ranant
Mitsubishi Vlt-Hc5000Lp Projector Lamp
I have a Mitsibishi HC4900 and i think the lamp has expired.Any suggestions on the best place to get one.Aust preferably.
Regards Richard
Before i rush out and buy a new lamp,can i be sure this is the problem.Has worked fine for 5 years-about 1500 hours on the lamp-received no warnings about lamp life.Now wont start up.Both buttons go green for a period when turned on and then i get power steady red and status flashing green.Then both go out .Any ideas
Regards
Richard
Regards
Richard
Rich, good call. See below, call them. Best to learn what those lights mean, do you have the manual? any ideas from that?
Technical Support
For technical support for Mitsubishi Electric products contact us on:
Tel: 1300 651 808 and press option #3 for air conditioning & refrigerator technical support
press option #4 for projectors and Diamond Digital product technical support.
Fax: (02) 9684-7684
Email: technicalsupport@meaust.meap.com
And service centre locator here http://www.mitsubishielectric.com.au/repairers.html
