fsjk85
Iq2 Hard Drive Upgrade
i can't bring myself to do it , too worried something will go wrong and i will be without my foxtel for 2 weeks waiting for a tech to come out
more power to you guys who have the guts though :)
The trickiest part is identifying which is the Target and which is the Source :D pity Foxtel doesn't activate the USB connector under the flap for people like yourself to attach a external drive :(
cheers laurie
Tried to stick in a USB drive only to find Foxtel designed it to accepts a longer connector as a standard one will not even mate up well done Foxtel we are again forced to buy your one :unsure:
cheers laurie
ps found a connector nothing happen must be disabled :(
There are plenty of PC cases i have found where the front USB ports are useless for wide memory sticks like yours
The USB port does work well at charging my phone, no need to plug in the 240v charger every time i need to charge my phone.
cheers laurie
from the photo it looks like you could just swap the SATA connections so that the eSATA connection is active and then put your new drive in an eSATA enclosure.
no need to remove the original drive, just unplug the power and you're set. when you need to return the box just swap the connectors back, plug in the disk power and you're good to go.
I had a go at this last night on my IQ2. I had a spare "Western Digital Green" 750Gb drive after a recent upgrade to my HTPC.
Use a T8H torx driver to remove the 5 rear screws and then lift away the cover.
Inside is quite sparse and there's plenty of room to work in. Use the T8H driver again to remove the two drive caddy retaining screws, disconnect the SATA and power cables then remove the caddy. For those who might be interested there are some pics here. I have shown which screws retain the drive caddy in one of the pics.
Remove the drive from the caddy with a Philips head driver.
Use the Copy+ software (make sure it's the 1.2.0.4 beta version) as per instructions at Copy+ site here.
I tried the two USB adaptors method but it looked like it was going to take several hours to do the job, so I tried it using the internal SATA connections on the motherboard. It only took about 25 minutes.
Swap drives, put the IQ2 back together and enjoy.
Big thanks to fsjk85 for the heads up. I didn't even think this was possible.
I have a Hauppauge HD PVR arriving early next week and will try post a mini-review on it later.
Any chance you can post the images again? The link has gone dead. thanks
You need to run Copy+ on each HDD.
So you need to remove the IQ2 drive and connect it to your PC
If you are removing the drive there is no point putting your new drive in an external enclosure
Plus removing the drive is minimal effort, i would rather spend the extra 2 minutes swapping srives than having a permanent HDD sitting next to the IQ2 where you can see the cables running from the eSATA port, plus the external drive would need a power supply which is wasting power when the IQ2 is already converting the power for the internal HDD.
Looking at the pics it looks very straightforwad. A 1TB drive ought to triple my IQ2's storage if I'm not mistaken. Hmmm tempting :)
Is there anything complicated about the copy process, or is it just connect and click?
For those who have installed the 1GB drive, what size did you set the GB setting in COPY+SKY+ utility?
thanks
thanks
I guess you mean 1TB
In which case it would be 1000 GB
well, you don't have to go through all that, you can simply connect the original disk via eSATA to run copy+ and then swap the cable to connect up your target disk to the IQ.
matter of personal preference, really.
this method does let you use a 2.5" lower power/noise/heat disk with minimal fuss.
Lol thanks just want to make sure I put the right figure into the software and don't butcher it
the biggest 2.5" I could see after a brief look just then was 500GB .... I wonder how WD's AV 1TB would compare to a 2.5" in terms of noise
so tempted to do this hack, I'm just too scared atm. I'll keep tracking this topic to see how people go
