zorg1503559539 0 Posted October 15, 2007 Share Posted October 15, 2007 seems like Myer are doing good deals at the moment change from the old days plus bonuses if you have a Myer One card also. Link to post Share on other sites
mcduck 1 Posted October 15, 2007 Share Posted October 15, 2007 i like myer. but it depends on the sales person. loved my sammy deal. the 700a deal sucked. Link to post Share on other sites
dvdnovice 0 Posted October 17, 2007 Share Posted October 17, 2007 Just to follow up - applied the update - Simpsons reminded me - and it all worked sweet! Hi Barak, Glad the update worked. I have to say that Panasonic took quite a long time to get back to me about sending me the upgrade on SD card, so I'm glad I did the upgrade myself using the files provided by others on the forum (via the 70A thread) Link to post Share on other sites
dvdnovice 0 Posted October 17, 2007 Share Posted October 17, 2007 (edited) Isn't that updated firmware for the 70A and not the 700A? Hi uthmani, If you look at the documentation that comes with the upgrade, it clearly states that the upgrade is for all LCD and plasma TVs of the "7" range (ie. 7A, 70A, 700A in both PX and LX models). The link to the documentation is http://www.dtvforum.info/index.php?s=&...st&p=803250 That was what convinced me to download the file and apply the upgrade. Edited October 17, 2007 by dvdnovice Link to post Share on other sites
Blazerj 0 Posted October 17, 2007 Share Posted October 17, 2007 Thanks to all who make TV-life so easy here. Bought the TV based on reading here, have noticed the Channel 10 issue for a while, come here looking for confirmation plus I get the firmware update and instructions all linked and over and done with in 15 minutes. Outstanding. Thanks to you as well. I also bought the 700A from reading here. Assuming from your post you downloaded the S/W update. Did your downloaded file get a .txt extension, and if so did you remove it before downloading ? The file I received was "SDDL.SEC.txt". Link to post Share on other sites
MitchA 0 Posted October 17, 2007 Share Posted October 17, 2007 Tested it on Eveybody Loves Raymond, sound issue nowhere to be seen in the credits where it used to appear. As for the "SDDL.SEC.txt", it's just being renamed with txt as it's not a recognized extension, just take off the .txt and put it on an SD card Link to post Share on other sites
Rivallouie 0 Posted October 18, 2007 Share Posted October 18, 2007 I was going to buy this TV today, but since it will double as 2nd monitor I wanted to make sure that my MacbookPro connected all ok. Using the VGA port it initially detected the resolution at 800 x 600. I was able to get this closer to the native resolution on the TV (1366 x 768) by selecting 1280 x 700, but this still left me with some black borders. I also tried using the HDMI port, this was probably slightly better and when selecting overscan it was nearly perfect except the perimter of the screen was missing by about 1cm. I thought that this TV had 1:1 pixel mapping - shouldn't that ensure the correct resolution? Does anyone know how to fix this problem? (Preferably a non-software fix, maybe just a setting I've got wrong? On the other hand when connected to the Sony 32D3100 the resolution was detected perfectly. But I don't want the Sony for a variety of reasons. Cheers Link to post Share on other sites
potsie webber 0 Posted October 18, 2007 Share Posted October 18, 2007 Anyone know the going rate for these at the moment & the best place to shop in Melbourne? Link to post Share on other sites
barak 0 Posted October 18, 2007 Share Posted October 18, 2007 Using the VGA port it initially detected the resolution at 800 x 600. I was able to get this closer to the native resolution on the TV (1366 x 768) by selecting 1280 x 700, but this still left me with some black borders. I also tried using the HDMI port, this was probably slightly better and when selecting overscan it was nearly perfect except the perimter of the screen was missing by about 1cm. I thought that this TV had 1:1 pixel mapping - shouldn't that ensure the correct resolution? Does anyone know how to fix this problem? (Preferably a non-software fix, maybe just a setting I've got wrong?Cheers I'm a little confused by what you mean by selecting overscan - I do know that I'm able to adjust the position of the pc image on mine thru the settings menu on the tv, would there be a menu setting to adjust the position for the hdmi input? I'm about to go and get a DVI->HDMI cable to connect my HT to the TV, so I can start using a 360 VGA adaptor. I'll have a look later tonight about the hdmi and see if I can help. I think part of the reason that the hdmi fills the screen better is that it scales the input to the resolution of the screen, whereas it doesn't touch the VGA (analogue) input. Of course I could be way off!! Link to post Share on other sites
