cr1key Posted April 10, 2015 Share Posted April 10, 2015 Update to my post above: the repair didn't fix the problem afterall. The dimming/flickering reappeared soon after. Back to Electron Flow. This time the power supply has been replaced. Only watched it for a few hours but so far so good. The "MAB" that was replaced last time was the motherboard. (Maybe MAB was a typo for M/B.) Seems the new optical engine they put in last time has worse focus uniformity than the original, which is annoying given it's likely nothing was ever wrong with the original. Doesn't seem possible to get both the top/center and bottom in sharp focus. Link to comment Share on other sites More sharing options...
deathsbreeze Posted November 27, 2016 Share Posted November 27, 2016 tw9100 Has anyone had problems with faint bright spots when the picture goes black/dark? like when there is a screen saver going? just shows as a very faint grey Link to comment Share on other sites More sharing options...
deathsbreeze Posted December 1, 2016 Share Posted December 1, 2016 (edited) Had a closer look at the lens to see if i could spot anything but no luck. I did notice that when i held my remote in front of the lens the bright spots have a green tinge to them. So im thinking the problem lies with one of the LCD's in it. Does anyone know if the LCD's have separate colours eg red for one green for the next etc? Edited December 1, 2016 by deathsbreeze Link to comment Share on other sites More sharing options...
Quark Posted December 1, 2016 Share Posted December 1, 2016 2 hours ago, deathsbreeze said: Had a closer look at the lens to see if i could spot anything but no luck. I did notice that when i held my remote in front of the lens the bright spots have a green tinge to them. So im thinking the problem lies with one of the LCD's in it. Does anyone know if the LCD's have separate colours eg red for one green for the next etc? There will be red, green and blue. As mentioned elsewhere, sounds like a dust blob. Link to comment Share on other sites More sharing options...
deathsbreeze Posted December 2, 2016 Share Posted December 2, 2016 Hope so.....Time to tinker Link to comment Share on other sites More sharing options...
Quark Posted December 2, 2016 Share Posted December 2, 2016 36 minutes ago, deathsbreeze said: Hope so.....Time to tinker Haven't done this, but I think a can of compressed air is recommended. Link to comment Share on other sites More sharing options...
deathsbreeze Posted December 2, 2016 Share Posted December 2, 2016 Went to remove my projector but cant find the bloody tamper-proof allen-key for the ceiling mount. Will go buy a set tomorrow. While i was up there i took a picture of a blank screen on white paper. The large blob may be dust, but the lower one has a pattern in it. There is also a second pattern spot near top left of large blob but its focus point is further away. I have a compressor with adjustable pressure to give it a blowjob tomorrow.......... Link to comment Share on other sites More sharing options...
deathsbreeze Posted January 13, 2018 Share Posted January 13, 2018 Wow didnt realise its been so long since i was on here. Any way, i pulled the projector apart and cleaned it out. Think it was dust as its almost all gone now. Now i have another problem, i get a vertical green line showing up on the left side of the screen (top to bottom, about 15mm wide 30cm in on a 125" screen). It comes and goes, will get a pic next time i see it.Any ideas? Link to comment Share on other sites More sharing options...
deathsbreeze Posted December 27, 2022 Share Posted December 27, 2022 Bit of a dead thread these days? 9100 has been kicking along, slowly getting more green lines (1 has turned red a few times) but we just ignore them. Have replaced a few globes (even had a non-genuine explode after 2000h). Just had a genuine globe die Xmas day and only 15 months old. So I had a look on here and AVS browsing projector chat. A good amount of chat about the TW-9400. Had a browse at prices and saw most were $4500+. Then stumbled on one for under 4k. . . Nuff said! 1 Link to comment Share on other sites More sharing options...
