Panasonic Pz700 1080p Owners Thread.
  • Replies 238
..lucky the wife doesnt read this board... 1797 is INSANE!!
LOL..Perhaps the lesson is: don't buy last year's model TV 4 months before the current year models arrive, rather better to wait till the new models actually start hitting the stores... THEN buy last years runouts for considerably reduced prices.
For the 50" PZ700?
That would not be for the 50".
It would help if ppl quoted the size of the unit in this thread :P
Correct...it was for the TH42PZ700.
Read in context, my quote was in reply to the post directly above it which was already quoting the 42"
Hey guys,
I have a brand new PZ700 50 inch which I have connected to a Pana E47 combined DVD and VCR. I purchased this unit mainly to archive my video family movies to DVD. I have done a lot of work and completely rewired all my coax with RG6 quad shield and installed F Connector wall plates and put up a brand new Clipsal 2ANCOM6 aerial which is specified for my area. The FTA HD picture is great and I cannot fault it.
I am having a problem though which someone may be able to help me with. When I first got the TV, I connected it to the E47 DVD player via the HDMI 1 connection and was watching videos and DVD thru it. Everything was okay on the default settings. All I did was select HDMI 1 on the TV (using the AV selection button) and it would "see" the DVD connected there.
Yesterday I purchased a surge protector (Belkin) and also a longer HDMI cable. (Pannasonic brand cable at 1.5 m) I got home and replaced the cable and disconnected power to install the surge board. Now I cannot get a connection via the HDMI cable. I have tried the following,
used different HDMI cables
used all three HDMI points to connect into
read the manual over and over, both the DVD manual and the TV manual
Everything works as it should via the component or normal AV cables. I can see a difference in the quality of the DVD picture, I am sure it was better with the HDMI connection working.
I have assumed that the cables and connection points are not damaged so I guess that I have somehow changed a menu setting in setup or something similar.
I have selected HDMI/Optical where it is specified in the menu setup for the DVD. I have followed the manuals carefully and cannot see why it is no longer working.
Can anyone who is more experienced offer me some suggestions. I thank anyone in advance for any help.
Brad
Always power off from the wall before changing HDMI leads. There's been some horror stories on the Forum about folks who have "hot swapped" HDMI connections and subsequently damaged the HDMI connection on their device.
Hopefully you haven't damaged the HDMI on the VCR Combo as you seemed to have ruled out any damage on the TV by using all three HDMI connections.
Did you have the Viera link activated when it was working before?
Do you have anything else with HDMI connection to test with?
I am pretty sure the viera link was working before. I just assumed it was some menu setting I was missing. I will have to ring panasonic and try to get some advice. I was not aware you could damage the connections. Thank you Mick for replying.
Brad
After reading all the comments on this thread and others around the forum, I've decided to go with the 50" PZ700A. Managed to get it for $2850 from Bing Lee, that price includes 4 years extended warranty (+1 = 5 years) and delivery.
Having fun with the TV so far - it was amazingly easy to setup, and the picture looks great.
New to this forum but have been following for some time.
I am in the process of trying to decide between the 428xda and the Pana 42pz700. After spending alot of time viewing both screens under showroom conditions I have become frustrated at not being able to view fast moving sports ie AFL .
I have been into most stores whilst a game is being broadcast but the pictures are just not good enough to be able to judge the sets true ability with regards to motion. It must be pointed out that in my opinion most sets just don't handle motion very well at all, particularly when the camera pans out and the players in the back ground are just a blurr (can't reed the number on the jumper). The pixellation of the players moving accross the grass drives me mad.
Both sets handle all other types of broadcast very well but it is the issue of motion that I put the most emphasis on.
I would not bother at all if the quality was not the same or very close to the picture I am currently getting from my CRT.
I can get both sets for around 2K and sit 2.5 to 5m from the set.
Can anyone help with regards to these issues.
That's good to hear, mine gets delivered next Wednesday :D
Then Bellotv from this forum is coming out on Thursday to put up my aerial and hopefully he can help me out with making sure I have done everything correctly!
