bohn Posted October 11, 2013 Share Posted October 11, 2013 (edited) I'm designing a new house with a home theatre. Was thinking about a room 4.5m wide by 7m long (9 foot ceilings). Wanting to have speakers behind an AT screen .. I have looked a few different calculators but they often give different results. I am guessing I can fit a 120 and possibly a 130" scope screen on the 4.5m wall? There will be only one row of seating about 1 metre from the back wall. Taking this into account (and the fact that the speakers need room behind the screen), do you think 7m is too long? Should I make the room 6.5m or 6m? Thanks. ps: I know distance to screen size can be subjective.. heh, for reference I sit in the middle of a movie theatre, not right at the front/back Edited October 11, 2013 by bohn Link to comment Share on other sites More sharing options...
Quark Posted October 11, 2013 Share Posted October 11, 2013 A good rule of thumb is for the seating to be back from the screen about 3 x screen height. A 130" scope screen is ~1280mm high, so seating would typically be ~3.84m back, before accounting for personal preferences (mine's about 4m back from a 130" scope screen). For that sized room you might consider a bigger screen e.g. 150", subject to light control, screen gain and projector lumens. Link to comment Share on other sites More sharing options...
Storm AV Posted October 11, 2013 Share Posted October 11, 2013 Just ordered a 170" screen for a 5m-w x 9m-l theatre. I'm with quark at least a 150, depends on the projector you are thinking of. My customer wanted to make final screen decision after projector was installed-big benefit was main speaker placement was done after screen size was decided on keeping things clean. Link to comment Share on other sites More sharing options...
Eli Posted October 11, 2013 Share Posted October 11, 2013 I made my HT similar dimensions, 4.5m wide and 8m long (1m used behind screen though). I'll be going a 150" scope screen. If you have one row I would go that size, as you have plenty of room to move the seating. Link to comment Share on other sites More sharing options...
bohn Posted October 12, 2013 Author Share Posted October 12, 2013 Thanks guys u've been helpful Link to comment Share on other sites More sharing options...
