Bry
Sony Bravia Owners Thread
I have a KDL 55EX500 and a Toshiba laptop. I tried to use the TV as a second display for the laptop using a VGA/SVGA cable. However, the TV seems not detecting the connection (PC connection is grey out, not selectable from the menu). I have tried setting different resolution available in the PC as suggested somewhere on the net but not successful. If anybody know this issue, please help me. Thanks a lot.
I had this same problem too... I have the KDL-40EX600 and had the same issue connecting my Toshiba laptop to VGA to the TV. The TV's inputs will only become active when it senses a connection. The Toshy laptop was able to pick up the 2nd "monitor input" but the Sony wouldn't see it.
In the display options there is an area to change the settings of the inputs. There was an option for "Auto" or "Always" or something like that. Anyway, I set the PC input to "Always" and now the connection's active all the time. I hit the normal Ctrl + F5 on the laptop and configured the laptop to only use Monitor 2 when swapping between monitors. I now get 1920 x 1080 @ 60hz and it looks great.
Got a HDMI cable on order from EZYHD (after reading all the great feedback) and will be using the HDMI cable on the laptop now :P
Hi all - so I've had a 40X3100 for 3 years now, it has served me very well. I remember spending countless hours on DTV Forum back then, seeking a good price!
Well it's time to move on I think, I'd like to upgrade to a bigger screen. How much do you think my set is worth nowadays, and what would be your recommendation on how to sell it? It still has 2 years of warranty on it, so hopefully that is a plus.
I ask as I've not sold a TV for quite some time, the last one being a CRT in the local trading post - times have probably changed since then. Would appreciate any advice!
Hey guys just noticed my KDL 46X3100 standby light flashing at me when I hit the power button on the remote. This is the second time this has happened to me over the last 2 days, didn't much attention to it the first time. If I press the power button on the remote while the light is flashing the tv just powers up like normal. I guess I should count the amount of flashes it gives me.
Does anyone know what the flashes mean? Like 2 or 3 flashes standee for??
Zoidy
Zoidy
Hi Dr.Z,
Here's a link that decyphers the blinking codes:
What do the Sony Television Blinking Codes mean?
AUSTRALIAN KDL BLINK CODES
2 times – Main power supply voltage error (12V, etc)
3 times – Malfunction of 3.3V line
4 times – Malfunction of 5V line (Voltage Supply to FE, etc)
5 times – Malfunction of power supply for screen
6 times – Malfunction of inverter or overcurrent, etc
7 times – Abnormal temperature inside unit
8 times – Audio circuit error (amplifier, etc.)
9 times – Fan malfunction
10 times – Digital FE circuit error
11 times – Malfunction of Trident IC or around IC
12 times – BH board error
13 times – Malfunction of balancer
(Codes posted by Agoraquest forum member babyaservice)
Hi Dr.Z,
Every new model that is released has different set of blink code meanings, the above list is only relevant to the particular chassis that the set was designed for.
Sony Bravia KDL-40V4000
I've searched and searched :unsure:
but can't find any recommendations for calibrating the 46V, 40v or 32v
Can anyone point me in the right direction for calibrating this TV ?
Here's a few links to get you started:
AVForums - KDL 40V4000 Settings
AVForums - Sony KDL40V4000 - Calibration Settings
AVS Forum - Display Calibration
Blu-ray.com - Calibrate Your HDTV
Problem with Sony kdl46x3100.
Hi everyone. I am new to the forum and hope this posting is in the right place.
My TV has developed a fault. The problem affects the TV when it is switched on for about the first 20 to 30 minutes of operation. It usually manifests in lines, flickering and some jumping of the image largely on the left hand third of the screen. Very occasionally there will be no picture at all but if I turn off and then on again I usually get back to an image with the fault only affecting the left hand third of the screen.
I have a Tivo, PS3 and Wii connected to the TV but through a process of elimination I have ruled out any of these devices and also the aerial connection as the cause of the problem.
The TV has never been moved since it was first installed and has not suffered any impact or other abuse.
A friend (no expert) thinks the problem is likely to be "driver". He thought that these generally can not be replaced and usually you have to buy a new TV if this problem occurs.