Why Does The Football Look So Bad?, especially in SD
Have a look at the above thread. If you have a good source with enough bitrate, these screens handle fast moving images fine (eg a good HD file or Bluray source, even a good DVD source). FTA broadcast bitrates are just too low to handle fast moving images an the poor result is what you see.
I'm not up to speed with the exact bitrate numbers, but I'm pretty sure a good HD source should be 20-24Mbits (?) whilst we have to make do with just 12Mbits for the HD channels.
the whole effect is made even more obvious because the screens are much larger than CRTs.
Thanks Diesel
I read that thread the other day and I understand the issues you mention.
However even given these problems surely one of these screens handles it better and I thought current owners may be able to shine a little light.
Trying to compare the two sets at a store has been impossible because the quality of the store reception is just terrible.
Only the motion issue in a sports environment interests me as it seems most of the better sets such as the pz700 handle
DVD/movie motion pretty well.
Well, I am now a "proper" contributor to this thread, having set up our new Panasonic TH-50PZ700A 50" / 127cm Plasma (and Panasonic DMR-EX77 DVDR unit) last night.
I'll make some pics available online sometime, and write a report on it thus far.
Good news is that it appears to be flawless, brand new as expected, easy to set up, and with a picture pretty much as I expected (which is very good).
Retravision Belmont (in the Newcastle NSW area) seemed to do the right thing by me, knew not to toss heaps of bull, gave me prices in the ballpark I was after etc. - glad to recommend them.
Re: Extended warranty - it's not cheap, especially the official Panasonic Extend Warranty Options in the documentation provided.
They (the retailer) offered some apparently reputable (I think he said it was Alliance-underwritten or some such) full manufacturer's extended warranty for an extra 4 years (making it 5 years in total) (on the Panasonic TH-50PZ700A) for an extra $420.
(We can still add this if we like, but have not yet.)
What are people's thoughts and experiences with this please?
If we don't get it, Murphy's law says we are guaranteed to have some serious problem with it in a couple of years.
And apparently an out-of-warranty service call for modern such large flat panels is usually very costly.
Edited by ssar
You should be able to get a far bit of the price of the in store extended warranty. From what i have read in these forums the price the stores actually charge is far greater then what they pay. On the panel i just ordered i paid $265 for a extra 4 years of warranty when there normal price was $369. So if you stick to your guns they will eventually lower the price. After all they will rather make a small profit then none at all.
I had a look at the TH-50PX80A and the TH-50PZ700A side by side in Bing Lee and I must say the picture was sharper and looked better on the 80A than the 700A playing a Bluray and free to air tv. 700A looked a lot softer in picture quality. Have others thought the same? Or is it just the new technology in the series 8 screen as oppose to the series 7?
Edited by alholme
got my Pana TH-50PZ700A last Wednesday from Dick Smith Nunawading. Set up was a piece of cake (well aside from the enormous box). Watched some of Friday nights St Kilda v Fremantle on it and the picture was very good. Unfortunately the game itself was awful and so i only watched it for a quarter before watching an episode of Dexter thru my xBox. I initially thought the picture would be pretty ordinary but i was very pleasantly mistaken.
The only qualm i have with the tv, which is my fault as i obviously didnt do enough research, is the lack of Full HD through Component in, which means i can only watch/play xBox at 1080i or 720p as i have the super old xBox which does not have a HDMI out. But still, overall I am VERY VERY happy with the tv. Can't wait to get my hands on a BlueRay playa once my bank account recovers...
Further to my posts last week re the sports handling ability of the 42PZ700 I managed to view an AFL game on this set on the weekend. The picture was far better than I imagined so I negotiated and purchased there and then ($1899 plus 5 yr warranty $299). Boxed unit is due in today.
All I have to do now is set it up to a Pioneer DVD recorder (with analogue tuner) and Yamaha Home theatre Amp/receiver.
Does anyone have any tips specific to this set up.
