chefscuba70
Sydney Audio Club Meeting.... Sun 14Th Oct. Genelec, Drawmer
Hi all,
For anyone interested, your welcome to come along and join us.
The October 2012 meeting of the Sydney Audio Club sees us once again at Dence Park for an afternoon of fine music and sound and convivial company.
Each month, the Sydney Audio Club presents the finest in high end audio systems for our members and guests. It's a bit like a private audio show once a month where you can hear and discuss equipment that you might not otherwise have the chance to audition. And you can bring along your own music to test the capabilities of the system or to just share with like-minded music lovers in a friendly and relaxed atmosphere.
This month we will have a system presented by Steven Spurrier of Studio Connections Australia (refer to http://www.studioconnections.com.au). Studio Connections Australia is the Australian distributor for some highly renowned and respected brands of audio equipment. Their brands include: Genelec, Bricasti Design and Drawmer. (All the equipment on the day will be provided by Studio Connections Australia.)
This month we will have a system comprising Genelec and Drawmer products.
The speakers will be the Genelec 8260A and 8240A models (please refer to http://www.genelec.com). Genelec have been manufacturing professional studio monitors since 1978 and have recently introduced home theatre and installation product ranges.
The Genelec 8260A is a three way active system which combines a coaxial driver (MDC™) with the advanced Genelec Directivity Control Waveguide™ (DCW™), ensuring drivers couple coherently over their full operating bandwidth as well as creating coincident mid-frequency/high frequency point source. (Drivers are 3/4” tweeter, 5” midrange, 10” woofer). The 8260A features an internal digital active crossover, accepting inputs from 32 to 192kHz. Total amplifier power is 390W per speaker.
The Genelec 8240A is a two way active system which features a flow optimized reflex port that provides solid, clear and articulated low frequencies without compression, distortion or port noises. It is also combined with the Genelec Directivity Control Waveguide™ (DCW™), and has rounded edges and gently curved front and sides of the MDE™ (Minimum Diffraction Enclosure™) enclosure. (Drivers are 3/4” metal dome tweeter, 6.5” woofer). The 8240A also features an internal digital active crossover, accepting inputs from 32 to 192kHz. Total amplifier power is 180W per speaker.
The Genelec Loudspeaker Manager™ (GLM™) software manages the Genelec DSP signal processing responsible for all loudspeaker functions, such as the crossover filters, driver equalizers, driver position alignment, room response alignment, calibration and equalization related filters as well as distance compensating delays. Carefully designed DSP crossover filters with extremely steep roll-off characteristics feed dedicated power amplifiers for each of the low distortion drivers. The Genelec Loudspeaker Manager (GLM™) control network and software features adjustment of levels, distance delays and flexible room response improvement equalization with the reliable and robust AutoCal™ automated calibration system via the GLM™ control network.
We will also be featuring the M-Clock Plus AES Grade 1 Master Clock/Dual Sample Rate Converter from Drawmer (http://www.drawmer.com/products/dms/m-clock-plus-master-clock-src.php).
M-Clock Plus is a high stability master clock generator offering clock rates from 44.1 to 192kHz, coupled to two sample rate converters, which allow material to be re-sampled and synchronised to the selected high precision clock. In addition to the internal clocks, M-Clock Plus can sync to either external word clock or clocks from AES/EBU signals. Precision clock frequency measurement and display indicates the exact frequency of the selected clock, whether internal or external, to an accuracy of 2ppm.
M-Clock Plus has an external word clock input and an AES11 input which retrieves the clock from an AES audio signal. Each sample rate converter has selectable AES, SPDIF or TOSLINK inputs, with simultaneous AES, SPDIF and TOSLINK outputs. This allows many possibilities for format conversion as well as sample rate conversion. Sample rate converter #2 has inputs on the front panel for easy access. Provides user selectable word length of 16 or 24 bits with automatic dither generation – particularly valuable for 16 bit word lengths at low signal levels. There are 10 word clock outputs - 8 at the rear and 2 at the front for easy access.
Note: also of interest from Studio Connections Australia are Drawmer's HQ Precision Pre-amp / DAC and the Bricasti M1 DAC – http://www.bricasti.com/m1.html. Neither of these will be on display or available in our meeting however.
Sources will be all digital this month, sorry no vinyl. Steven will be providing an Audio Alchemy DDS Pro/DTIPro32/DDEV3.0 CD transport, which has both AES/EBU and COAX outputs. We will also have an Oppo BDP-95 player for DVD-A and BluRay discs (provided by a member) for playing members and guests music. Playing SACD discs will be possible but less desirable due to the enforced DA conversion in the player – the signal must be then later reprocessed via ADC which means there is a lot of processing.
