BigBad64
Replacement Remote For Panasonic Th-42pz700a
The remote for my mother-in-law's Panasonic TH-42PZ700A has blown up and I need a replacement. The remote model number is N2QAYB000122.
Google's only Australian conclusion seems to be Ebay where a "Panasonic Remote N2QAYB000239 (Same N2QAYB000122 ) for TV" is offered for $57.90 delivered.
Would this be right, that a different model number would do the job?
Do Panasonic sell replacements direct, or does anyone have another suggestion on the best way to go?
Cheers diesel, I'll contact the supplier listed on that website.
My elderly-immigrant mother-in-law and a Harmony remote, hmmmm, not sure how that would go to be honest.
Thanks for the reply.
Try "Speedy Spares" (speedy spares.com) they have most remotes in stock and courier overnight (my Sony PVR remote cost me $39)
Edited by KEF Ci2000
I tried Speedy Spares, they don't do Panasonic.
The official Panasonic supplier has to order it in and it was going to be $99 delivered.
The ebay supplier guarantees his remote will work and it's $57.90 delivered and is in stock - ordered.
I hope it's just a remote issue.
It was definitely stuffed as pointing it at any Panasonic TV without pressing any buttons you could see the light on the TV flashing to indicate the remote was sending a signal. I tried to pull it apart to see if anything was stuck and it ended in tears - hence the new remote.
I did do a full re-tune of the channels via the buttons on the TV, and all the digital channels were in black and white???
I'm hoping a fully functioning remote will be able to sort that out and that the TV is OK.
All my pana remotes are interchangeable
Try borrowing one to make sure it was the remote and possibly try calling your nearest repairer, with all the panel crashes there is sure to be some remotes leftover.
I use and recommend Harmony remotes, but yes, can be confusing to set up and use initially.
Have you tried one of the numerous "universal" remote controls?
I expect most (but not all) would be compatible with Panasonic TV.
Available for less than $10 online or in bargain/reject/cheap shops.
Just a matter of setting it up to suit the brand/model of TV (from its many built in codes).
Then the buttons behave as usual/expected.
Often they will control multiple devices (allowing one control to rule all/many devices) to simplify things.
Here is a genuine, but refurbished one. $29.99 including postage.
Missing battery and rear cover, but you could use your original ones.
https://www.ebay.com.au/itm/GENUINE-PANASONIC-TV-REMOTE-N2QAYB000122-NO-BATTERY-COVER-BOTTOM-FLIP-COVER/233175061431?hash=item364a5113b7:g:UccAAOSwv4FclCD6
Here is a new genuine one. Complete. $44.99 including postage.
https://www.ebay.com.au/itm/GENUINE-PANASONIC-N2QAYB000122-REMOTE-CONTROL-TH58PZ700A-TH58PZ850A-TH65PZ700A/162290368134?hash=item25c9427e86:g:WIIAAOSwKtVWx7Tl
As mentioned by duster, other Panasonic controls will probably work in place of original (though some buttons might be different/missing/additional).
Perhaps can borrow one from a friend/colleague/neighbour?
Possibly (but I do not know for sure) one such as;
https://www.ebay.com.au/itm/Universal-Replacement-Remote-Control-N2QAYB000350-For-Panasonic-Viera-Smart-TV/332724402060?epid=26021546923&hash=item4d77eb778c:g:fiQAAOSwXSRbTt-T
https://www.ebay.com.au/itm/Universal-N2QAKB000059-Remote-Control-RC-IR-For-Panasonic-Viera-TV-LCD-Plasma/263864131597?epid=21007492357&hash=item3d6f87200d:g:miMAAOSw1r5baV8x
https://www.ebay.com.au/itm/New-Replaced-Remote-N2QAYB000239-for-Panasonic-LCD-TV-PLASMA-sub-N2QAYB000122/263562028702?hash=item3d5d85669e:g:X7sAAOSw-09aHu2k&frcectupt=true
https://www.ebay.com.au/itm/Remote-Control-For-Panasonic-TV-N2QAYB000238-Same-N2QAYB000122/152987052442?hash=item239ebd299a:g:IYsAAOSw241YW0qF
Hopefully you find a solution soon.
Cheers.