Just received Panasonic PZ700 + Pan DMR ex77 + pana SC -ht65 theatre system. Everything connected OK with HDMI but I am having trouble with Foxtel digital. I purchased a scart to component cable (for Foxtel supposedly) which appears to be component plus 2 extra audio cables and I have attached the component cables (blue,green & red) to the AV2 component connection but I dont get Foxtel (picture or sound) on AV2. Can anybody tell me where the extra red and white wires plug into and are they necessary? I thought scart included video or do I need to use the S video slot for video? Everything thing looks great if I can just get Foxtel working all will be right with the world.
get yourself a reciever which upscales to 1080p and you'll be fine. Mind you, i highly doubt you'd notice the difference on the old version xbox anyway. better off buying a ps3 for your blu ray player. Get a new games machine and blu ray player all in one. :)
You need to set your Foxtel picture setting to 'YUV' not RGB. The scart lead must be out of the socket with a TV symbol not the tape symble stamped on the foxtel box.
hi guys just bought a 42"pz700 and picking it up tomorrow. can anyone tell me what sort of settings i need to run it on to start with and for how long? is it in the instructions or do i just need to turn brightness and contrast down? should i not be watching letterboxed dvds for a certain amount of time or is it ok as long as i don't do it for too long?
Can't wait for tomorrow!!!
Appreciate the reply - I have discovered via the Foxtel digital part of this forum that I have a Foxtel set top box that doesn't do component video or optical digital sound - it lists YUV but it is greyed out - so I dont know why the box has a scart output or why a supposedly digital service cant output component digital video and audio. I have tried phoning Foxtel for 3 days to try and get a box that will output the optimum video/audio, but I cant get past the automated answer service that informs me that they are too busy and to phone back tomorrow - what a wonderful service!!!
If you want to get hold of someone at foxtel call their sales line someone always answers and then ask to be transferred to someone who can help you with questions on replacement boxes. Foxtel doesn't look to crash hot on YUV anyway. ive got IQ and i find it poor pitcure quality.
Managed finally to get hold of somebody at Foxtel. She really had no idea what I was talking about couldn't seem to get past the fact that I didn't want to get Foxtel HD.
Panasonic PZ700 1080p owners thread.
Hi All,
Finally I made the decision and got a 50" PZ700.
It was a tough decision for me. I have been staring at the TV countless times at the shops trying to like it.
Under shop lighting PZ700 looks very unconvincing.
I think people at the shop were caught up with the idea of its matte/anti glare screen. Therefore many shops I been
too , they proudly put the PZ under bright lighting condition. While other plasma brands they put in under dimmer location in the shop.
As we all know plasma doesn't look good under shop lightings.
My conclusion is as follows:
Pros:
DVD using my Sony upscaling DVD player through HDMI is VERY Impressive. I thought I was watching blue-ray.
Due to the matte screen, if you watch it under good lighting condition, the picture is very easy on the eyes
(you can watch DVD all day. LOL!).
Picture are Clean and Crisp. Really was very surprise by how good DVD is on this T.V. I can postpone buying a blueray/hd-dvd now until the war is over.
Jpeg slideshow through the SD card slot is amazing. I attribute this to the extra pixels of a FULL HD TV.
The quality of the Jpeg pic on the TV is as if you are looking at a frame photo.
So much better than the panasonic PX600 I tried last year.
Foxtel (using composite connection) - is crappy in my eyes, maybe its only me because I was comparing to how good it look in DVD.
But as we all know Foxtel looks crappy on any FULL HD TV.
FTA- No comments since I watch FTA through Foxtel. Will install a TV antenna soon.
Heat - Compare to Samsung P9, Pana. heat dispersion is so much better. The 3 fans behind is blowing out hot air.
Therefore the TV inside doesn't get very hot compare to samsung P9. The 3 fans are very quiet.
Buzzing - No problem here. Unless you intend to put your ear right next to the rear of the unit all day long.
Black - The blacks are quite good, second only to Kuro. It still look good even when I watch in the dark.
