TVfishing Posted May 5, 2015 Share Posted May 5, 2015 There used to be a site for RV-ers to find TV towers whilst travelling. It was straight forward and easy to use. Cannot find it anymore. Help! Link to comment Share on other sites More sharing options...
Colin Matten Posted May 6, 2015 Share Posted May 6, 2015 This one? http://laceys.tv/dtv-map.htm Link to comment Share on other sites More sharing options...
alanh Posted May 6, 2015 Share Posted May 6, 2015 (edited) A much better link is the one from the source of this information. It includes the channels used on that site as well https://myswitch.digitalready.gov.au/ and type in your location. It also tells you the direction in which to point the antenna and whether it should be horizontal or vertical. Alanh Edited May 6, 2015 by alanh Link to comment Share on other sites More sharing options...
Tazzy2Heads Posted May 6, 2015 Share Posted May 6, 2015 Hi Guys and Gals The Laceys map doesn't show the correct channels after the re-stack, tx site locations seem to be ok. Cheers Tazzy Link to comment Share on other sites More sharing options...
I am not a duck Posted May 6, 2015 Share Posted May 6, 2015 There used to be a site for RV-ers to find TV towers whilst travelling. It was straight forward and easy to use. Cannot find it anymore. Help! Ahhh, do you mean this one? Link to comment Share on other sites More sharing options...
alanh Posted May 7, 2015 Share Posted May 7, 2015 As I said get your info from the source. The transmitters are licenced by the ACMA which is part of the Department of Communications and it owns the Myswitch website. Alanh Link to comment Share on other sites More sharing options...
