eddieaus 0 Posted July 10, 2007 Share Posted July 10, 2007 just came back from Sony Central Adelaide, they have 40" V300 on display. i was very impressed by the PQ, definitely the best 720P LCD display so far. and with RRP$1999, it can easily beat Samsung 40R81 to death. i was also glad to hear it doesn't have HD tuner, because the V2000's HD tuner was a disaster (it takes 3 secs to switch a channel). they also quoted me $1440 cash price for the 32" version, which is only about $60 off. will look around and see if other stores can offer a better deal. http://i149.photobucket.com/albums/s44/edd...hoto-0048-1.jpg http://i149.photobucket.com/albums/s44/edd...hoto-0049-1.jpg http://i149.photobucket.com/albums/s44/edd.../Photo-0051.jpg Link to post Share on other sites
cary 0 Posted July 10, 2007 Share Posted July 10, 2007 Comparing the 40" V300 and the V2000 : 40IN V SERIES BRAVIA LCD KLV40V300 Picture Native Display Resolution: 1366x768 BRAVIA Engine: Yes Viewing Angle: 178 Screen Format: WideZoom/Nomal/Full/Zoom Picture Mode: Vivid/ Standard/Cinema Multi Picture: Yes (Picture and Picture) Noise Reduction: 3D Digital Comb Filter Brightness: 450 cd/m2 Contrast: 1600:1 (On-screen) Response Time: 8ms Sound Audio Output: Yes Sound Mode: Dynamic/Standerd/Custom Surround Mode: S-FORCE/Simulated Stereo/Off BBE Digital: No Terminals HDMI Input: x1 Rear, x1 Front Component In: x2 S-Video in: x2 Composite in: x3 Headphone Out: x1 HD15 / PC Audio Input: x1 Other Features Power Saving Mode: Yes Clock: Yes On / Sleep Timer: Yes Teletext: Yes(English,French,Persian) 250P Light Sensor: Yes Cinema Drive: Yes OSD Language: English,Traditional Chinese, Thai, Arabic, Farsi Swivel: Yes General Power Requirement: 110-240V 50/60Hz Power Consumption: 180W Dimensions with stand (WxHxD mm): 981×688×265 Dimensions without stand (WxHxD mm): 981×643×110 Weight with stand (Kg) : 24kg Weight without Stand (Kg): 20kg 40" V SERIES HD BRAVIA LCD TV KDL40V2000 Picture Integrated High Definition Digital Tuner: Yes Native Display Resolution: 1366x768 BRAVIA Engine: Yes Viewing Angle: 178 Screen Format: Wide Zoom / Normal / Full / Zoom Picture Mode: Vivid / Standard / Custom Multi Picture: PIP (For Freeze Function) Noise Reduction: Yes Brightness: 450cd/m2 Contrast: 1300:1 (On-screen), 5000:1 (Dynamic) Response Time: 8ms Sound Audio Output: Yes Sound Mode: Dynamic / Standard / Custom Surround Mode: SRS TruSurround XT / Simulated Stereo / Off BBE Digital: Yes Terminals HDMI Input: x1 Component In: x1 S-Video in: x2 Composite in: x3 Headphone Out: x1 HD15 / PC Audio Input: x1 Other Features Power Saving Mode: Yes Clock: Yes On / Sleep Timer: Yes Teletext: Yes Light Sensor: Yes Cinema Drive: Yes OSD Language: English Swivel: Yes General Power Requirement: 224 - 240 V 50/60 Hz Power Consumption: 205W Dimensions with stand (WxHxD mm): 988 x 716 x 334 Dimensions without stand (WxHxD mm): 988 x 664 x 103 Weight with stand (Kg) : 28 Weight without Stand (Kg): 22 The 40" V300 rrp is $1999 and the 40" V2000 rrp is $3399, what does the extra $1400 give you for a V2000 model apart from an inbuilt HD tuner?? $2k for a Sony 40" 1366x768 LCD panel is an awesome price, opinions/thoughts??? Link to post Share on other sites
eddieaus 0 Posted July 10, 2007 Author Share Posted July 10, 2007 don't forget V300 has 10bit panel and supports 1080P signal, while V2000 doesn't. BTW V2000 looks soooooo old now Link to post Share on other sites
zorg1503559539 0 Posted July 10, 2007 Share Posted July 10, 2007 seem to be missing something but the only difference b/w the 32 inch v300 and v2000 is the built in HD Tuna and the price $1499 vs $2399 RRP? How much for a decent HD setop box these days. Link to post Share on other sites
JonL 0 Posted July 10, 2007 Share Posted July 10, 2007 Thanks for your comments. I'm wondering, do you have any comments about the performance of the 32" V300 against other 32" competitors such as the Samsung R8 series? 1499 rrp is very reasonable, especially for Sony and the decent specifications further add value for money. Link to post Share on other sites
ruud 0 Posted July 10, 2007 Share Posted July 10, 2007 Think it's about $180 for a Sony setop box Link to post Share on other sites
zorg1503559539 0 Posted July 10, 2007 Share Posted July 10, 2007 I'd echo those comments should be able to be had less for cash as well... ie good guys jb etc. looks like the new 32 inch display for the new house... Link to post Share on other sites