Cons:
Matte screen under bright lighting - Why on earth pana. decided to do a anti glare screen, it does not work!!
This only encourages shop people to put your plasma under bright lighting and the blacks look all wash out!!
This causes many people not to buy your plasma because it look so crap under shop conditions.
If you are buying this TV and your intention to put it under bright places in your home it will work as BAD as buying
a non anti-glare plasma screen. Some might say worst, since the blacks become greyish.
In the end I would say this is the 2nd best T.V after the 50" 1080p Kuro. hehehe :)
With a street price of half of the kuro best price, its a sure buy.
Any other owners of PZ700 care to give their comments.
G'day Panny 1080p owners,
Am about to acquire my first plasma soon and still deciding whether to get the std HD 42" PX8A or the Full HD PZ800A. Since it's gonna be the first and probably will stay for a while (like 5 years or so), would it be worth it to get the Full HD or 8A is fine since it's a 42" anyway and I've been reading a lot of discussion that Full HD on 42" would be a waste of money since you can hardly notice the difference. It will be mostly use for watching dvd, fta and also loves sports (especially F1).
  • 2 weeks later...
Call centre people have NFI about anything.
U aont gonna get any proper digital signal from the normal foxtel box.
The HD box with the 4 or 5 channels in HD is a rip off also.
  • 2 weeks later...
50" pz700
Has anyone with the 50" noticed that Nine HD has lip sync problem? Nine SD with same program is fine.
I'm in Perth metro area and have an external antenna, Nine HD signal quality is 10, strength is 9
according to the built in DVB info.
This is with sound playing directly from the TV speakers and surround options turned off.
Could it be antenna? Or faulty built in DVB? firmware? cabling? any ideas would help :)
  • 11 months later...
Hi fellow PZ700A owners ...
I have the 50" model, it's 18 mths old. Yesterday I started noticing a pale yellow rectangle, approx 40 x 15 cm, extending from the top, middle of the screen down. The yellow was more noticable when reds were being displayed, less when blue/green was on the screen. The rectangle has appeared intermittently, on all inputs - including the internal tuner. Not too sure yet, but it may fade / disappear the longer the screen is turned on ... need to test this.
I plan to call the extended warranty people tommorrow ... just wondering if anyone else has experienced this fault and what the outcome was?
Regards, Carl
Perth seems to get more lip sync issue reports than other states from what I can glean from reading the forums.
In Sydney, HD is more susceptible to lip sync issues, but in my experience, it's the broadcasters and not the TV/antenna etc.
Let us know how you go. Sounds like something needs replacing.
  • 2 weeks later...
apparently something doesn't need replacing !?!
The service rep came this morning and simply said "we'll have to take it away". I said no, I'm watching the footy tonight and I thought you guys said this was an "in home" service?
So he gave me a bit of masking tape and asked me to place it on the rear of the screen in line with the yellow rectangle next time it appears. I've got to call him back then and apparently we are going to turn the unit around and "adjust something" I reconfirmed with him that no electronics needed to be replaced.
So, a mystery. What's he going to do? When I showed the couple of pictures I've taken of the fault he sounded like he'd seen it before ... a problem with "columns" or something I think he said.
Just needs a little fine tunin' then, hey??? :huh:
ok ... got the screen serviced today
if you haven't seen the back off an HD plasma you can probably imagine it's a complex bit of equipment. The screen is actually made up of multiple elements (which is what the technician was refering to as columns. These elements are rectangular - and guess what? - exacty the size of the yellow rectangle I was describing as a fault. In the HD panels there are 2 rows of them - top and bottom. So, all the technician did was to insert a few shims (thin bits of plastic) under the ribbon cable connector to the element (column) in question and give it a bit of a tightening. Apparently not a Panasonic fix, but one he picked up from Hitachi.
So, hopefully no further problems.
And just one other thing - apparently there ARE confirmed reliability differences between the Japenese and Chinese assembled models - which we probably had guessed anyway. Sort of ironic in my case as mine was assembled in Japan ... :huh:
