  • Replies 100
Great, thanks. I'll update my TV when I get time.
EDIT: Just updated, went through without a hitch!
The release notes don't say much and indicate only one problem correction. So, what advantage is there to upgrade?
iicap'n
I caved and bought the Playstation Blutooth remote yesterday so I can control the PS3 better while watching movies.
$34.50
It's great. Recommend it.
Off topic, recently just watched "UP", what a brilliant movie!
Sorry dude not saying anythin here...
Why..Buy the remote....Just use the TV remote...thru bravia Link That's what i do!!
QUOTE (Typhoon @ Jan 20 2010, 11:03 AM) *
$34.50
I also find the PS3 Blue-tooth remote pretty good and it works without having to point at the PS3 which is more than I can say about the TV remote.
Also did the 1.428AA update without a hitch.
Has anyone had an issue with the Z5500 (46 inch in my case) where the screen blanks out randomly for a second or 2?
What are you doing at the time...watching FTA, another source eg BD/DVD/PVR - if so how is it connected?
Ive had it happen twice on FTA and 4 times on PS3/Bluray.
On the PS3/Blu-ray its connected via Yamaha 1900rx-v receiver.
Tried different HDMI Cables also with same resultt. This has never happened on my old Sony XBR 3100.
Updated the firmware on the Z5500 also.
Sorry, haven't had this issue.
I would be jumping up and down if I were you and ask Sony to explain and then fix/replace.
In reply to previous post, I bought the remote becuase I was way too stupid to get my sync working. And my hubby couldn't be bothered to help me. For $34.50, I thought just buy the remote.
I tend to watch with subtitles as I watch movies when the bub is sleeping, so I don't wake her. Can flick on subtitles, switch on and off, get the pop up menu's etc very quickly with the PS3 remote.
Could probably also do all this using the sync, but as I have no experience with the sync, I can't comment on the difference and if the remote was really worth it.
But I do like it :)
On my KDL46Z5500, there were about 1cm thick vertical shade from top to bottom on both panel edges.
They are more obvious with plain colour screens (like white or grey).
Is this normal? I went to have a look at a KDL40Z5500 in store yesterday and same thing happen.
Bravia Z series owners, could you please help me and check if that happen to your set?
I have recently noticed this same issue on my set. Just wondering if you have followed this up with the retailer or Sony? Do others out there have the same issue with this set?
Hey guys I am new here, but figured I would pop a question prior my purchase.
Has anyone seen or owned one of these Sony 32" Bravia LCD HDTV units yet: KDL-3285100?
It has 1080p full res for pc input and some other nice qualities, but no picture in picture.
 http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921665746334
One thing I find disappointing when considering these two models is Picture in picture is not offered on the more expensive model listed above, but is on this cheaper (kdl-52L5000) 32" with a 1366 x 768 resolution:
 http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=8198552921665746294
Anyways, I am wondering if the picture quality is as good as some are saying, and how they perform on PC input/ regular desktop usage + PC gaming etc.
I will be using primarily for a display for my PC's but also as a media display unit whether it be on PC or via cable/coax hookup for digital/analog tele.
Ultimately I am wondering if going with the cheaper 32" here is a good idea or not, based on quality and features like PIP and how it performs on PC for resolution (1366 x 768) is a bit of a downgrade for me with my max res at 1920 x 1080p currently, but if it does games and video well, and displays PC desktop, windows, images well I think it might be worth going cheaper.
Maybe this isn't the right place to put this, and dunno about all the rules here, so hopefully someone can provide some needed input on these or point me somewhere else.
Thanks.
Edited by Job314
Well, I bought my Z5500 in November.
I was unhappy with the picture quality from the outset and after weeks of struggling to get a decent picture and a string of phone calls and emails to Sony support, I finally got to speak to someone there who applied their brain instead of reciting the manual to me and who acknowledged I had a problem. He authorised a warranty call.
Pinnacle (the authorised service agents) arrived in January, took one look at the set, agreed I had a problem and whisked it away. Now after three weeks at Pinnacle (and another round of phone calls and emails) I've finally got my set back, with a new 'board' in it somewhere.
Lo and behold, my set finally produces a picture as good as I expected it to be when I took it out of the box. Colours are right and viewing angle/s excellent.
I'm one relieved viewer. For a while there I thought I'd wasted my money.
Now I can join the chorus. This is the best set I've ever had.
iicap'n
Compared to what? Viewing angles on LCD’s are NEVER “excellent”.
Compared to what it was ie. any move from 90 degrees and the picture washed out terribly. You should have seen what it was like. In comparison, it's now excellent.
I also have a 52z5500 and compared to the old panny 37 plasma, which you can almost see at right angles, the viewing angle is woeful. But I didn't buy if for the viewing angle. I got it for the PQ and SD playback on a big screen.
Edit: and the promo PS3 :)
Edited by theslydog
  • 1 month later...
Maybe it is just my TV (40Z5500), but the channel numbers do not match the channel numbers on my other STB's. For example Channel 7 HD is normally channel 70, but on my Bravia it seems to be Channel 32, and Nine HD which should be 90 is listed as channel 33.
So any ideas on how to fix this? Is it normal? Will Sony support be able to help?
A number of months ago I posted a query about off axis washing out and was assured it was normal. However, I'm talking anything other than being slap bang in front of the TV. Surely this is not normal and certainly when I go back to showrooms, this problem is only evident when the angle is a lot wider.
Any comments on this?
All comments would be appreciated
Thank you
hi,
anybody out there have the factory white balance settings for the 40z4500 in the service menu.
i some how changed the red,green,blue settings by accident.
cheer's.
  • 1 month later...
hi,
cheer's.
You posted this a while ago...and prob all ready fiixed it...But ya could just use the TV's Factory Setting Reset function!!!
i tried the factory setting reset but it does not reset the white balance settings.
