Dwaino86 Posted January 10, 2010 Share Posted January 10, 2010 (edited) wonder if this fits your bill? http://www.dtvforum.info/index.php?showtopic=85588 Edited January 10, 2010 by Dwain Link to comment Share on other sites More sharing options...
NormanD Posted January 18, 2010 Share Posted January 18, 2010 Hey Guys, Anyone out there with a Pio BDP120 tried to play .avi or .mkv files via the USB. I'm considering buying one off the Pio Clearance centre for $289 and have and external HDD full of movies in .avi format. Cheers. Link to comment Share on other sites More sharing options...
shockvalue Posted January 23, 2010 Share Posted January 23, 2010 (edited) Some advice please. Currently looking to buy either the Sony BDP-S760 or the Onkyo DV-BD507. Haven't heard much about either model. Any thoughts on the way to go? Also anyone know prices for these two models. Thanks Edited January 23, 2010 by David1 Link to comment Share on other sites More sharing options...
330p4 Posted January 26, 2010 Share Posted January 26, 2010 The Sony BDP-S760 has had some excellent reviews and apparently shares most of its innards with a higher grade Sony BD player: e.g. http://www.trustedreviews.com/home-cinema/...u-ray-Player/p1 My local Good Guys had one today for about $565 - there have been reports of them being ordered at JB HiFi for $599. GGs is the only shop in my area where I have seen them in stock. I wouldn't be surprised is the Onkyo BD player is rebadged from one of the mainstream producers. Some advice please. Currently looking to buy either the Sony BDP-S760 or the Onkyo DV-BD507. Haven't heard much about either model. Any thoughts on the way to go? Also anyone know prices for these two models.Thanks Link to comment Share on other sites More sharing options...
NormanD Posted January 27, 2010 Share Posted January 27, 2010 OK guys, Myer have the Sammy BDP1600 for $269, it has 2 USB ports, does anyone have one of these units and can confirm it plays movies from an external Hard Drive.? Cheers Link to comment Share on other sites More sharing options...
NormanD Posted January 28, 2010 Share Posted January 28, 2010 Anyone got any views on this product from Clive Peeters: http://www.clivepeeters.com.au/products/ho...e+entertainment Cheers Link to comment Share on other sites More sharing options...
keiron Posted February 7, 2010 Share Posted February 7, 2010 (edited) Does anyone know of a good Blu Ray lens cleaner that's available locally. Panasonic recommends it's own RP-CL720E cleaner, but try getting one in oz! There's the Maxell BR-LC available at Amazon that uses "air cleaning" , not sure if this would be much use. All ideas welcome. Edited February 7, 2010 by keiron Link to comment Share on other sites More sharing options...
funkyblue Posted February 7, 2010 Share Posted February 7, 2010 Well I'd have to now recommend the AMTC Blu-Ray player from Dick Smith's. http://www.dse.com.au/cgi-bin/dse.storefro...uct/View/GH7110 My issues originally were due to a faulty USB and my TV. I've found out I sometimes lost sound was because of the TV. If I turned it off and on sound would work. It upscales everything even MKV and DIVX. Picture quality is excellent. Pity there are no firmware updates though. It works well for $179 bucks. Link to comment Share on other sites More sharing options...
Eeeerrr Posted February 12, 2010 Share Posted February 12, 2010 Does anyone know much about the SA-BT207 blu-ray player - the unit that comes as part of the Panasonic HTIB SC-BT207 (http://www.panasonic.com.au/products/details.cfm?objectID=4932)? Is it fair to assume it is as good as the blu-ray only jobs - the BD60 and BD80? Thanks guys. Link to comment Share on other sites More sharing options...
HyperBLAU Posted February 18, 2010 Share Posted February 18, 2010 Hi Guys, need some help for my parents set up. They just got a new tv and want to get a bluray player. At the moment they have an old HTIB dvd setup with the surround speakers being connected to the main unit. They want to keep the existing speakers and just replace the main unit with a BD capable player. Is this possible? From what I can gather analogue outputs on the back of most stand alone players need to still be connected to an AV Receiver, or can I just hook speakers straight to the analogue outputs? Can anyone suggest a player that might be able to do the job? Thanks in advance. Link to comment Share on other sites More sharing options...
fryzie Posted April 3, 2010 Share Posted April 3, 2010 Does anyone have anything negative to say about the Sony BDP-S560 ? I was probably going to pick one up tomorrow... Link to comment Share on other sites More sharing options...
Chris Dowling Posted May 22, 2010 Share Posted May 22, 2010 any of these bd recorders have twin hd tuners? Link to comment Share on other sites More sharing options...
RaGH Posted May 26, 2010 Share Posted May 26, 2010 You could buy a LG HD798 ? or HD799 which will come with a 250 or 500gb HDD respectively. I reckon they're good units that will obviously do you Blu-Ray playback, but will be able to record onto HDD and onto Blu-Ray discs or DVDs too. Unit has wireless built in to allow content streaming, as well as a USB port allowing any size external drive plugged in to be recorded onto directly or content backed up onto. Also the file format is fairly common, and can be converted easily once on a PC into your preferences. Hope that helped.... I may of got the model # prefex wrong though. Link to comment Share on other sites More sharing options...
BJ Boy Posted June 1, 2010 Share Posted June 1, 2010 You could buy a LG HD798 ? or HD799 which will come with a 250 or 500gb HDD respectively. I reckon they're good units that will obviously do you Blu-Ray playback, but will be able to record onto HDD and onto Blu-Ray discs or DVDs too. Unit has wireless built in to allow content streaming, as well as a USB port allowing any size external drive plugged in to be recorded onto directly or content backed up onto. Also the file format is fairly common, and can be converted easily once on a PC into your preferences. Hope that helped.... I may of got the model # prefex wrong though. I thought these units were BD playback only? Link to comment Share on other sites More sharing options...
choonie Posted December 27, 2010 Share Posted December 27, 2010 Hi Guys I just purchased a Samsung UA55C7000 Currently have a LG HR598D That is not a 3d player, so i need a 3d blue ray player to go with the TV I probably want a Samsung player do not need PVR capabilities just a stand alone 3d player possibly looking at the BDC6900, also looking at the 5900 (it says it is 3d capable...what does this mean?) I have an Older Yamaha Amp RXV459 - SO NO HDMI inputs, i will have to run Optical to the amp and HDMI to the tv can you guys suggest what is best from your experience Thanks Link to comment Share on other sites More sharing options...
NordaRocks Posted March 10, 2011 Share Posted March 10, 2011 (edited) Multi-region DIY kit for the new Oppo BDP-95: $ 110! edit The first 'real life' pics of the Oppo BDP-95: Link 3. Edited March 10, 2011 by NordaRocks Link to comment Share on other sites More sharing options...