Of course, I bought the TV in June last year and it is now out of warranty. I think I would have a pretty good basis for arguing I am entitled to a replacement under consumer law for a failure of this kind after such a short time.
I tried Google and could not find any info on this.
Is this a known problem affecting Sony HD tv's?
Do the symptoms sound like a driver problem? Can this kind of problem be fixed?
I bought the TV from Sony Central in Adelaide. Anyone had to deal with them regarding a problem TV? Is there a key person I should contact to get this sorted out?
Thanks in advance for any advice or information.
Hi there, I am also experiencing problems with my KDL40W3100. Can you please let me know what you ended doing? Thanks.
Can anyone help me !
I have a Sony Bravia kdl40x3100......the standby light is blinking 13 times then stops for a couple of seconds then blinks 13 times again.....
Does anyone know what the problem could be?
Sabrinella
Sabrinella
Same thing happened to me, it's the blink code fault listed up above.
Extended warranty mob took it away to fix it (Townsville mind you and I live in Brisbane) and exactly as I expected after researching, the replacement part is
no longer available so they replaced the tv with an EX500.
Kayar,
Thank you for your response, however I am new to this forum and still trying to find my way around it, so when you wrote "the blink code listed above" I had a look and was unsure of what I was looking for. Would you mind clarifying exactly what to look for above as I could not find it.
Thank you
Sabrinella
As stated before those blink codes are for a specific model series, in the case of the model Sabrinella mentioned the blink codes are;
2 times - POW OVP - - Main Power Over Voltage Protection
3 times - POW ERR1 - - Power Error
5 times - T_CON - - T_CON Error
6 times - BACKLITE - - Back Light Error (Panel Inverter)
7 times - TEMP ERR - - Temperature Abnormal Detection
8 times - AUD PROT - - Audio Abnormal Detection
9 times - FAN_ERR - - FAN Error (Not Detected. Display Only)
10 times - DTT ERR - - DTAU Power / Communication Error (AUS only)
13 times - BALANCER - - Panel Balancer Error
hi folks
just wondering if people can tell me if my epg/guide behavior is normal. basically, it seems to loose all its information after some period of time (perhaps a day), but if i turn it off, then on again with a short period of time (up to a hour perhaps), it retains the full information. Its pretty annoying, as i need to go through all the channels to refresh the guide.
i don't really understand why this would be standard behavior. in a way defeats the purpose of a 7 day guide.
i've got a 32ex500 btw.
thanks for any help/info.
That doesn't sound like normal behaviour. The EPG data is refreshed by the Networks on an ongoing basis so the EPG should reflect this. If the TV does not cache the EPG data when you turn off the TV, then you will need to surf the channels to reload it, but once loaded (ie 30 secs on each broadcaster) it should stay in the EPG view.
yeap, agreed. this is the problem, it stays in EPG for only a while. but if i turn the tv on again after even an hour, its all gone, and i have to scan through the channels to refresh.
can anyone here confirm this is the standard behavior... or alternatively, if you don't find this on your ex500 series, please let me know.
thanks
I too have to surf the channels (or at least 1 out of the network block) to have any info in the EPG......this is on initial startup....havnt noticed if the info disappears after time though.
Its annoying either way.....why doesnt it just appear when u turn on the TV.....pretty basic i would think.........WMC on my PC shows all info straight up and u can even add the colourful logos into the guide.
Does anyone know if u can do this with the Sonys EPG? B)
BTW way i have a EX600 series
WMC EPG
thanks
That's the point I was trying to make - sorry my post wasn't clear enough - I see that after re-reading it. Basically some TVs (STBs and PVRs as well) will cache the EPG data, so that it is available immediately upon start up. However many devices do not, so you need to channel surf each time after you have turned the TV back on to reload all the EPG data. This is normal behaviour.
If what you are saying is that you lose EPG data after each power cycle, then I would be suggesting that the TV is not caching the EPG data and is most likely 'normal' behaviour.
If on the other hand you are saying that if you leave the TV on for 24 hours or longer and then begin to lose EPG data (without turning the TV off/on again) then this would not be normal behaviour. The TV should be receiving EPG data from the broadcast stream as long as it is on.
