doobie1
Projector Ceiling Mount - Recommendation.
http://www.ebay.com.au/itm/Universal-Projector-Ceiling-Mount-Bracket-Any-Home-Theatre-Projector-30kg-Level-/201255030250?pt=LH_DefaultDomain_15&hash=item2edbbc0dea#ht_1670wt_1362
Howdy,
(Firstly, sorry, but I can not see how to put a link in the usual way (copy/paste), so the above was via the "code" symbol - so hope ok - just couldn't work it out - the "link" symbol didn't have 'ok' highlighted).
Anyway, is the above type of ceiling mount ok for an Epson tw8200 that has 34cm between screw points and weight of 8.6kgs.
I'm sure it is, and I would be using it as a low profile (without the extension pole) but wondering if it may be subject to 'wobble'.
Or is there a better one around that is 'cheap'. Most I see have arm extensions to 33cm ,but mine needs 34cm.
Thanks for any thought.
I use peerless mount for my jvc x500, but thats expensive.
Edited by Sub25
Thanks Sub25 but the Sanyo is a little higher in price than I wanted at this stage - and especially the peerless :)
Thanks Jamo8 for putting the link in your post (I still can't work out how to).
Kabo search didn't come up with anything.
Might just get the universal one - should hopefully be stable enough (no wobble).
Thanks for your troubles guys.