For this meeting, both music sessions will be BYO after Steven’s demonstration session. Members and guests are welcome to offer music to share with us all. So bring along your favourite music on CD, DVD-A and BluRay. All we ask is that the music and recordings be interesting. We'll ask you to tell us a little about the artist/recording before it is played. Tracks over 6 minutes will be faded out, to give everyone a fair go.
Whether you are a novice or a seasoned veteran, you will have the opportunity to listen, learn and share your experiences with others of a similar mind.
Members and Guests welcome – we are a very friendly club so you don't need to know anyone to join us for an afternoon of fine music and sound. We will welcome you at the door.
Venue: Epping Creative Centre
Address: 26 Stanley St, Epping
Doors open 1pm
Meeting starts at 2pm
Best regards,
Tom Waters
President
Sydney Audio Club
www.sydneyaudioclub.org.au
tomwaters@sydneyaudioclub.org.au
how did things go ? any pics from these gtgs ? :)
Hi Al,
Yes, sorry, I've been hopelessly behind with everything. Been too much happening lately but have finally transferred and sorted out my photos.
The meeting kicked off with a talk by the presenter about speaker placement and frequency responses within a room. There was alot of detail explained with graphs displayed on the screen that got a little complicated to follow at times and raised many eyebrows as to what was being suggested as most of it went against conventional audiophile thinking.
As you can see from the photos, one debated concept was the placement of the speakers up against the back wall, which is a no no by most, but the presenter said that by doing this, you received free bass gain and explained that if the speaker was a metre off the wall, you would get a lower frequency cancellation from it bouncing off the wall and could not be corrected by equalisation, (graphs were shown of the results). The Genelec Loudspeaker Manager software corrects the bass boom and brings all other frequencies back to a flat response regardless of the rooms issues.
We got to here the difference with the EQ on and off. When off, the sound was very messy with obvious boom and no imagining. When switched on, the sound re-focused and became balanced, though this was better, I found it did veil the highs some and overall there was a lack of depth to the soundstage but as these are used nearfield in studios, it's not a consideration I guess.
Overall, the presenters talk was well liked and found to be very informative but the equipment and sound received mixed views. Some found the sound to be great and responsive, while others thought it lacked naturalness with an over processed digital feel. I think there can be a benefit with the use of EQ in difficult rooms but only when it can't be heard in the music in any way.
Wish I'm in SYD for this :(... Will be great to experience this in person..
The only speakers I have heard so far that seem to work well when faced all the way to the back wall are LS 3/5As (The ones I heard are from Stirling IIRC), some Audio Note speakers, vintage Tannoys and JBLs. As you said when placed too close to the backwall you will loose that "sense of depth".. Making the sound seems flat (and boring). It's a win some/loose some decision.. :(
Nice summary and pics :thumbsup: .. And that master clock (Drawmer M clock) looks interesting!!! :wub: Been looking for a master clock and now I know of one more brand to research now.. Thanks :)
Very interesting there chef. Read with interest re using the back wall. The mission 753s I owned for years I found as recommended by the maker worked best with being 200mm from the back wall and had a great bass response that way. I guess comes back to way speaker designed to work some ate boundary designed and need that re enforcement for best balanced sound. But naturally loose little in soundstage depth. Give and take. Sounds like a great gtg there with maker explaining principles behind their design and illustrating in situ plus with benefit of eq etc.
    • By chefscuba70
      Hello all,
      I would like to inform every one of the Sydney Audio Club’s upcoming meetings for anyone who may be interested in attending. Each month I will post a copy of our newsletter highlighting who will be presenting at our next gathering. See post below.
      All are welcome, so please post here for more info, or see our website for calender dates, www.sydneyaudioclub.org.au/
      You don't need to know anyone to join us for an afternoon of fine music and sound.
      Hope to see you there.
      Potential Presenters:
      I’ve been a member of the Sydney Audio Club for over a year now and love it and have recently joined the committee in the role as Events Coordinator. This is a joint role with another committee member whose career background is in Pro Audio.
      Together we source and organise Home and Pro audio equipment from Distributors, Retailers, Direct to Market Companies, Representatives and our Members, to showcase their gear for the enjoyment of our members and guests at our monthly meetings held at Dence Park Creative Centre in Epping.