Edited by diesel
That's because I presume your PC is always connected to the net so it's getting it's EPG data fed to it all the time. Also, it is most likely that WMC also caches the EPG data.
It all comes down to how the brand has developed the software to handle EPG data. At least these Sony's support an EPG. I remember when most other brands had the EPG, but Sony still did not.
The PC is always connected to the net but turned off nearly every night.....so wouldnt it be unable to cache if its off?.......
Also if the channels are brodcasting their signal and obviously u receive the signal instantly then why doesnt the EPG info do the same when u switch on?
And if say EPG info is cached and is there at startup , then it has to be refreshed anyway?
Not aimed at you specifically diesel BTW :D
(does anyone know why i cant type in the reply box when i try to "quote reply" but can when i use "fast reply" ..?? )
thanks for responses folks.
baboy, can you confirm for me, so after you have turned on your ex600, and cycles through all the channels (ie, the EPG data is fully loaded), if you turn your tv off, and then on again say 12 hours later, will you have to cycle through all the channels again to restore it, or will it still be there?
i assume WMC will get its info direct from the net, or will perhaps keeps it cached, so as long as you return to a particular channel within 7 days, it's guide will show current info.
diesel, i do understand your point, and this is why the behavior of my ex500 is confusing. as i mentioned in my original post, if i leave the TV off for 5 minutes, the EPG data is still there on power up (ie it is cached). however, if i leave it off for 1 hour (actually, even 15mins seems sufficient), all the EPG data will be gone, and i will have to cycle the channels to restore it.
If i simply had to cycle the channels everytime i powered up, then i would assume the tv simply does not support caching.. but clearly it does cache for at least some short period of time. hence i'm wondering if other people experience this.
I just turned the TV off for a few minutes then back on and the EPG was still all there.........I know definately after 1st time switch on each morning (after about av. 8/9 hours off time) theres no info on the EPG and u have to cycle to get it to show.
I wonder if the TV was connected to the net (something I havnt done as yet as the Sony dongle is $100 and I need wireless ) would this do anything for the EPG? <_<
ok, sounds pretty similar to the behavior of my ex500. pretty shitty design.. why wouldn't they just have the tv hold the information? stupid.
i doubt the net connection would help.
Sabrinella
Just to let everyone know the outcome.....13 Blinks = the balancer
Even though my TV was 3 years old and out of warranty Sony replaced the component I was told was $1000.00+ free of charge as it was a major fault. I paid for the labour $200 odd $$'s which I was fine with so I was pretty happy with that. :rolleyes: Lets hope this part does not faulter.
Regards to all,
Sabrinella
The broadcasters send the EIT EPG data every few seconds within the transport stream. They only transmit the EPG data for their station(s), hence why you need to;
1. scan each broadcaster
2. leave it on each station for ~30secs to get full 7 days data
The Freeview EPG is transmitted by all broadcasters and they broadcast the entire EPG data for all stations. To receive this, your TV needs to have MHEG5 decoder and presumably Freeview approved.
Some (most?) TVs don't fully power off straight away when you turn them off. For example, my Panasonic goes into a 'lite' standby mode when I first power it off. I believe during this period it maybe searching for OTA updates and I think it maybe some kind of system where the manufacturers keep the components powered on incase you accidentally turned it off and turn it back on straight away. This way the TV doesn't have to cycle fully off then on.
On my TV at least, a quick press of the power button on the remote restarts the TV. If However I leave it off for 15 mins or longer I'll hear a 2nd click and the TV goes into a 'deep' standby mode, where I guess all components are powered down except those needed to receive an IR signal and power up the TV again. For me to turn the TV on once in this state, I need to hold the power button down for ~2 secs before the TV turns on.
If this is the case with your Sony, then I presume for that initial period after you turn it off, the TV is still on in some low power state and the EPG data is still stored.
This would be my guess at the 'cacheing' query you raised.
Connecting to the net won't do a thing because the EPG is transmitted in the broadcast stream and not the internet - unless the TV was IceTV compatible which it isn't.