eddieaus 0 Posted July 10, 2007 Author Share Posted July 10, 2007 Thanks for your comments.I'm wondering, do you have any comments about the performance of the 32" V300 against other 32" competitors such as the Samsung R8 series? 1499 rrp is very reasonable, especially for Sony and the decent specifications further add value for money. didn't see 32" in store, however they do have them in stock. 32" has 8bit S-PVA panel, while 40" has 10bit. Samsung R8 is not on same level as V300, as they are using cheap CMO/AUO panles. Link to post Share on other sites
baka7 1 Posted July 10, 2007 Share Posted July 10, 2007 I'm in the market for a new 32inch LCD for my room. How does the new Sony V300 compare with the soon to be released Panasonic TX-32LXD700? I had my mind set on the Panasonic but seems like the sony one is more cheaper but doesn't have inbuilt HD tuner whereas the Panasonic does. Link to post Share on other sites
GorGor 0 Posted July 10, 2007 Share Posted July 10, 2007 I'm in the market for a new 32inch LCD for my room. How does the new Sony V300 compare with the soon to be released Panasonic TX-32LXD700? I had my mind set on the Panasonic but seems like the sony one is more cheaper but doesn't have inbuilt HD tuner whereas the Panasonic does. I've been told that the new V300 is Made in Malaysia, while V2000 is Made in Japan. Can someone confirm this? Thanks. Link to post Share on other sites
eddieaus 0 Posted July 10, 2007 Author Share Posted July 10, 2007 I'm in the market for a new 32inch LCD for my room. How does the new Sony V300 compare with the soon to be released Panasonic TX-32LXD700? I had my mind set on the Panasonic but seems like the sony one is more cheaper but doesn't have inbuilt HD tuner whereas the Panasonic does. Sony will release D300 to compete with Pana D700. i've heard 120hz does help minimising motion blur. personally i wouldn't pay the extra $500 for 120hz as i'm very happy with the V300 PQ. Link to post Share on other sites
eddieaus 0 Posted July 10, 2007 Author Share Posted July 10, 2007 Think it's about $180 for a Sony setop box yes, $179 at MYER Link to post Share on other sites
aafuss 0 Posted July 10, 2007 Share Posted July 10, 2007 Also uses a WAX3 chassis:same type as US S3000 model. U series:made by Wistron, I think. Got that from Sony ESI (I can use that site). Link to post Share on other sites
Tuatara 0 Posted July 10, 2007 Share Posted July 10, 2007 Also uses a WAX3 chassis:same type as US S3000 model. U series:made by Wistron, I think. Got that from Sony ESI (I can use that site). I picked up one in NZ a couple of weeks ago (returned my samsung r81 for it - lucky it was within the 28 day return period). The sony is a great set - handles HD and SD well (even divx!). Highly recommedned Link to post Share on other sites
rareairunc 0 Posted July 10, 2007 Share Posted July 10, 2007 we got these in store yesterday and we unboxed the 40in first and set it up with a topfield hd box and i was quite impressed with it the look,the pq and the price then we unboxed the 32in and set it up but for some reason i didnt like it it looked plain in the smaller size and i wasnt impressed at all apart from the price sounds weird maybe but i dont know just something about it i dont like Link to post Share on other sites
eddieaus 0 Posted July 10, 2007 Author Share Posted July 10, 2007 we got these in store yesterday and we unboxed the 40in first and set it up with a topfield hd box and i was quite impressed with it the look,the pq and the price then we unboxed the 32in and set it up but for some reason i didnt like it it looked plain in the smaller size and i wasnt impressed at all apart from the price sounds weird maybe but i dont know just something about it i dont like i reckon is because of the difference between 8bit and 10bit panels. 10bit panel can show a lot more colors than a 8bit Link to post Share on other sites
rareairunc 0 Posted July 10, 2007 Share Posted July 10, 2007 yeh maybe but also the grey look i dont think suits the smaller 32 compared to the 40 Link to post Share on other sites
eddieaus 0 Posted July 10, 2007 Author Share Posted July 10, 2007 i wish sony would released the black version as well: http://www.sonystyle.com.hk/ss/resource/im...e32_2_600px.gif Link to post Share on other sites
aeon1503559541 0 Posted July 10, 2007 Share Posted July 10, 2007 Interesting, any prices, specs on the D300? Link to post Share on other sites
eddieaus 0 Posted July 10, 2007 Author Share Posted July 10, 2007 Interesting, any prices, specs on the D300? will be the same as european version D3000 http://www.sony.co.uk/view/ShowProduct.act...gory=TVP+LCD+TV Link to post Share on other sites
GB42 0 Posted July 10, 2007 Share Posted July 10, 2007 You watch this avent model disapear when the new digital models come out in september.Sony have only released these analogue ones so that they have tv's for sale until september,as they have no more stock of there old digital models. Link to post Share on other sites
cary 0 Posted July 10, 2007 Share Posted July 10, 2007 The current V2000 series is coming down in price ... popped into Myer a few minutes ago on my morning tea break for a look see. The ticketed price of the 46" V2000 (1366x768) is now $3499 and the 40" V2000 is now $2899. Thats the Myer ticketed price, I'm sure JB's, HN etc will be dropping their ticketed prices as well. I asked the Myer sales guy about the price drop, he said the V2000 series is a run out, they're making way for the new range coming out next month, will be cheaper as they'll be manufactured in China rather than Japan. Don't know if thats fact or rumor, it's just what the Myer guy said to me. Link to post Share on other sites
zorg1503559539 0 Posted July 11, 2007 Share Posted July 11, 2007 ayoen seen any prices on the 32" v2000? Link to post Share on other sites
rockybalboa 0 Posted July 11, 2007 Share Posted July 11, 2007 V3000 40" + HD PVR for under $2600!? If so, I think I will be downsizing from 46". (unless the 46" TV's have similarly huge price drops) Link to post Share on other sites
eddieaus 0 Posted July 11, 2007 Author Share Posted July 11, 2007 The current V2000 series is coming down in price ... popped into Myer a few minutes ago on my morning tea break for a look see. The ticketedprice of the 46" V2000 (1366x768) is now $3499 and the 40" V2000 is now $2899. Thats the Myer ticketed price, I'm sure JB's, HN etc will be dropping their ticketed prices as well. I asked the Myer sales guy about the price drop, he said the V2000 series is a run out, they're making way for the new range coming out next month, will be cheaper as they'll be manufactured in China rather than Japan. Don't know if thats fact or rumor, it's just what the Myer guy said to me. So MYER won't get V300 until next month? that's kinda late, i was hoping to get a better deal there. Link to post Share on other sites
cary 0 Posted July 11, 2007 Share Posted July 11, 2007 The V300 series don't have tuners in them whereas the V2000 series do. I think the new series the Myer guy was referring to was not the V300 series as those are available now? Link to post Share on other sites
Sea Kitten! 0 Posted July 12, 2007 Share Posted July 12, 2007 Here's something to think about if you're planning on getting the 40" 10-bit Sony AND hooking it up to a HTPC with an Nvidia card: It appears that unless you have a Nvidia 8 or above series you're not going to get more than 8-bit color from your panel. http://en.wikipedia.org/wiki/GeForce_8_Series Looks like I'm screwed I haven't got the room in my Shuttle for an 8-Series card. Link to post Share on other sites
eddieaus 0 Posted July 12, 2007 Author Share Posted July 12, 2007 I've heard that V300's panel is not true 10-bit. It's got 10-bit color from a 8-bit panel by dithering. I don't have evidence to support the theory though. It is a little bit suspicious when sony uses "true 10-bit panel" to describe X series but without the word "true" for other models on the US Sony website. Link to post Share on other sites
Gogo1503561024 0 Posted July 12, 2007 Share Posted July 12, 2007 this new sony screen(40" v300) supports 1080p but is advertised as a 720 screen? hows that work - Limitations somewhere/not native? $2000 is a great price. Link to post Share on other sites
eddieaus 0 Posted July 12, 2007 Author Share Posted July 12, 2007 this new sony screen(40" v300) supports 1080p but is advertised as a 720 screen? hows that work - Limitations somewhere/not native? $2000 is a great price. native resolution is 1366X768, but can accept 1080P signal via HDMI, won't be displayed as 1080P though. Link to post Share on other sites
Dandroid 0 Posted July 12, 2007 Share Posted July 12, 2007 One step closer to the D300. And thanks for keeping us up to date on these Sony sets, Eddie. Link to post Share on other sites
eddieaus 0 Posted July 12, 2007 Author Share Posted July 12, 2007 BTW guys, Australia has lowest pricing for 40" V300 in Asia/Oceania region (in AUD): Australia: $1999 China: $2,143 Taiwan: $2,109 Hong Kong: $2,667 New Zealand: $2,718 very suprising Link to post Share on other sites
SOLIDsnake 0 Posted July 12, 2007 Share Posted July 12, 2007 Hmm, so when are the 40" are actually coming to the stores in sydney. I haven't seen them anywhere so far and am in the market for a 720p for my ps3 (cant afford 1080p, PS3 was a present lol). I was tossing up between this and a comparable plasma (in size, pq and price), but I've been out of the loop for a while and don't know much about plasmas. Link to post Share on other sites
eddieaus 0 Posted July 12, 2007 Author Share Posted July 12, 2007 Hmm, so when are the 40" are actually coming to the stores in sydney. I haven't seen them anywhere so far and am in the market for a 720p for my ps3 (cant afford 1080p, PS3 was a present lol). I was tossing up between this and a comparable plasma (in size, pq and price), but I've been out of the loop for a while and don't know much about plasmas. try the Good Guys, i saw both 32" and 40" at my local good guys. they quoted me $2050 for 40V300 + HD box. Link to post Share on other sites
paulw2 0 Posted July 12, 2007 Share Posted July 12, 2007 BTW guys, Australia has lowest pricing for 40" V300 in Asia/Oceania region:Australia: $1999 China: $2,143 Taiwan: $2,109 Hong Kong: 2,667 New Zealand: 2,718 very suprising Is that A$$ conversion or country of origin $$?? Link to post Share on other sites
chowny28 0 Posted July 12, 2007 Share Posted July 12, 2007 Hmm, so when are the 40" are actually coming to the stores in sydney. I haven't seen them anywhere so far and am in the market for a 720p for my ps3 (cant afford 1080p, PS3 was a present lol). I was tossing up between this and a comparable plasma (in size, pq and price), but I've been out of the loop for a while and don't know much about plasmas. Im looking at this TV for the same reason, I have an Asus W2PC laptop which has HDMI output & HD-DVD player on it, that way i have both bases in HD DVD covered. If anyone has price in Brisbane, let me know. Otherwise when i start shopping ill post up the prices i get. Link to post Share on other sites
Owen 119 Posted July 12, 2007 Share Posted July 12, 2007 Here's something to think about if you're planning on getting the 40" 10-bit Sony AND hooking it up to a HTPC with an Nvidia card:It appears that unless you have a Nvidia 8 or above series you're not going to get more than 8-bit color from your panel. http://en.wikipedia.org/wiki/GeForce_8_Series Looks like I'm screwed I haven't got the room in my Shuttle for an 8-Series card. All video is 8 bit, but video processing needs to be done in high bit precision to avoid rounding errors when manipulating 8 bit data. The panel its self dose not need more then 8 bit. 8xxx cards have much better and more accurate colour then 7xxx or 6xxx cards. Link to post Share on other sites
Glider 0 Posted July 13, 2007 Share Posted July 13, 2007 Here's something to think about if you're planning on getting the 40" 10-bit Sony AND hooking it up to a HTPC with an Nvidia card:It appears that unless you have a Nvidia 8 or above series you're not going to get more than 8-bit color from your panel. http://en.wikipedia.org/wiki/GeForce_8_Series Looks like I'm screwed I haven't got the room in my Shuttle for an 8-Series card. If you are thinking about upgrading your video card, look at the new Radeon 2000 series. They have a new UVD (Unified Video Decoder) which will take care of H264 and VC1 video processing with high quality playback. They are the equivalent of the Nvidia 8000 series. The HD2400 cards even come in cut down form to fit inside small cases, like the shuttle. If you are a casual gamer, then try and see if you can fit one of the HD 2600XT cards inside. They are also releasing AGP models as well as PCI. Their prices should be competitive. Expect them to start appearing in stores in the next couple of weeks. Link to post Share on other sites
eddieaus 0 Posted July 13, 2007 Author Share Posted July 13, 2007 Is that A$$ conversion or country of origin $$?? yes they are in AUD$ Link to post Share on other sites
eddieaus 0 Posted July 13, 2007 Author Share Posted July 13, 2007 just came back from MYER Adelaide, they don't have V300 yet, but offered me 10% off when they come in, so 40" will be $1799 and 32" $1350. Link to post Share on other sites