      The Sydney Audio Club offers companies an opportunity to present and demonstrate their equipment to the club. It could be a single piece of kit or an entire system, something new to market or an old favourite. Also we have recently updated our website to list our presenters over the last 12 months in the public area.
      Anyone interested in offering and presenting any gear at our future meetings, feel free to contact myself for further discussions. Meetings are on Sundays and openings are available from Feb 2013.
    • By TomW
      For our June club meeting … Morris Swift of OneAudio Music Systems (https://oneaudio.com.au/) will present the active µ2 speakers.  (That “µ” character is pronounced “mu” and is the Greek symbol for small or micro).   OneAudio released the passive version of their µ2 speakers a while ago and it has received acclaim from Len Wallis Audio and others.  The active version is very new.  Brad Serhan designed the cabinet and did the voicing for both the passive and active speakers.  Brad also designed the DSP in the active version.  Morris designed the electronics and amplification.
      Here is an excerpt from a OneAudio brochure which explains their design philosophy…
      “The relationship between designing equipment and verifying its performance through measurement, and the effect on what we subsequently hear, and how this is perceived, is a complex one. So much so that many audiophiles and even designers claim that you can’t measure what you hear, and implore us to simply trust our ears. At OneAudio, we unequivocally reject this. There is no doubt that such measurement is difficult, requiring new levels of accuracy, novel approaches, and new insights in interpreting the data. But it is absolutely essential if we are to consistently design equipment capable of delivering the high levels of performance and musical enjoyment demanded by us at OneAudio.”
      Morris plans to demonstrate both active and passive µ2 speaker systems, however, the emphasis will definitely be on the active version.  He’ll take direction from the audience, but he is also prepared to present on DSP technology and the issues with "digital", as well as the challenges of critical listening/evaluation and "A-B" testing.
      Morris will do most of his presenting at the beginning of our second half session (i.e. after our half time break).  He wishes that you listen to the system first without being told what you should expect to hear.  Morris would like you to first listen without influence or bias.
      The featured system will be as follows:
      Speakers (Active):  OneAudio µ2 Active speakers utilizing ScanSpeak Revelator drivers - a 5" woofer and a 1" ring tweeter.  These drivers are from the ScanSpeak premium product range and can be found in other speakers priced up to $50,000 and beyond.
      Main digital Source:  PC/Laptop supplied by OneAudio.
      CD Transport:  An Oppo BDP-105D Universal player will be used as a transport (for our BYO session only).
      Our popular BYO session will be split – it’ll be in part of the first half session, and also the latter part of our second half session.  Members and guests are welcome to offer music to share with us all.  So bring along your favourite music on CD or USB flash drives (sorry no vinyl).  NOTE that USB flash drives are preferable.  All we ask is that the music and recordings be interesting.  We'll ask you to tell us a little about the artist/recording before it is played.  Tracks over 6 minutes will be faded out, to give everyone a fair go.
      Whether you are a novice or a seasoned veteran, you will have the opportunity to listen, learn and share your experiences with others.  Feel free to come and hear the capabilities of the system, or to just share the experience with like-minded music lovers in a friendly and relaxed atmosphere.
      Guests are welcome – we are a very friendly club so you don't need to know anyone to join us for an afternoon of fine music and sound.
      Venue:  Epping Creative Centre, Dence Park
      Address:  26 Stanley Road, Epping
      When:  Sunday 18th June 2017
      Doors open 1pm
      Best regards,
      Tom Waters
      President
      Sydney Audio Club
    • By TomW
      For our April club meeting … George Fracchia of Zensati Australia (http://www.zensatiaustralia.com/) will present a superb system based around the Prism Sound Callia DAC/Preamp, along with the Technical Brain Integrated Amplifier TB-ZERO INT and the PMC MB2 SE Speakers.  The PMC speakers have been kindly supplied by Vinod and John at the LifeStyle Store in North Parramatta (visit http://www.lifestylestore.com.au/).
      The official representative of Prism Sound in Australia, Peter Orehov, will also be present.  Peter will give a presentation highlighting the relevance of the Professional Recording (studio) to the Audiophile and Hi-Fi community.
      ZenSati Australia sells the Prism Sound Callia DAC/Preamp to the Hi-Fi and Audiophile community.  Technical Brain products are also available through Zensati Australia.   PMC products are available through the Lifestyle Store.
