dawatson69 Posted May 24, 2014 Share Posted May 24, 2014 Hi all, A question for the X35 owners, what mounts do you all recommend? Cheers Link to comment Share on other sites More sharing options...
dawatson69 Posted May 24, 2014 Author Share Posted May 24, 2014 Sorry Chopsus, you might have to explain yourself a little better, for dummies. Thanks Link to comment Share on other sites More sharing options...
bassmaniac69 Posted May 24, 2014 Share Posted May 24, 2014 Peerless is the brand and B & H are the best people to buy from, although Amazon also do them as well, at least they did when I was looking for a mount Link to comment Share on other sites More sharing options...
Quark Posted May 24, 2014 Share Posted May 24, 2014 See here and here. Use the pole mount type if possible to keep your projector off the ceiling to reduce heat on hot days. You want one of the PRG models for precise adjustments. Link to comment Share on other sites More sharing options...
