cttc
Foxtel Faq - Setup & Use (& Optus Digital)
Other than the optical port that DS250 looks identical to the DS230 that we have had here in NZ (SkyNZ) for a couple of years now.
Cyril
Cant see where to edit my post, but my first pic was meant to be this one.
Thanks for the info updated the FAQ.
I stand by my advise, connect using YUV via the DB15 connector and your on your way. If you chose RGB you need a H&V sync seperator and achieve nothing.
This leaves your PC to feed the DVI input, and the Foxel box to feed YUV (Component) into the VGA connector. Dont go down the RGB over VGA line, it will not benifit you one dot.
Cyril
Thank you very much cyril
Hi
My foxtel keeps going to no signal or flickering on my TV AV input not on the foxtel signal. I've tried changing leads, swapping connections, tried a set top box through that av and it works fine. So i'm thinking the AV input has a problem.
It happens alot on sports replays on foxtel.
Any help would be appreciated
Try with a different cable from a different Foxtel STB output (eg use the VCR scart composite output, or the RCA composite output if your box has one) to narrow the problem. It might just be your Scart cable so try the one plugged into your VCR scart if you have one. Which Foxtel box is it?
I've tried the different outputs only thing I was going to try is scart out of foxtel box to component.
Not sure what box it is grey box with smart card on left hand side at front.
I rang up foxtel again and they said its probably the box so getting a service call.
I noticed that replacement IQ & Foxtel remotes can be purchased at Dick Smith/Tandy stores
Also just noticed that the DSN250 CAN do component (YUV) and that the RF modulator has been removed.
Does anyone know if it is possible to get your foxtel to switch state feeds.
I am desperately wanting to get NSW ch9 not Vic.
Just wondering if this is something that is programmed on the card, the box or the sat feed itself to this region.
Dan
The card has details that were programmed based on your residential address. Doubt you can readily have it changed, for legal broadcast region reasons.
Cyril
I had a Foxtel IQ box installed on Monday and have found this thread to be of great help in understanding the gamut of PVRs, STBs, etc.
Many thanks to the contributors, particularly 'cttc' for the excellent oversight.
Les Harris
Vic
Good to hear it was useful.
Need help RE: Foxtel installation.
Around 2000-2001, we had foxtel and moved to a new house right near Kincumber mountain..the foxtel guy said apparently we couldn't get reception because of where we now live.
Now back then Foxtel was analog, its now digital..
Foxtel is coming out on Saturday for install, what are my chances of it going ahead?
I have seen alot of other houses with interferance with mountains and trees so I don't understand, hopefully its different with digital.
Thankyou.
P.S. - I tried to start a new topic but it didn't let me.
PSI-11D, it's quite possible cable may be available in your area, which should give you everything that Satellite offers.
im on the central coast, nsw..i dont think cable is avaliable..so will there be problems if i can only get satelite?
I can't see what sort of problems there would be being on a mountain, unless your specific location prevents clear line-of-sight to the Foxtel sat. See what the techie says - if it can't be installed I'm sure they won't charge you.
Im not worried about the charge - Its free anyway.
Im just hoping that its different this time around. Im actually below a mountain...but the thing is, Ive seen alot of other dishes pointing straight at trees, mountains etc and they have it hooked up..why did the tech not even bother to go on the roof to try?
Fingers crossed. :blink:
The angle of incidence of the beam from 156E (Optus C1) in your location is 50-51deg depending on your exact location, with an azimuth of around 9-10deg so if you lookup at an angle of 50deg in the northern sky can you see without obstuction, if so then all should be fine.
If you make a simple triangle with a piece of cardboard that has a base length of 100mm and a vertical length of 120mm (thus a hypotenuse of 156mm) then you will have a 50deg triangle. Hold this level, helps if you have a spirit level, and look up the hypotenuse, if you see clear sky roughly 9deg to the east of north (real north) then all should be ok.
Dont forget that KU band dishs are offset dishes, as such the LNB arm points some 20odd degrees below the angle of beam incidence.
Cyril
Hi - anyone able to help me out here?
I got foxtel installed last week. Looks like a UEC box (its got a sticker saying DN 1000 attached) so I presume its a UEC 1000? I'm connecting to a new Samsumg M81 LCD. Picture quality using the std Scart to Composite is pretty average so I bought a Scart to Component cable on the advice of the foxtel guy. Followed the instructions from foxtel to set up the component connection (changing the picture output from PAL to YUV) but the picture I get is shocking. I have reverted back to using my new cable as a composite output at this stage.
Any suggestions where I could be going wrong ?
Thanks to any good samaritans out there
Z
Edited by zinc
Only thing I can suggest is to make sure you have the cable going from the TV scart and not the VCR scart.
Just reread your post. How can you revert to using your new cable (which presumably has 5 leads) as composite???
Things I would try:-
Make sure you select save settings after changing to YUV.
As Venus said make sure your using TV scart.
Make sure your plugging the component cables into correct sockets on TV.
Try the other component input on the TV.
Disconnect the composite cable (ie don't have both component and composite connected at same time).
Maybe even do a firmware update on the box.
Otherwise maybe you have dud cable or dud box.
The Foxtel Scart to component cable has 6 (3 component 2 audio and 1 composite).
Thanks for that. I haven't seen the Foxtel-branded cable; only the typical 3 component plus R/L Audio.
So if I get Foxtel hooked up now and buy a DVD recorder later, how easy will it be for me to set it up to record? I'm great at using technology but crap at setting it up!! :blink:
