Chris Dowling
Point To Point Tv
Can definitely be done but will require either a dedicated commercial solution for iptv or raspberry pi and xbmc type solution. I'd be worried about sufficient bandwidth. If you can run optic fibre data and tv should be a doodle fibre is a lot cheaper than what it was and much faster than wifi even using a dedicated apn and won't need a bunch of raspberry pi units abs external tuners configured to stream to other raspberry pi units. Coax degrades much faster than fibre. You can run data and tv and numerous satellite services down the one fibre. You can even get the ends preterminated. I'd hate tti set it all up and find I don't have the bandwidth to do several HD channels.
Edited by andrewlace
Hey Chris, How did you go with this one.... IF the guy is only doing it so no birds land on his roof then his kidding himself that they won't anyway...
If the guy has unlimited funds (you get them) then a commercial IPTV solution is your best bet. but $$$
