Peacekeeper Posted April 11, 2009 Share Posted April 11, 2009 Seems that channel 10 (SD) is dolby Digital and my STB will not process audio at that setting. I need to use the audio button and change it to MpegII audio. This is a new issue and used to work fine previously. My Son in Laws does the same. Could 10 when they changes 12 to Channel one have changed audio signal on channel 10 SD? Dobly digital wouks fine on the other channels namely 90 and all other channels come up with audio either mpegI, Doblby Digital or Mpeg II. Any thoughts why 10 now defaults to DD? Is there any way to get it to default to Mpegi or II? The work around works but is a nuisance. Any thoughts appreciated tony Link to comment Share on other sites More sharing options...
DrP Posted April 11, 2009 Share Posted April 11, 2009 I thought TEN dropped the AC3 on its SD channel when One xx started and now only transmit MPEG L2 audio. Your STB may not have automatically updated its stream maps (not surprising really) and may need a 'rescan' to work normally again. Link to comment Share on other sites More sharing options...
Peacekeeper Posted April 11, 2009 Author Share Posted April 11, 2009 (edited) Thanks will rescan the channel later on . Thought something changed as all other channels fine. Edited April 11, 2009 by Peacekeeper Link to comment Share on other sites More sharing options...
diesel Posted April 11, 2009 Share Posted April 11, 2009 With ten changing LCNs of late, a rescan is definitiely required Link to comment Share on other sites More sharing options...
Peacekeeper Posted April 12, 2009 Author Share Posted April 12, 2009 Thanks that did it It is fine now Link to comment Share on other sites More sharing options...
DrP Posted April 12, 2009 Share Posted April 12, 2009 Good to hear. Its a pity that the government doesn't require STBs sold in Australia to actually follow the Australian standard. If it did then problems such as your audio problem simply wouldn't happen - ie, your STB would learn the change automatically. Link to comment Share on other sites More sharing options...
diesel Posted April 12, 2009 Share Posted April 12, 2009 So will the freeview specs become part of Australian Standards? Link to comment Share on other sites More sharing options...
DrP Posted April 12, 2009 Share Posted April 12, 2009 (edited) The standard is under review but that does not guarantee that anything freeview has 'requested' will be made part of that standard, although you could be forgiven for believing otherwise by reading posts made by others. Given the extremely poor adherence to the standard by many STB manufacturers now I wouldn't hold my breath and expect future products to be 'fully compliant' in the future either. As I've cautioned several times already, one should not rush out and buy new equipment before the standards have been penned. Edited April 12, 2009 by DrP Link to comment Share on other sites More sharing options...
