cttc
Foxtel Faq - Setup & Use (& Optus Digital)
Can I ask what picture setting that people use ?
I have Foxtel Digital and a Bravia X series.
I have been playing around with the picture setting and I can't seem to get it right.
On the box system setting,
do you adjust the pic setting from the box or TV ?
And on the TV, which mode should I use to watch Foxtel
(zoom, wide zoom, normal, can't remember the other one) ?
Is the picture coming from the box widescreen or is it just 4:3 ?
I'm just using a normal SCART to component.
Thanks.
In the Foxtel STB Setup/Picture settings Menu set TV Type to 16:9 (Widescreen).
In your TV's menu set your display to 16:9 (Widescreen).
Some Foxtel programs are 4:3 so there is also a Foxtel menu setting for what the Foxtel STB is to do with 4:3 programs (Put black bars, 14:9 or stretch).
See your Foxtel STB manual (PDF) for more details.
There are so many combinations and this will probably be a work in progress but:-
Foxtel (TV)scart S-Video & Analog Audio -> TV
Foxtel (VCR/Video)scart S-Video & Analog Audio -> DVDRecorder
PS3 HDMI -> TV
Wii Component -> TV
DVDRecorder HDMI -> TV
TV Optical Audio -> AVReceiver
PS3 Optical Audio -> AVReceiver
DVDRecorders Coaxial Audio -> AVReceiver
Wii Analogue Audio -> AVReceiver
Optional TV Analogue Audio output ->AVReceiver
Optional Foxtel Analogue Audio output ->AVReceiver
Antenna (RF cable)->DVDRecorder->TV
You could instead record Foxtel using Composite and use Foxtel Component output.
I ran out of inputs on the AVReceiver for Foxtel's digital audio output.
I didn't try to use the AVReceiver for switching of video (as it doesn't have HDMI inputs/outputs).
I didn't make assumptions about the TV's ability to pass through Digital or Analog Audio.
Thanks heaps for your suggestions.
A gentleman at HN indicated i buy a FOXTEL SCART to Component. Would this be appropriate?
Just asking the quest, any help would be received gratefully.
Thanks again cttc
Yes it is a valid choice, as I said you can either go Scart to TV S-Video & Audio and Scart to Recorder S-Video & Audio
OR Scart to TV Component & Audio and Scart to Recorder Composite & Audio.
(You can't get Component and S-Video at same time from the standard STB(420), you can with an iQ)
People decide based on how important recording quality is to them.
We're thinking of getting Foxtel sometime.
I got some questions about Multiroom ( 2 IQ boxes )
This might sound very stupid but can can Foxtel iq have "my sport" package on 1 box and other foxtel box have "get started" package channels
My dad mainly wants his for Sport and My mum and I don't :lol:
Thanks cttc.
Please see the connection configuration below, which i found in this topic. I noticed that my recorder has an RGB SCART input. Even though i need to have the recorder on at the same time, would this improve my recoring quality while maintaning my PQ aswell.
"Config B1r - Foxtel to RGB converted to ? on TV. Foxtel to RGB on Recorder. Potential Foxtel display quality: Average to Very High, Record Quality: Very High
Requirements: Recorder with RGB input (normally a Scart), TV with a matching input to Recorder's (HDMI or Component or RGB) output
1. Foxtel's (tv)Scart output >---(Scart to Scart cable)---> Recorder's Scart input
2. Recorder's HDMI or Component or RGB & Audio outputs >---(HDMI or Component or RGB & Audio cable)---> TV's HDMI or Component or RGB & Audio inputs"
My recorder will had a HDMI output to TV's input so this means i potentially have High viewing PQ and high Recording PQ.
Am i correct in my assumptions.
THanks :D
I don't have access to a manual and it isn't listed on specs I have seen. But if it does accept Scart RGB (input) then yes another valid option that should be better than the others quality wise.
PS Some Australian Panasonic DVD recorders were incorrectly listed as having RGB scart input (some old models and the european models actually can do it though). As long as it is in the manual that came with it you should be ok.
Possibly a stupid question but having just received the 2 week access to Showtime I see some movies light up as Dolby Digital - what format is the sound for all the other stations?
Also, what video resolution does Foxtel output via component - my Plasma is saying 768 x 288?
Martin
No doubt already asked & answered but I'm just double checking...............
I am looking at connecting a Foxtel Pace 420 STB to a Panasonic DMR-EX77 DVD-R for recording.
