SteveF1975
Panasonic Th-P50G10A 10 Blink Error Code
Hi
I have a Panasonic TH-P50G10A
It has the 10 blink error code
I've tried the reset with no luck.The back is now off, nothing really obvious except there is a slight bulge in one of the 220V 1400uf capacitors on the PS.Don't know if this is the cause of my problem.All the fuses on the PS have continuity.
I'm searching to see if I can find some direction to go from here.
Any help would be appreciated
Caps are an easy and often simple fix.
Change it out as it's worth a try
99% of the time it's one of two things...... Caps or board
Obviously you need to hope caps. And older models it's that simple most of the time
Ps - match the voltage. Doesn't matter if you up the uf as its power storage capacity....... I was told.
Edited by Jutta
According to the Service Manual, a 10 flash error is associated with the A Board...
try "bleeding the caps"
hold power button for 30 seconds with TV unplugged to power
(if that actually works then your caps are on the way out)
Edited by mello yello
Hey Mello
Is this where you have been hiding
Cheers MB
:thumbsup::D
Ive been here for blinking years, absolute years, been over the edge for yonks
speak to me
