Perfect for Netflix
      HDMI x 4
      USB Input x 3 - For media playback
      Extra Details below and from the Loewe website: https://ww2.loewe.tv/au/bild/loewe-reference
      Loewe is acknowledged as a specialist manufacturer and this is their top television model, the Reference, in a 55” size model. It is hand made in Germany with features that are not found on standard sets.
      Effortless Perfection.
      The new Loewe Reference sets exceptionally high standards. An achievement made possible by a perfectly synchronised performance: A crystal-clear Ultra-HD picture combines with outstanding quality sound from Loewe's unique integrated soundbar. A timeless modernist design meets ultimate convenience, thanks to the integrated hard disk recorder and Bluetooth audio streaming.
      Ultra High Definition ... for the best picture.
      The UHD display is combined with Loewe's unique glass high contrast filter panel, delivering even richer colours and deeper blacks - for a truly special picture. For TV broadcast signals that do not yet meet the UHD standard Loewe's up-scaling algorithm converts from the currently available Full HD 1,920 x 1,080 pixels in a seamless process ensuring visibly enhanced details and the clarity of Ultra HD 3,840 x 2,160 pixels.
      Loewe 3D Active Shutter ... for even more depth.
      From outer space to jungles or oceans … Sometimes, you want to truly immerse yourself in the action unfolding on your screen. Loewe's 3D Active Shutter technology brings images alive with vibrant detail - and not just for 3D content. Algorithms work invisibly behind the scenes - calculating which picture content should appear at the front and back - to transform even 2D content into an impressive three-dimensional home cinema experience.
      High-resolution art ... with the LUMAS app.
      The new LUMAS Gallery app takes art into the digital dimension - and opens up new horizons. It allows you to enjoy selected works of art by internationally renowned artists - such as the Cuba series by the Stuttgart-based photographer Werner Pawlok - in high-resolution Ultra HD quality on your television screen. The LUMAS TV app is available on the new Loewe Reference TV home screen, so you can start selecting pictures straight away - using the Loewe remote control. Browse photographs, graphics, illustrations, digital art or paintings. When you find a picture that appeals, you can display it as a fixed image (for a maximum of 24 hours) or enjoy as part of a slide show.
      Quality Sound
      The Loewe Reference has a sound quality to rival even high-end hi-fi and home cinema systems: tangible bass, vivid middle, precise highs and an exceptionally wide dynamic range – the traditional hallmarks of Loewe Sound. The Loewe Reference sets particularly high standards. An integrated soundbar with eight speakers generates crystal-clear sound with a rich 120 watts of music output. In combination with the specially designed bass reflex box and integrated 5.1 audio decoder with Dolby Digital and DTS, the result is an impressive home cinema … and a perfect home concert hall. The Loewe Reference's cinema surround mode conveys amazingly authentic surround sound. At the touch of a button, it also allows you to switch between film and music mode. Special algorithms calculate the optimal overall sound setup for each situation: as powerful as possible while retaining sensitivity – ideal for cinema buffs and music fans.
      Loewe Mobile Recording ... any time, any place.
      You're stuck in traffic or can't get away from a meeting...you won't make it home in time for your favorite programme. You're out with friends...and you suddenly realise your weekly drama is about to start. The Loewe Reference takes the stress out of situations such as these. Loewe Mobile recording allows you to easily record programmes on the integrated Loewe DR+ 1 TB hard disk, even if you don't happen to be at home. Leaving you free to enjoy your favorite programmes at a more convenient time! All you need is a smartphone and an Internet connection. Simply open the new free Loewe Smart Assist app, select the program from the programme guide and press 'record'... Your Loewe TV will then take care of the rest. When you get back home, you can even watch your recorded programmes on your patio, or tucked up in bed using a tablet computer.
    • By HDobsession
      Item: Epson EH TW9300W projector
      Price: $2700 ono
      Item Condition: Immaculate
      Reason for selling: Upgrade to Epson 9400W
      Extra Info: less that 300hours (thought it was 100 where did the time go?) on the globe absolutely immaculate projector. Amazing 4K enhanced images.  Has been installed on ceiling mount so no bumps, scratches. It looks new. With warranty until 23rd June 2020! Includes a bonus new globe! Includes receipt for warranty.
      Includes
      - Projector TW 9300W
      - Extra globe (brand new in box)
      - 2 pairs of Epson 3D rechargeable glasses
      - Wireless transmitter (basically unused)
      - Warranty with receipt until June 2020
      - Power cable
      - remote
      I am more than happy to answer any questions. I'm only selling because I'm looking to upgrade to the next model. This unit is in perfect condition.
      SOLD