From what I have read, and going by recording configuration C1rS1 in the 1st post, I intend to purchase a SCART to S-Video cable to run from the TV SCART output on the Foxtel Box to the TV, and a SCART to SCART cable to run from the Video SCART output on the Foxtel Box to the DVD-R.
Am I correct?
Are the cables from Jaycar Electronics OK for this?
Yes that is a valid config and Jaycar cables are fine. You could go Component to TV and Composite to Recorder of course.
Personally, i think the s-video to tv and to recorder option is the best compromise.
I have tried component and s-video to the tv and i don't see that much of a difference, i have a 32"LCD. This might be different on a larger screen size of course. I find that as i record a lot, being able to watch recorded and live to air Foxtel at the same PQ is great.
The whole Foxtel PQ issue seems to be more to do with the signal that Foxtel transmits rather than the connection type from the STB to the TV.
Edited by ja5on
To cttc & ja5on, thanks for the replies.
Think I'll stick with the middle ground connection as I tend to watch/record 50/50.
Cheers.
This might sounds stupid, oh well :)
1. Can country people get "digital" Foxtel where they live?
2. Or is it like the free HD/digital channels? where people have problems getting them?
I hope I made sense.
Foxtel is not available in most country areas as Austar have rights for those areas. But where Foxtel is allowed to have customers it is a satellite service (anywhere outside cabled areas) and so country people don't have same problems that Digital Free To Air TV has.
Here's what I'd like to do, any hints gratefully received (apologies for newbieness)
At the moment we have Foxtel, an LG TV, LG DVD and Sony VCR.
I like the idea of Foxtel I.Q for recording but would also like to permanently archive/make copies for friends (from Foxtel, Digital Camera, etc).
As far as I can work out I could go with Foxtel IQ and also grab a DVDR or maybe go with a
Sony RDRHX750 which appears to do both??
Should I get I.Q and just a cheaper DVDR with no HDD or the Sony RDRHX750 ?
Or am I rambling up the wrong tree?
It is hard to beat the convenience of the iQ (recording direct from planner, recording two things etc). So that with a DVD Recorder for permanent backups is what I would suggest.
I would only seriously consider just an external recorder (DVD with HDD) if your Foxtel doesn't get a lot of Free To Air stuff you record (you have Foxtel via satellite and don't get some channels etc). But remember you are only going to be able to record one Foxtel channel at a time with an external recorder and also not be able to watch another Foxtel channel while recording one.
Thanks.
We have Foxtel Cable and would definitely record FTA stuff. The recording/watching limitation applies to I.Q with Ext DVDR or just DVD with HDD so I suppose the ease of use of I.Q could be the clincher.
Any hints as to a good sub $300 DVDR. I'm a bit of a Sony Boy but have heard lots of good things about Pioneer and bad things about LG (although our current LG DVD player has coped with everything I've thrown at it)
Yes but you can be recording something else as well with the iQ, and with the iQ you can always just write out recordings later to the DVD when your not watching stuff.
Suggest you have a read of http://www.dtvforum.info/index.php?showforum=8 as this isn't the place. The panasonic is worth considering.
Cheers, will have a look
Thanks for all your help
Thanks cttc,
The Panasonic DMR-ES15 looks like the one as it has DivX playback, which I need.
What would be the optimum setup with Foxtel (won't be getting I.Q just yet)
Be careful with all DVD Recorders and their divx playback, some will not play back on some formats eg not DVD RW.
As for connection with the current Panasonics it is usually choice of Component to TV and Composite to Recorder OR S-Video to TV and Recorder. See the FAQ at the start of this thread and the messages back a bit.
When you get an iQ you can have Component to TV and S-Video to Recorder.
Hi cttc,
I'm grabbing a Pioneer DVR 550-H-S tonight as it seems to best fit our needs.
Our LG TV has Component In and Composite In and Out.
I also need to connect Foxtel and our Sony VCR.
What would be the best connection I could get until I go with I.Q down the track?
Config A1r OR Config C1r from FAQ for your DVD recorder. If you are mainly going to be watching recordings and timshifted Foxtel via the DVD recorder then go for C1r. Then use Foxtel STB's remaining composite video output or the RF output for the VCR.
When you get the iQ you can still use the A1r Scart to Component cable for your TV and the Scart to VCR cable for your VCR but will need a S-Video to S-Video cable for connecting your recorder (for best results (A2r)).
EDIT: wait a sec if your LG doesn't have S-Video in then A1r.
  • Recently Browsing   1 member