      The system will be as follows:
      Prism Sound Callia DAC/Preamp.  Jason Kennedy at the the-ear.net said… “Prism Sound’s reputation preceded it when it finally entered the domestic hi-fi business earlier in the year [2016]. The Cambridge based company has been making converters for the studio market since 1987 and its top pro DAC is a cult product amongst those in the know. PMC founder Peter Thomas has one in his main system for instance, and he’s tried more than most in his quest for digital audio ecstasy.”  Refer to http://www.prismsound.com/hifi/products_subs/dac1/dac1_home.php and http://www.the-ear.net/review-hardware/prism-sound-callia-dacpreamplifier.
      Technical Brain Integrated Amplifier TB-ZERO INT.  Highly respected, ultra-high performance products from Japan.  Refer to http://www.zensatiaustralia.com/2013/01/technical-brain-tb-zero-integrated-stereo-amplifier-now-available/, http://www.technicalbrain.co.jp/stereosound-2015spring-194.pdf and http://www.technicalbrain.co.jp/index_e.html
      PMC MB2 SE Speakers.  From the Lifestyle Store website “…Meticulous attention has been applied to hone the designs to new standards, adding new internal bracing, computer-modelled driver dispersion surrounds, and custom-designed, specially tuned stands.  All these elements contribute to the production of a purer musical signal, allowing the listener to come as close as possible to the original performance.”   Refer to http://www.lifestylestore.com.au/pmc-mb2-se-three-way-high-resolution-reference-monitors.html, http://pmc-speakers.com/products/consumer/se-series/mb2-se.  Our thanks again to the Lifestyle Store for graciously providing these speakers for the day.
      Cabling will be from the products distributed by Zensati Australia which includes Vertere, Black Cat, Trinity, Dalby and of course ZenSati.
      Gryphon Mikado Signature CD player.  We will use the Mikado as the transport into the Callia DAC/Preamp.  Note that Gryphon Audio Designs is not distributed by Zensati Australia (this player belongs to a club member).  The Mikado is an excellent player with remarkable resolution, transparency and warmth.  Refer to http://www.gryphon-audio.dk/m/product-information/heritage-products/mikado-signature/reviews for reviews.
      Note:  We will also have an Oppo BDP-105D Universal player on hand to allow the playing of USB flash drives during our BYO session.  We will be using the Oppo only as a transport into the Callia DAC.
      The second half of the music sessions will be our popular BYO.   Members and guests are welcome to offer music to share with us all.  So bring along your favourite music on CD or USB flash drives (sorry no vinyl).  All we ask is that the music and recordings be interesting.  We'll ask you to tell us a little about the artist/recording before it is played.  Tracks over 6 minutes will be faded out, to give everyone a fair go.
      When:  Sunday 9th April 2017
      Doors open 1pm
      Best regards,
      Tom Waters
      President
      Sydney Audio Club
    • By TomW
      For our March club meeting we’ll have Leighton Holloway of Holloway Sound present his Carmen loudspeakers.  Leighton is a Sydney based bespoke speaker manufacturer.  He previously worked as an audio installer and for many years as an audio engineer.  He’s been building speakers for many years for family and friends, and in 2014 he decided to turn it into a business.  When he isn’t in his workshop nowadays you’ll find him rehearsing or gigging with his funk band (he plays bass).
      Leighton is enthusiastic and knowledgeable of all aspects of speaker design.  He designs and builds his own cabinets and cross-overs.  And he designs and builds to order, so if you have a particular configuration in mind, Leighton can likely build it.  All are handmade bespoke speakers, made in Sydney by Leighton himself.   Refer to http://www.hollowaysound.com.au/home-1.html
      The system will be comprised of some of the following gear.  On the day, we’ll evaluate which combination sounds best in our room.
      Holloway Sound Carmen speakers.   Stand-mount 2-way speakers.  Very good transparency, linearity and tonality without harshness.  Leighton will also show a pair of Carmen’s that are partially built so you can see the excellent build quality of the cabinets.  Refer to http://www.hollowaysound.com.au/carmen-series2.html.
      Oppo BDP-105D Universal player.  Will be used as a transport and level controller.  Refer to http://www.theabsolutesound.com/articles/oppo-bdp-105-universal-blu-ray-player-and-dac/ and https://www.oppodigital.com/blu-ray-bdp-105/
      Audio GD SA-2 DAC.  A very good sounding DAC built on the respected Burr-Brown 1704 chip.  Refer to http://www.audio-gd.com/Pro/SA/SA2/SA2EN.htm.
      Classe CP800 preamp/processor.  Refer to http://www.classeaudio.com/products/cp-800.php and http://www.stereophile.com/content/class233-cp-800-da-preamplifier.
      Plinius SA-250 Mk4 power amp.  Refer to http://www.pliniusaudio.com/Plinius_Range/Power_Amplifiers/SA_Reference.html and http://www.stereophile.com/solidpoweramps/506plinius/index.html.
      Cabling by Synergistic Research, Kimber Kable, Wireworld.
      The second half of the music sessions will be our popular BYO.   Members and guests are welcome to offer music to share with us all.  So bring along your favourite music on CD/SACD or USB flash drive.  (Sorry, no vinyl this month.)  All we ask is that the music and recordings be interesting.  And hopefully you’ll tell us a little about the artist/recording before it is played.  Tracks over 6 minutes will be faded out, to give everyone a fair go.
      When:  Sunday 12th March 2017
      Doors open 1pm
      Best regards,
      Tom Waters
      President
      Sydney Audio Club
    • By TomW
      For the January meeting of the Sydney Audio Club we are very pleased to have dedicated Sydney Audio Club member, Graham Allen, present the large reference version of Linkwitz kit speakers.   These DIY speakers are one of many products created by Siegfried Linkwitz (refer to his website at http://www.linkwitzlab.com/index.html).  Siegfried Linkwitz has over 40 years of experience in loudspeaker design, electro-acoustic system design and the perception of sound from loudspeakers in normal rooms.  (As well, his name is one half of the respected Linkwitz-Riley crossover filter).
      In our September 2015 meeting, Graham presented a pair of Linkwitz Lab LX Mini speakers.  They offer very good sound for a very modest outlay of money.
      This month, Graham will be demonstrating his recently completed Linkwitz Lab LX521 speakers.  Refer to http://www.linkwitzlab.com/LX521/Description.htm.  These unique speakers, designed by Siegfried  Linkwitz, are wide range 4-way dipoles using per channel; 2 bass drivers, lower mid, upper mid and tweeter drivers.  They should be quite capable of filling our club meeting room with a high quality, well imaged sound stage.
      Graham’s speakers are the LX521.4 4-way version with digital crossover, and are built acoustically identical to the published Linkwitz design, with some minor changes to the appearance to suit locally available materials.  The timber used is Australian river red gum, with the baffles and baffle support shelf made from solid stock, and the side supports made from marine plywood covered with 2mm veneer cut from the same plank.  The river red gum is finished in an oil based varnish.  The bass enclosures are made with marine plywood, painted with a textured satin black.  (See the photos of Graham's own speakers below this message.)
      Graham will give a brief technical description of the LX521 design approach, explain how they were constructed, and demonstrate the speakers on a range of music.  For his presentation, Graham will use his laptop with JRiver as a source (via a USB streamer to the miniDSP 4x10 processor).
      Details of the system….
      Linkwitz Lab LX521 speakers – These reference quality speakers offer articulate bass reproduction due to reduced coupling to room modes, neutral timbre and fast time response, low non-linear distortion and high instantaneous dynamic range, optimal spatial rendering of the stereo phantom image.
      Amplification –  The LX521s will be driven by an 8 channel, 180W per channel, Hypex class D amplifier, using the UcD180HG amplifier modules https://www.hypexshop.com/DetailServlet?detailID=2151 and SMPS400A180 power supplies (4 separate power supplies) https://www.hypexshop.com/DetailServlet?detailID=3140.
      Crossover duties and digital signal processing will be handled by a MiniDSP 4x10 Hd https://www.minidsp.com/products/minidsp-in-a-box/minidsp-4x10-hd.  The miniDSP 4x10 accepts digital and analogue inputs.
      Oppo BDP-105 Universal player – We will have an Oppo on hand for our BYO session.  Refer to https://www.oppodigital.com/blu-ray-bdp-105/ and http://www.theabsolutesound.com/articles/oppo-bdp-105-universal-blu-ray-player-and-dac/
      The second half of the music sessions will be our popular BYO.   Members and guests are welcome to offer music to share with us all.  So bring along your favourite music on CD/SACD or USB flash drive.  (Sorry, no vinyl this month)   All we ask is that the music and recordings be interesting.  We'll ask you to tell us a little about the artist/recording before it is played.  Tracks over 6 minutes will be faded out, to give everyone a fair go.
      When:  Sunday 15th January 2017
      Doors open 1pm
      Best regards,
      Tom Waters
      President
      Sydney Audio Club