Blazerj 0 Posted October 18, 2007 Share Posted October 18, 2007 Anyone know the going rate for these at the moment & the best place to shop in Melbourne? G'day, I picked up mine at Clive Peters for $1545 after shopping around JB, HN & GG. Link to post Share on other sites
mcduck 1 Posted October 18, 2007 Share Posted October 18, 2007 funnily enough. i actually rang Myer ( indro, brisbane) today and was told they're going for $1620 but will price match. i think they were cheaper higher in this thread, hope that helps. Link to post Share on other sites
Rivallouie 0 Posted October 18, 2007 Share Posted October 18, 2007 I'm a little confused by what you mean by selecting overscan - I do know that I'm able to adjust the position of the pc image on mine thru the settings menu on the tv, would there be a menu setting to adjust the position for the hdmi input? I'm about to go and get a DVI->HDMI cable to connect my HT to the TV, so I can start using a 360 VGA adaptor.I'll have a look later tonight about the hdmi and see if I can help. I think part of the reason that the hdmi fills the screen better is that it scales the input to the resolution of the screen, whereas it doesn't touch the VGA (analogue) input. Of course I could be way off!! I have managed to adjust the position of the pc image via the tv settings, so it's almost right, but not quite. It still says the resolution is 1280 x 700 or similiar. If I connect to the Sony 32D it automatically defaults to the correct resolution of 1366 x 768. It seems strange that it won't do that? Link to post Share on other sites
ronburgundy 0 Posted October 18, 2007 Share Posted October 18, 2007 Picked one up for $1,560 from GG about 2 weeks ago Link to post Share on other sites
barak 0 Posted October 18, 2007 Share Posted October 18, 2007 I have managed to adjust the position of the pc image via the tv settings, so it's almost right, but not quite. It still says the resolution is 1280 x 700 or similiar. If I connect to the Sony 32D it automatically defaults to the correct resolution of 1366 x 768. It seems strange that it won't do that? I have the same problem with my laptop now that i think about it I can select the correct resolution (1366x768) on that but only 1024x768 on my laptop. I know that is related to the graphics drivers that are available for my Intel 945 chipset not having widescreen (XGA) capability. Link to post Share on other sites
Rivallouie 0 Posted October 19, 2007 Share Posted October 19, 2007 I have the same problem with my laptop now that i think about it I can select the correct resolution (1366x768) on that but only 1024x768 on my laptop. I know that is related to the graphics drivers that are available for my Intel 945 chipset not having widescreen (XGA) capability. Hmm...interesting, I'm not so sure I have a driver issue as it resolves the correct resolution on some 1366 x 768 LCDs, although perhaps the driver does not recognise it on certain LCDs. I have no idea really! Link to post Share on other sites
Jerboz 0 Posted October 20, 2007 Share Posted October 20, 2007 Uneven brightness on corners I've done some further investigation on this (see my previous post below). What I did was to make plain colored jpg (black, white, red, blue, yellow, orange) and copy it to my SD card. The size of the jpg is 1366x768 which should cover the entire screen. I used the slide show feature to play it. I noticed there are dark spots on all four corners. The next thing I did was to go to the place where I bought it. The sales guys was kind enough to allow me to test using the SD card on their demo/display unit. I notice the dark corners as well; and the sales guy admits seeing it too (this goes to show that my eyes are not playing tricks on me). I'm wondering now whether this is normal on all Panasonic LCDs. I'd appreciate if you guys test your unit as well and give me some feedback. Many thanks. Hi All,I've just recently joined this forum. I'd like to ask whether any of you have experienced a slight brightness drop-off on the corner of the screen. It's slightly noticeable but if I focus my eyes on the upper right corner, the pixels are a bit darker than the rest. It's not very big, probably 1 cm size only. After having noticed this while watching HD channels, I experimented by feeding XGA signal from my laptop; and making my Windows XP desktop all white so I can see the brightness difference. True enough, I could see some slight brightness drop off on the corners. My question is whether this is normal on LCD and should I just ignore it? Should the brightness be even on all areas of the screen (including corners)? Btw, this unit is new; just bought it last week. Thanks. Link to post Share on other sites
tech2002 0 Posted October 20, 2007 Share Posted October 20, 2007 Brightness test on corners - Unfortunately I don't have an SD media card. However, I was able to search through recorded material on my Panasonic ES55 hard drive, and find actual TV broadcast scenes/screenshots containing completely solid colours. This provided a real-life test to check for uneven brightness when displaying actual TV broadcast material. I was able to test four solid colours: White, Red, Blue, Grey. There was uniform brightness all the way to the corners of the screen on all these colurs. It is possible the colours displayed via your SD card may produce an edge effect not seen during regular TV broadcasting. I recommend testing your display using regular TV broadcast material containing solid colours, to see if darker corners also appear as with your SD card. If you feel the level of brightness variation is not satisfactory, then I would explain this to the store and have it resolved as early as possible. On the other hand, if it is not too bothersome, I would retain the original set, particularly if it does not have any dead pixels.... Link to post Share on other sites
dvdnovice 0 Posted October 23, 2007 Share Posted October 23, 2007 Brightness test on corners -Unfortunately I don't have an SD media card. However, I was able to search through recorded material on my Panasonic ES55 hard drive, and find actual TV broadcast scenes/screenshots containing completely solid colours. This provided a real-life test to check for uneven brightness when displaying actual TV broadcast material. I was able to test four solid colours: White, Red, Blue, Grey. There was uniform brightness all the way to the corners of the screen on all these colurs. It is possible the colours displayed via your SD card may produce an edge effect not seen during regular TV broadcasting. I recommend testing your display using regular TV broadcast material containing solid colours, to see if darker corners also appear as with your SD card. If you feel the level of brightness variation is not satisfactory, then I would explain this to the store and have it resolved as early as possible. On the other hand, if it is not too bothersome, I would retain the original set, particularly if it does not have any dead pixels.... Hi, I have also noticed some variation in brightless when viewing pictures using the Television's in-built SD card reader, but not with regular TV broadcasts, HDD recordings or pre-recorded DVDs. So it may have something to do with the SD playback option. Interestingly I've also noticed the same problem on the TV when using my EX-87 to play back pictures from its SD card slot (EX-87 is connected to the 700A via HDMI) but not with other output from the EX-87, so perhaps there is something wrong with the software used to playback pictures from SD cards. Link to post Share on other sites
dvdnovice 0 Posted October 23, 2007 Share Posted October 23, 2007 (edited) Sorry, double post Edited October 23, 2007 by dvdnovice Link to post Share on other sites
tech2002 0 Posted October 23, 2007 Share Posted October 23, 2007 Actually there was some discussion quite awhile back about the quality of the SD Card slot, both when using it for playing back recorded video material and also when displaying photos. It seemed the SD Card slot was more for convenience than for producing high quality images and video on the 700A. Really haven't had any issue with colour uneveness or darkened areas of the screen on my 700A when viewing DVDs or SD TV. Link to post Share on other sites
F@TMAN 0 Posted October 24, 2007 Share Posted October 24, 2007 (edited) Hey guys, was directed to this thread from OCAU, and I've been doing a bit of thinking between this or a Dell 27" Display. But, the more thinking I've done, I realised for the application (Foxtel & PS2) and the environment that it will be used in (bedroom, viewed from approx. 2m) , a 32" LCD would be the preference. Since there's been a lot of interest for this display, I was wondering what user's impressions are now that you've had a chance to break it in, and how its compared with other displays? Appreciate your feedback, cheers. *EDIT* Did a bit of shopping around the Eastern Suburbs in Sydney today, best I could get was just under $1700 incl. extended warranty to 5yrs. Seems like I might wait until some sales pop up before I purchase, in the light of some of the deals members on this forum have grabbed! Couldn't believe Myer trying to flog $400 for extended warranty, though, what a rort! Edited October 24, 2007 by F@TMAN Link to post Share on other sites
tech2002 0 Posted November 2, 2007 Share Posted November 2, 2007 I was wondering what user's impressions are now that you've had a chance to break it in, and how its compared with other displays? Appreciate your feedback, cheers. I think you'll find some good information if you review the many posts on this forum. I'm certain that people would update if anything has changed from their iniitial impressions on the 700a. It is a fantastic choice for a 32" LCD TV, as it also handles SD very well. I also don't think a few hunded dollars here or there should make a difference, compared to a TV you're not happy with, or with problems down the road that are unsupported by the manufacturer. Good luck, and keep us updated. Link to post Share on other sites
F@TMAN 0 Posted November 2, 2007 Share Posted November 2, 2007 appreciate your response, tech2002, I got my display up and running yesterday and have to admit I was very happy with it (although I didn't get much of a chance to fiddle with it - that's what weekends are for!). I managed to grab it from DJ's for $1500 incl 5yrs warranty, I guess my hard work paid off! =p Link to post Share on other sites
dvdnovice 0 Posted November 2, 2007 Share Posted November 2, 2007 (edited) appreciate your response, tech2002, I got my display up and running yesterday and have to admit I was very happy with it (although I didn't get much of a chance to fiddle with it - that's what weekends are for!). I managed to grab it from DJ's for $1500 incl 5yrs warranty, I guess my hard work paid off! =p Excellent price. I got mine for $1650 (excluding extended warranty) in July, and that was one of the "best prices" then. Make sure you check the version number: http://www.dtvforum.info/index.php?s=&...st&p=805776 and if necessary, get the update to fix the "sound breakup" problem: http://www.dtvforum.info/index.php?s=&...st&p=805790 Edited November 2, 2007 by dvdnovice Link to post Share on other sites
Frained 0 Posted November 3, 2007 Share Posted November 3, 2007 and if necessary, get the update to fix the "sound breakup" problem: I just updated my firmware using this update. Went from 3.03 to 3.08. I'm sure there was more to this update than just the sound. Link to post Share on other sites
fistingdwarves 0 Posted November 5, 2007 Share Posted November 5, 2007 appreciate your response, tech2002, I got my display up and running yesterday and have to admit I was very happy with it (although I didn't get much of a chance to fiddle with it - that's what weekends are for!). I managed to grab it from DJ's for $1500 incl 5yrs warranty, I guess my hard work paid off! =p Sharp price. Any chance of a receipt scan? I just went into Bing Lee (Pitt St mall) and spoke to two very friendly chaps who told me $1500 (incl wty) was below cost for them, so they couldn't do it. If you can give me the receipt, pls send to my DTV username at hotmail. cheers Link to post Share on other sites
Aloysius 0 Posted November 5, 2007 Share Posted November 5, 2007 Just bought one of these 700a's for the dining/kitchen area. It's a little ripper! It stands alone no DVD, no AV receiver etc. Good sound! Great picture! Good tuner! Easy set up! $1468 from Goodguys Recommend highly Link to post Share on other sites
Ramskii 0 Posted November 6, 2007 Share Posted November 6, 2007 Just wondering if anyone here has turned down the backlight yet? It can be done through the service menu but apparently it voids your warranty if you stuff something up though. I know how to get in but atm I am too much of a wuss to try it incase something goes wrong haha. Anyone care to be the guinea pig? Link to post Share on other sites
tech2002 0 Posted November 6, 2007 Share Posted November 6, 2007 (edited) What are the settings you've used to access the service menu - I've tried a number of settings without success. Many thanks. On another note, looks like the Panasonic 37" LCD has arrived in New Zealand. But the specs on the website say it's only a 1366x768 panel. Will try to find a store with a display model and check it out. http://panasonic.co.nz/product-detail$...#036;.html#tabs Edited November 6, 2007 by tech2002 Link to post Share on other sites
Frained 0 Posted November 7, 2007 Share Posted November 7, 2007 (edited) Just wondering if anyone here has turned down the backlight yet? The default for the backlight is 276, I turned mine down to 256. I can now turn brightness and contrast up without blowing away detail in the whites and the whites are now far easier on the eyes. I also reduced the red-gain from FF to F6, the reds just seemed to be grossly oversaturated. And I wonder why it would be turned up to the maximum anyway, the other colours are not. Faces now have a more natural colour. If anyone can figure out how to turn off the auto backlight dimming, please post. edit: turned down backlight to 256 not 250. Edited November 7, 2007 by Frained Link to post Share on other sites
Ramskii 0 Posted November 8, 2007 Share Posted November 8, 2007 What are the settings you've used to access the service menu - I've tried a number of settings without success. Many thanks. http://panasonic.co.nz/product-detail$...#036;.html#tabs I tried accessing it by holding -/v in while pressing zero on the remote. It has worked for other ppl so i assumed it would work for me. No luck atm though. Frained can you tell us how you accessed the service menu? cheers Link to post Share on other sites
Frained 0 Posted November 8, 2007 Share Posted November 8, 2007 (edited) Frained can you tell us how you accessed the service menu? I should have mentioned this when someone asked before. Our 32lxd700A are different to the UK 32lxd700, they press the "0"(zero) on the remote, we press the "i"(info). so, press and hold -/V on the TV while clicking "i"(info) on the remote 3 times in quick succession. edit: Fiddling around inside the service menu can seriously screw your TV not to mention the warranty. I would suggest recording the default settings on paper before making any changes and put the paper away in a safe place for future reference. Edited November 8, 2007 by Frained Link to post Share on other sites
fistingdwarves 0 Posted November 8, 2007 Share Posted November 8, 2007 Purchased 8 Nov 2007 from GG Alexandria for $1565 incl 5yr wty. Shopped around at various places and best alternative offer was $1560 from Bing Lee (but the salesman was a polesmoker). GG offered TV alone for $1350, and cash deal (i.e. no Visa card) with wty for $1550. Salesman (who was the store manager) told me that at $1550 he was making $13 on the TV, and he seemed like a fairly honest chap. He also seemed to know a lot about various places' 5yr wtys, how much each one cost, which was better than which, and why. Perhaps unsurprisingly he said GG's was the best and BL's (which BL only charge $120 for- compared to $300 'standard price' for GG's) was junk! Thanks to all posters for price guidance, it certainly helped me get a price I'm satisfied with. Link to post Share on other sites
Ramskii 0 Posted November 11, 2007 Share Posted November 11, 2007 I should have mentioned this when someone asked before. Our 32lxd700A are different to the UK 32lxd700, they press the "0"(zero) on the remote, we press the "i"(info).so, press and hold -/V on the TV while clicking "i"(info) on the remote 3 times in quick succession. edit: Fiddling around inside the service menu can seriously screw your TV not to mention the warranty. I would suggest recording the default settings on paper before making any changes and put the paper away in a safe place for future reference. thanks for that mate. Turned it down to 250 and now the whites are much better I must say. Blacks dont seem to be any darker though. PPl on the uk forums have turned it down to 200 so i might try that. Link to post Share on other sites
THX1979 6 Posted November 13, 2007 Share Posted November 13, 2007 I bought this TV a few days ago to pair with my PS3 for gaming. I compared it with my sony CRT (hr36) 1. Motion handling - superb 2. Color fidelity - superb 3. Blacks- I have to admit coming from CRT the blacks were piss poor. In fact i was in shock but I guess thats to be expected. 4. BLU RAY - saw Ratatouille last night and the picture quality is on a par with CRT but richer, more vibrant colors but worse blacks than CRT Are there any service menu tinkerings that can improve the blacks?? Link to post Share on other sites
tech2002 0 Posted November 14, 2007 Share Posted November 14, 2007 I bought this TV a few days ago to pair with my PS3 for gaming. I compared it with my sony CRT (hr36)1. Motion handling - superb 2. Color fidelity - superb 3. Blacks- I have to admit coming from CRT the blacks were piss poor. In fact i was in shock but I guess thats to be expected. 4. BLU RAY - saw Ratatouille last night and the picture quality is on a par with CRT but richer, more vibrant colors but worse blacks than CRT Many thanks for your comments. How do you find the sharpness of the Panasonic vs the Sony CRT with good and also high quality source input. Link to post Share on other sites
THX1979 6 Posted November 15, 2007 Share Posted November 15, 2007 well the sharpness on this LCD is perfect and u dont get any of the convergence problems of a direct view CRT. For viewing films (which is my main hobby) I would not recommend this LCD as the black levels are not up to the same standard as a Samsung or Sony LCD flagship models. I noticed the same problems on the Hitachi and LG LCD's - washed out blacks. Games are fantastic though (eg Ridge Racer 7) Link to post Share on other sites
chalks1971 0 Posted November 15, 2007 Share Posted November 15, 2007 thanks for that mate. Turned it down to 250 and now the whites are much better I must say. Blacks dont seem to be any darker though. PPl on the uk forums have turned it down to 200 so i might try that. How do you navigate the service menu? Link to post Share on other sites
barak 0 Posted November 15, 2007 Share Posted November 15, 2007 How do you navigate the service menu? Using the red and green buttons and 1,2,3,4,9 or something. I hit 1 after the screen loaded and was moving thru the menus. If someone can tell me where to go to change the backlight as i can only see the R-gain that someone set to F6 from FF... Cheers! Link to post Share on other sites
Ramskii 0 Posted November 15, 2007 Share Posted November 15, 2007 Using the red and green buttons and 1,2,3,4,9 or something. I hit 1 after the screen loaded and was moving thru the menus. If someone can tell me where to go to change the backlight as i can only see the R-gain that someone set to F6 from FF... Cheers! To get to the backlight hit the green button 3 times when you enter the menu Link to post Share on other sites
